Page 1 of 2 12 LastLast
Results 1 to 100 of 140
    Reputation: Goldigger's Avatar
    Another Cute Tripple XML
    I've got all the bits and after some thought come up with the following design for a round tripple xml using a cute optic and a H6flex..
    Thinking it looks a bit basic at the moment...
    Reputation: Khrystyan27's Avatar
    Cool, i will be watching this topic...
    Estimated lm output?
    What tipe of optics?
    Leds are XML U2 bins...Cree quote @3amps 975 per led
    Optic Ledil Cute 3-SS-XM
    Made a start on the mill today
    Here's how i will seal the rear cover
    Rear driver compartment milled out with the lip for the oring
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Very Nice GD.
    As far as being basic I think that's the only problem using rond bar. There's only so many things that can be done with it
    Reputation: HuffyPuffy's Avatar
    This is really cool, you are really going to give the rotary table a work out with this one
    Quote Originally Posted by HuffyPuffy View Post
    Your not wrong there...I i need to motorize the rotary table, I have been using a drill and spining it with that
    Reputation: yetibetty's Avatar
    GD the design looks good and I'm sure you can pull it off. But you are going to wish that you had a lathe to compliment your mill at some point.
    Keep up the good work.
    Quote Originally Posted by yetibetty View Post
    If i only want to turn anything up to 32mm i can put some round bar into the appropriate sized collet in a ER32 chuck, like shown in this video..
    If i need to go a bit larger id have to mill a stub on one end of the bar to fit into a collet..
    <iframe width="560" height="349" src="http://www.youtube.com/embed/TIOzLL8jMPI" frameborder="0" allowfullscreen></iframe>
    I have seen that video a few times and it will work for the small stuff. Unfortunately the largest you can fit in an ER32 collet is 20mm (16mm for ER25) as the ER number is the outside diameter of the collet not the inside.
    You're doing fine as you are and the results are the same with a lathe , the lathe is just faster.
    You could always get a screw on chuck, screw it to an MT3 taper and stick it in your spindle! But what's the rush?
    Look forward to the finished housing.
    Dam I was wrong on the collet sizes..just looked on rdg and they do a ER40 which goes up to 25mm.
    Just do what this guy has done http://www.youtube.com/watch?v=b2-Kdud7eiA
    I'm impressed in how excited his wife is with his efforts. Mine just says that's nice in that tone we all know
    that's awesome! Now if I could only I could get my wife to build me one, she'd have all the adulation she could ever want
    oh, and looking forward to the light GD
    Quote Originally Posted by brad72 View Post
    brad, I'm going to get my wife to watch that vid, just so that she knows how she is meant to react when I cut through metal.
    Mine just says "as long as you clear up arter yourself, I don't mind what you do".
    Not very inspiring
    A waste of time it is is
    Reputation: emu26's Avatar
    I agree with her, "frigging amazing", both your new light GD and that video.
    Now if only I could find the time to get mine cleaned and set up
    Great video, makes me want a lathe now, will have to wait though.
    meep meep !!!
    Reputation: Road_Runner's Avatar
    Quote Originally Posted by emu26 View Post
    What, your wife???
    Perhaps you could let us know how to do that as well.
    Not very inspiring
    Here you are Yeti...hapf the kit to add the 4th axis to your mill...
    http://www.ebay.co.uk/itm/ws/eBayISA...m=270696993188
    Bout time for an update..
    Rear and front cover...working on the rear cover here..I machined the front and rear cover from one piece of round ali bar. Once i've machined the two sides, one side of the front and one side of the rear. I then saw them in two and machine the remaining face for each cover.
    Front cover-after i parted the two.
    Main body and rear cover in the 4 jaw chuck mounted vertically
    GD, check your PMs.
    Your parting tool is ready.
    GD, check your PMs.
    YB..check your pm's sent you PM 30 mins ago in reply
    Also check your paypal
    Quote Originally Posted by Goldigger View Post
    Got the paypal (thanks) will post in the morning. No PM though.
    Opinion guys..
    ok i've crudley manipulated this image and added in some extra slots that are present but not got a photo..should i mill a grove around the body through the middle of the horizontal slots as indicated by the black line?
    Idea being that the hot air in the fins will be able to clear better...
    Reputation: uncle_bob's Avatar
    How about a circumference groove at each end of the horizontal slots if possible it may look a bit better than one in the middle. My two bobs worth
    Quote Originally Posted by uncle_bob View Post
    I see where your coming from..good idea..
    I'm with uncle bob.
    I'm with uncle bob.
    How does your wife feel about that?
