Results 1 to 6 of 6
    Cleavage Of The Tetons
    Any of you have a Roomba and a voltmeter handy?
    I could use a favor. Wifey said that the Roomba battery died, so before just busting out the Amex, I figured that I would do some diagnostics.
    My first reaction was "yay! here is as good excuse to build a new Li Ion battery out of parts from Deal Extreme, and bump it up to 2800 (or more( Ma!"
    But first, I want to figure out what is going on.
    The charger that plugs into the wall is giving out (close enough) to the correct 22.5v
    BUT the Homing/charging dock is giving out a severely low value, and I am not sure why. Curious if this is correct!
    Additionally, the battery gave a read of a whole different value:
    So, I am thinking something is hinky.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    The battery has 12 cells. That's 14.4V charged. Do you have anything like a hobby charger like Imax B6 ?
    I used it to check Roomba batteries in charge/discharge.
    CNC LED light housing for DIY projects
    PRETENDURO
    All-Battery.com: Total Power Solution for Every Battery Need has relatively cost-effective replacement battery packs for the Roombas. Ours is still amazingly on the original battery pack. We bought it three years ago and it is run once a week. Expecting to get a call from the fire department some day when one of the cells has a rapid discharge incident while we’re at work.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
    You can't replace the NiXx cells without replacing the charging circuit and providing a low voltage cut off, another thing to consider is discharge rate, I don't know how many amps a roomba pulls. I suggest some serious reading about li-ion technology first.
    Why do you assume that (we) wouldn't know that?
    Because of your initial post.
