7up board with driver built in
what do you guys think of this, http://www.cutter.com.au/proddetail.php?prod=cut990 ?
I am right in thinking all I will need to do is get an optic, battery, switch and heatsink/housing and I will have a 7up xpg light?
Yes, and yes.
 Originally Posted by sam2391
I got one of those boards and unfortunately cannot recomend it. Control on the dimming is iffy and the switch control points to solder are non existent little pin heads.
sorry for being not fully correct recommending my own products, but what if you try 2-3 L333 boards linked as master-slave? There's a very nice housing done by Matt for a dual-board setup:
http://www.candlepowerforums.com/vb/...d.php?t=258699
when two A-types are used it may provide up to 2400 OTF lumens.
L333 all configurations (more that 70 options available): http://www.lux-rc.com/view.php?p=con...ht_engines/3UP
Ok im interesed in this now! How much for a fully built kit to the UK? does it include a battery and charger? Thanks, Also how much is just a housing and switch etc?
sorry didnt realise you just made the light engines, will definatly look into this though
- You may not post replies
- You may not edit your posts
Forum Rules