    Or you could do multiple grooves, but it may end up looking like a porcupine. Though it will give you more surface area and good air flow.
    I know nuthing!!
    I know nuthing!!
    I gotta be carefull noy to remove to much material, it weighed around 175grams before i started trying to make it look pretty..
    This has to cope with 3 xmls running at 3amps
    Ok, however, when standing still it will probably be smokin at 3amps anyway, so you may as well make the walls thinner to get the heat out quickly when you are at full amps and moving? yes. Im no thermal engineery guy though
    Maybe the grooves at each end are the go anyway.
    For years there has been the debate about which direction the fins should point. In the end I decided both directions is best ( in other words I couldn't make my mind up ).
    This light still works today after lots of use over a couple of years and it runs cool. Not 3 XML's and I had to do it on a drill press with router bits.
    GD, I'm sure you can do a similar thing only better with your mill.
    Yeti i really like that light...not sure mine will look as good to be honest..
    Anyway here is the updated pic of the grooves..no time to do anything tonight but will get some done tomorrow after work hopefully
    Here's an update on a little bit of tonights works..had to make dinner so i didnt get to finish it..
    Still need to finish the part from the front bezel to the start of the horizontal grooves..
    Had a lumicycle mount in the draw so used that rather than buggering around maching a mount for it.
    Looking good GD. Certainly a good testiment of what can be acheived just with a rotary table and some skill.
    Make dinner...... life's hard for us blokes these days with all the extra things required from us eating into play time like cooking, vacuuming etc etc etc . Hope my wife doesn't read that sentence.
    Looking good GD. Looks like this light will be quite light weight by the time it's finished it's rotations.
    P.S I do all the cooking as my wife can't/won't cook.
    Cheers for the comments guys..
    At least i didnt have to wash up last night...If i cook the mrs washes up visa versa (or she gets a slap)
    Nearly finished, just need to sort out the switch and cable gland...which will be a hirchmann M8 connector
    Oring in place for the led end...
    Oring in place for the driver end, which needs to be redone as i cut the oring chord to short
    All put together..
    What do people think on using one of my little mom switches? to small? If i used one of them i would put the switch on the right, M8 connector on the left and a status led above in the middle..
    Or use one of the usual ITW switches with led in the middle as seen on the tripple P7?
    And just to add, this light was machined entirely on the rotary table...wasn't as bad as it used to be now i have the 4 jaw chuck
    That's rather nice GD, well done.
    I would go with the big switch if you have the space for it. I only use the tiny switch in my lights now due to lack of space, both work just as well but if you have created enough space then you may as well use it.
    Thanks yeti...
    Thats the problem i dont have any spare ITW switches..like a nob i ordered a load of bits from RS and forgot to get some ITW switches...
    Oh and thanks for the parting tool...havent used it yet as i've been busy doing this one
    GD, I like the finish on this one. Did you have a go with the 00 grade wire wool?( no not brillo pad ) and how much does it wiegh? I bet it's one of your lightest yet.
    I gave it a quick go over in the sink with some 1200 wet and dry...just to make it look nice for some photo's
    I was quiet surprised when it tipped tha scales at 200g, I though it was going to be less..(includes the lumicycle mount etc)
    200 grams
    You probably want that much for 3 XMLs though.
    Tis a good looking light there Jay and a quick thanks for the thread as watching it progress has bumped me into starting another CUTIE a couple of days ago .
    and hope to have it working today as it is piddling down up here in Yorkshire.
    Can I borrow your thread to put up a few pics later today as it doesn't really merit a thread of its own
    Quote Originally Posted by troutie-mtb View Post
    Thanks Chris..
    Of course you can..I always like seeing what you create..as they seem to get better and better.
    My rear cover is sitting on the mill waiting for the postman who never came came to deliver a m12x1 tap for the switch..I hate that 13.5mm little lip on the back of the switch that you need to mill a recess for the switch to sit flush.
    Thanks Jay
    well it started out with in idea on how I wanted it to go using square stock but didnt really go as planned round and square are not the most easy shapes to marry up.
    so it morphed as the build went on not to mention the cockup that nearly ruined it but meant I had to change design to machine out the scars .
    The damn camera battery ran out so I just carried on shaving metal off so no pics I am afraid.
    I know what you mean about the switches I am using some clip in ones but using glue to fix it in .
    will have a pic of it assembled soon when the switch glue has set enough to move it from the vise.
    Finished and assembled
    Nice work there Chris... I like the hood idea over the front of the optics
    Do you think this will handle the full 3 amps? If i remember correctly your helmet light got hot quickly..
