Results 1 to 11 of 11
    Home of the Gravedigger
    Reputation: jkaber's Avatar
    Nov 2006
    Amoeba light in disguise
    This started out as a 1.0 Lumen Sigma Tri-Led that ran on 3 AAA batteries. Scar disected it and Amoeba-ized it. Now it runs on a 9V and is 250 times brighter! I was looking for a wireless solution to clamp on my pugsley for night riding and winter visibility. It has about 2.5 hours of run time. This paired with my Amoeba lights on my helmet light up the sky. Thanks Scar for the great work, it is a one of a kind.
    <a href="http://s427.photobucket.com/albums/pp356/jkaber/?action=view&current=004-6.jpg" target="_blank"><img src="http://i427.photobucket.com/albums/pp356/jkaber/004-6.jpg" border="0" alt="Photobucket"></a>
    <a href="http://s427.photobucket.com/albums/pp356/jkaber/?action=view&current=011-5.jpg" target="_blank"><img src="http://i427.photobucket.com/albums/pp356/jkaber/011-5.jpg" border="0" alt="Photobucket"></a>
    <a href="http://s427.photobucket.com/albums/pp356/jkaber/?action=view&current=003-5.jpg" target="_blank"><img src="http://i427.photobucket.com/albums/pp356/jkaber/003-5.jpg" border="0" alt="Photobucket"></a>
    Reputation: yetibetty's Avatar
    Great place to mount it, but do you get a shadow of the tire?
    Nov 2006
    It has the spot beam in it....so it does a pretty good job of getting the light past the tire.
    Lets RIDE!
    Reputation: Jim Z in VT's Avatar
    The low mount is sure going to show the trail texture nicely.
    Ummm....why is there a cog on your front wheel? AWD? :-)
    JZ
    It's not about speed, it's about lack of control.
    Rolling
    Reputation: lidarman's Avatar
    Quote Originally Posted by Jim Z in VT
    JZ
    That is the that funky pugsley setup. Somehow you can make it geared or SS with an exchange of the wheels right?
    Nov 2006
    JZ
    The Pugsley uses a rear hub on the front. The theory is that if the casette freezes up, I can swap wheels and ride out of the woods fixed gear style. I doubt that will ever happen to me, but it sure looks cool.
    Lets RIDE!
    Cool. OK, another question....what is the round horizontal object that your light is clamped to? It appears to be part of the fork?
    JZ
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Pauls Components mount
    They have also redone their stem mount - http://www.paulcomp.com/lightmounts.html
    cool placement
    BTW that is rigid fork can a shock able fork be mounting just like that?
    Reputation: aljee's Avatar
    is there a how to on how to do this with a light? i have been looking for a good light, but them shits cost $$$$$. thanks!
    Quote Originally Posted by 0600661160
    cool placement
    there has to be a braze-on if you are going to use that paul mount or similar. you can make a paul-style mount using a scrap piece of crap handle bar, two washers (outside edge big enough to cover the edges of the bar piece and small enough hole to for a 5mm bolt to hold it in place), and a longish 5mm bolt to hold it in place.
