Spanish biker
Very nice and simple. But with that 9V battery setup, isn't the runtime going to be really short?
I was trying to find the easiest way available to me to play around with these Luxeon V's on the bench top. Typical forward voltage for the Luxeon V's is 6.84 volts. Found that one 9 volt battery would power up one Luxeon V. Decided to wire two 9 volt batteries is series so that I could power up both Luxeon V's easily. Played around with this set-up for a while and just for fun I decided to see just how long I could power the two Luxeon V's with the two 9 volt batteries in series. I got over 3 hours of run time! I was very surprised. No cables, can give the light to anybody and they can find batteries for it, light weight. Can't think of any real negatives except for it is not waterproof.
- You may not post replies
- You may not edit your posts
Forum Rules