    If you were to sell this with a hirschmann cable, but without a battery and charger what would you ask?
    You can PM me the answer to that question if you prefer
    It is a strange lovechild of the Liberator and 7UP which have been mating for a while now
    but the baby was a long time coming .
    Re heat I am not yet sure how it will cope but think it will be OK when moving
    I have it set up for the full 3 amps of course but when on the middle setting it handles the heat well inside the house but does warm up fast on full .
    Money wise I have no idea at the moment will have a think .
    what tints have you used this one is 1B which is strange as I ordered 1D I have also a 1C to try sometime
    Just had to look at my cutter account to check the tints..I've got a load of 1C.
    I've just finished milling the holes for the switch and cable connector..all that's left is to tap the hole for the switch.
    Which will wait until Monday when hopefully the postman delivers the taps and switches.
    No pics as I have to rush out for my birthday dinner now...
    I wasn't going to bother with a beamshot, but I'd like to compare it with my Tripple XML..
    Happy Birthday Goldigger,
    and nice looking light Troutie, you do turn them out incredibly quickly once you get strated
    Yep Happy Birthday Jay not too far from mine which was the 9th
    another Leo .
    Thanks Stu had a long layoff with light building mojo gone but had some spare time and it was good to get making swarfe again even though it turned out not as I had in my mind
    going to start another one but take some time to think how to blend round front to oval back and want it to look small .
    Sorry I know what i want it to be like but dont know yet how to machine it on my stuff.
    got the weight to 160 grams built and working
    Thanks guys...
    My birthday isnt until the 16th...but thats a school night so to speak..
    I wired mine up using a temporary switch that doesn't have a led in the middle for the stat function.
    It's quiet funny something so small chucks out this much light..(44.5x68.5)
    I also bought some electronic scales, all asembled mine is 223g. I'm happy with that to be honest, Id prefere to have an extra 50grams to shed some of the heat..
    I'm also happy with the design, apart from the wiring it up! That took me bloody ages with my fat fingers
    I've got enough round bar to knock up a couple more of these...but no space on my handle bars.
    So i was curious how this would compare to my tripple XML that used T6 bins, This cute tripple has U2bins..
    Sorry the beamshot is a little blurred, didnt notice when i took it. But to be honest there isn't a lot between the two..
    Tripple Cute
    Tripple XML
    Yes thats the back of my car at the bottom of the path..
    Does anybody know what the 5 sub levels are on the H6flex for 3000mah?
    Has anyone tested to see what the pull off their battery is with a h6flex and 3 xml's?
    I dont have a multimeter to hand so just wondering what sort of runtimes i can get out of my 14.8v 5800mah lipo..
    Straight maths id expect around 2.5hours on max..
    If it helps I can give you the draw from a benchtop power supply with the light on 3 amps setting and the power supply set at 14.8 volts
    level------- draw------------ watts
    1------------0.03 amps------- 0.444
    2------------0.12 ----------------1.776
    3------------0.40 --------------- 5.92
    4------------1.14 ---------------16.87
    5------------2.14 -------------- 31.67
    HTH
    level draw watts
    1------------0.03 amps 0.444
    2------------0.12 1.776
    3------------0.40 5.92
    4------------1.14 16.87
    5------------2.14 31.67
    HTH
    Thats brilliant Chris
    Just to clarify first column amps and second watts?
    Thanks..
    Edited it seems to not like spaces
    Yes you are correct
    I think both of those look very tidy - GD's is a bit more "stylish" for what that's worth, although Troutie's looks like it has more surface area.
    Interesting about the current draw. Going from the Cree spec sheet posted in the "XM-L - let's discuss" thread, those roughly work out to:
    L1 - always 50mA
    L2 - 0.22A
    L3 - 0.69A
    L4 - 1.75A
    L5 - 3A
    The real L2-L4 levels are probably ~50mA either side of those values as I used the T6 voltages, which may affect things a bit plus losses etc, but they're good enough. I'm personally amazed at how little difference there is between L4 and L5 with 2 XM-Ls. I can tell it's there, but functionally they're pretty much the same.
    Oh, and the U2s do look a little brighter (mostly the tree near your car), though that might be down to other things.
    Reputation: Wombat's Avatar
    Quote Originally Posted by mattthemuppet View Post
    L1 - always 50mA
    L2 - 0.22A
    L3 - 0.69A
    L4 - 1.75A
    L5 - 3A
    This review shows XM-L lumen output all the way up to 5 amps. Results: Testing XM-L, MC-E, and SST-50 emitters up to (and over) 5 amps. | BudgetLightForum.com
    At 1.75amps it's around 650 lumens and at 3 amps it's 880. Around 2.4 amps seems to be the sweet spot.
