Results 1 to 3 of 3
    Nov 2006
    Another switch question....
    A little help for an ignorant newbie. I am planning on an xm-l build using George's Lflex driver. I saw that Savagemann used a momentary switch he got from ebay. It is described as momentary normal off. It is billed as a boat horn switch, push for on, power off when released. Is this the correct type of momentary switch for an Lflex?
    Thanks in advance.
    Jan 2011
    Yes - you want a momentary switch that is normally open.
    Dirt Deviant
    Reputation: savagemann's Avatar
    There are a couple types of MOM switches.
    N/O which is normally open
    and
    N/C which is normally closed.
    The flex drivers use a N/O switch.
    Normally Open switches are also referred to as
    Momentary Off,
    Push On,
    OFF - (ON),
    N/O,
    Off-Mom,
    and probably a few other terms as well.
    The switches I linked to on ebay work perfect with the flex drivers, and are a pretty good deal I might add.
    Look, whatever happens, don't fight the mountain.