    Tim
    Good find Wombat.
    Lots of info, thanks for posting.
    I'm not surprised though the same happens every time there is a new LED, the max it can receive is a safety net and not the most it should receive to produce light and not just heat.
    meep meep !!!
    Gotta love BLF, eh?
    There's some really interesting stuff there and Match's posts are always worth reading.
    It's very torch oreintated of course, but there's plenty that can be transferred over to bike lighting, so it's worth having a trawl through there from time to time to see what they're up to.
    another Leo .
    That is a great looking light Troutie, really like the hood on the front too. It is cool to see several different takes at a triple cute xml light in one place. The next one sounds challenging on a manual mill. I would not have a clue how to mill an oval on a manual mill, let alone blend ovals with circles, that is getting into 3D milling.
    And one more thing... happy birthday GD!
    Has anyone drilled extra holes in the PCB on the cutter tripple XML boards?
    Assuming it's ok as long as you keep away from the tracks?
    Tripple Cute
    Tripple XML
    WOW !!!
    Powerful that light !
    Did you get some flashes from other drivers?
    Manual Mill not a chance time to call in a favour or two .
    first draft today
    YEAH HAPPY BIRTHDAY JAY
  67. #67
    Put the new switch in today and tapped the hole for it...all finished now.
    All my other lights are redundant now, i prefer this one over all of them as its so compact.
    I also had an audience while soldering the new switch in..
  68. #68
    Been busy making two more..not finished but getting all the work completed while the rotary table is mounted horizontal..
    Still got to knock up a bigger mini cuboid, while the rotary table is in place.
    Then i can mount it verticaly and finish these two with all the slots and grooves..mini shouldn't take long as the led hole is tiny in comparison.
  69. #69
    Goldigger, you must have some muscles in your arms.
    I used my rotary table(the same one you have) for the first real time yesterday and my arm never wants to rotate another thing. I thought it was due to it being new and would loosen with use but after the 20,000000th rotation it never got easier.
  70. #70
    Yetibetty
    I think you will find that Jay is spinning it with a battery drill .
    That is what I do Use a straight allen key in the wheel bolt on the RT
  71. #71
    Yetibetty
    That's almost CNC sounds good to me
  72. #72
    Yeti sounds like you need to adjust the grub screws on the bottom...if there adjusted wrong the table will be to tight when you turn the handle..
    Troutie your kinda right...I use a bosch 650watt, which i have to grip ther chuck so it doesnt spin to fast.
    But i only use it on the finishing passes....
    I turn it by hand when im ploughing out round holes...that driver hole is 17.5mm deep....thats some turns!
    I do have muscles in my arms...the gym 4 times a week
    This takes my fancy
    The Division Master CNC Indexer
    DivisionMaster - Home
  73. #73
    meep meep !!!
    Just bought a 4S LiPo balance cable on ebay, so when the h6flex arrives I will have everything on the shopping list.
    Except for for one thing, of course..............
  74. #74
    Quote Originally Posted by Road_Runner View Post
    I think that will change during next week mate
  75. #75
    Just checked the grubs screws and it was fine, just my lazy, feeble arms doing two 17mm deep holes on it's first use. I do have muscles now though that I never had before
  76. #76
    What is the OD and length of the finished light?
  77. #77
    Those measurements can be found at the start of this thread. I believe its 45mm and 70mm.
  78. #78
    Thanks, I missed those.
    Troutie, I like your design, mind if I use the idea to do something similar? I'm trying to figure out if I can make a similar shape work out of 50mm round bar. I am thinking three pieces, one which is the hood integrated into a front cover to seal the optic, a middle housing to house the triple optic with XML PCB and then driver at the rear, and then a rear cap. This way I should be able to machine each part in one operation off the bar in our small five axis lathe.
  79. #79
    Two more housings finally complete after cocking two bodies up!!
    These two got some slight changes for the best...sure you can see it from the pic.
    ebay seller sent me the wrong bolts, and was meant to replace them! Still haven't shown up, so ordered some more from a different seller..
    Negative feedback looming on the horizon.
    Road Runner and Russell your Housings are ready, just waiting on the silver bolts to turn up..
    Plus need to finsh Russells V2 mini tripple (cute) which is nearly done
  80. #80
    More grooves at the back and less at the front?
    Nice work. What cock ups did you do? we have all done them.... or will do them.
  81. #81
    meep meep !!!
    Oh goody, I think I can spot my own personal photon cannon housing in that picture.
    Those look flipping gorgeous mate, can't wait to fix it to the bike and get blasting.
  82. #82
    Yes more grooves to put the horizontal grooves in the middle of the heat sink part of the body..(the meat between the leds and driver)
    Reason being cock no 1 drilled the hole for the mount in the middle of the horizontal groove and fowled the flat surface for the driver
    Cock up no 2...snapped a tap in one of the holes
    I've read that alum in the correct temp water 134 will corrode a tap..and also a aluminium sauce pan
  83. #83
    meep meep !!!
    That must be some sort of groovy baby.
    And very cute as well.
  84. #84
    Mark 2 all wired up...and off to another home
  85. #85
    These look fantastic GD, I'm so excited that I can't get too sleep!! Really looking forward to testing this and the V2 mini tripple out in the week.
  86. #86
    nice work men! I read and learn about to make my light!
  87. #87
    Those turned out great!
    And what is that furry creature in the pics above (your audience) - are you keeping a mogwai?
  88. #88
    Thanks Huffy..
    The audience is Willow the house rabbit (french lop)
  89. #89
    meep meep !!!
    Collected my housing from the Post Office this morning and it is gorgeous, a true work of art and a thing of rare beauty indeed. Thanks for that Jay.
    Will have a go at assembling it tomorrow night, so keep watching this space for more updates.......
  90. #90
    Thanks RR
    Glad your happy with it
    Just one note, you'll need to file the square corners off the cutter tripple XM-L board..
  91. #91
    meep meep !!!
    OK, I did that. And I built the light. And it works!
    Just a few quick pics for you:
    Now to RTFM for the h6flex and find out how to set the light up exactly the way I want it to operate on my bike.
    But it works, and I'm just basking in the glow right now, in more ways than one, and feeling very happy with the whole thing.
  92. #92
    Glad its all working for you RR..
    Digging the oxo boxes...
  93. #93
    Made another but decided to polish this one, thought it looked rather bling
  94. #94
    Looks very sexy that Jay
    You need to polish and get it anodised sharpish
    Why
    I took some time to polish one of mine not quite as well as yours
    then lent it to my cousin in the dales after a month of cow and sheep **** which must be very corrosive it looks like its been dug up by the time team
  95. #95
    Why
    Thanks Chris,
    I keep thinking about getting an anodising kit and trying it myself.
    Gateros Plating, Zinc plating kits, Nickle plating kits, Chrome plating kits, Cleaning kits, Aluminium plating and all your plating supplies.
    When you anodise do you ano the surfaces that the lesd and driver sit on, or keep them bare?
  96. #96
    Shiny, me likey.......
  97. #97
    meep meep !!!
    Why
    My slightly less well polished example (sob, sob, sniffle) has been doing OK so far, but that might be because I usually avoid contact with cow and sheep poop wherever possible. Gritting and salting of the roads during winter is more likely to be an issue with my light so I'll need to either get it anodised, spray painted, or perhaps some other way of getting a protective coating over the naked aluminium to protect it from corrosion.
    I'm open to suggestions, please.
  98. #98
    Easiest way to polish is get some wire wool from home base, i use the fine grade..Then finish of with some autosol polish. It should only take 30mins tops..
    I'm seriously considering some home anodising, especially as a local bike shop has asked me to make him one of these as a demo light to keep in his shop, which will then hopefully generate some customers
    If i do go down the ano route, you can always send it to me and ill do it for you..
  99. #99
    I have had some acid for a while now just not got round to setting up the anodising yet
    had no problems getting battery acid from here ReAgent Chemical Suppliers : UK Chemical Suppliers, Buy Chemicals Online and not too pricey
    yes do it all far easier than trying to mask off bits
    and adhesives stick a whole lot better to anodise than bare ali .
  100. #100
    Have you got the full kit ready to do everything?
    I was thinking of getting this kit Gateros Plating, Zinc plating kits, Nickle plating kits, Chrome plating kits, Cleaning kits, Aluminium plating and all your plating supplies. also available on ebay.
    Just curious if there is a better way of buying all the parts?
    What are you using for a power supply, cathodes, tank?
    Cheers
    J
  1. What a cute couple
    By airwreck in forum Turner
    Last Post: 06-29-2008, 05:17 PM
  2. Kids are so cute at that age...
    By bry3 in forum Passion
    Last Post: 03-16-2007, 05:44 PM
  3. Aww, how cute!
    By pisgahproductions in forum Ellsworth
    Last Post: 03-23-2005, 06:41 PM
