Results 1 to 27 of 27
Thread: 4 3 2
    4 3 2
    as you know I have the Quad and Triple .
    so now the Double
    Only the two pics I am afraid as now have an X camera the trusty 3 MP is dead
    after I knocked over the tripod in the woods
    specs so far is 1 Laura RS and 1 CXP RS
    H6flex
    and rough hewn housing just like its brothers .
    To sum it up so far the Quad is good but not great plenty of lumens but some thing is just not there for me could be the Reginas are lacking a little
    The Triple Cute is also good and IMHO better than the Quad but not as a helmet light much better on the bars so bar mount to be fitted soon .
    I went out this morning with the pooch in darkness with no street lighting with the Quad on the bars and the Double on the helmet what was immediately apparent was the strength of the double beam on level 3 compared to the Quad on max it easily made its mark and out threw the 4 Reginas .
    I have had this theory from the MCE days messing with the square ledils that if removed from their holders when using more than one they help each other out some how with the spare lumens ,( This could be total bollocks )
    Reputation: ortelius's Avatar
    Two switches?
    Quote Originally Posted by ortelius
    Two switches?
    Yes the back is going to have a couple of Red XPEs added when I get a small low powered driver . as I keep losing my back lights .
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    Chris, to out throw the 4 regina's she must be a bright little bugger. What leds to end up using and what amperage to beat the regina's?
    A waste of time it is is
    Reputation: emu26's Avatar
    will you fin it at all mate or do you think it'll cope with the heat the way it is?
    Quote Originally Posted by brad72
    XMLs @ 3 amps current table .
    Only on ride on this combination so more testing to do it did surprise me too
    the quad went so far down the tarmac but was on the bars might be the extra height and angle of the helmet light made it seem to go further .
    Quote Originally Posted by emu26
    Not bother for this one never even warmed up on max but then it was just off freezing
    they are all just for me to use and give me an idea what is needed for warmer climes
    got 1 XML left now so a single is next when the Lflex`s come out probably with the Rocket optic
    Reputation: Goldigger's Avatar
    Chris whats the x camera?
    I have a canon powershot a75 your welcome to..its only a 3.2mp..
    I can set everything bar the 6 seconds 6 SECONDS AT F4 - WHITE BALANCE - DAYLIGHT
    unless i missed something somewhere..
    all i ask is to cover postage if your interested.
    Quote Originally Posted by troutie-mtb
    so now the Double
    Doesn't look rough at all to me. Fin the heck out of it.
    I really don't think the finning is needed on these lumps of aluminum. Fins will/do help in warmer climates and/or slower riding speeds. Plus they just look really cool.
    I have a tiny 12v driver from a salvaged desk lamp LED bulb if you want it. No idea on drive current though, but the LED is a XP-E (I think - really large dome, metal ring around the bottom, tiny die).
    As for the escaped light from one optic going into another - sounds possible. If the light from one hits the other at a right angle, it should go in and then be reflected out the front. I wonder how that would compare with light leaving an optic then being reflected back off the holder into the optic, should be better I guess.
    Thanks for the offer Matt but had already ordered a 350 ma driver off ebay .
    came in today
    no worries Link to the driver? Is it a teapot? This has started me thinking about an all-in-one Hammond box rear light as I have a couple of XP-Es kicking around..
    Quote Originally Posted by mattthemuppet
    Yes a Teapot driver
    I got me a new camera today and had a play with the video on it waving about the double in the full beam of the Quad
    and also one of the red on the rear .
    Troutie, are you planning to make the Blair Witch sequel?
    Photos look... scary
    you know, I've seen that trail so often it's more familiar than my own backyard!
    Oops
    I think I may have got the beam shots a bit mixed up .
    OK so I built this double with one CXP and one Laura in the belief that the spottier optic was the CXP .
    rides great and has real punch .
    So decided to make my mate one with even better punch 2 CXPs took in out this morning and WTF it seemed a floody bugger
    So today Mark three was born and put two Laura`s in this one switched on and in the daylight it is very noticeably spottier than the other .
    so it seems I must have gotten a bit confused with which optic I was using at the beamshot time .
    more to follow after I have been thrashed with battery cables
    OK back again
    the beam on the left is 2 XMLs and Laura optic
    on the right is 2 XMLs and CXPs
    both on the same setting
    needless to say the CXPs will be getting replaced pretty soon .
    Sorry for any confusion caused
    Quote Originally Posted by odtexas
    The mark three version and Finnier than a very finned Fin from Finland
    Sorry it looks a bit like some of Yours Odtexas
    And mine look sort of like Emu's original triple.
    No worries.
    Only so many ways to skin a cat or fin extrusion.
    The mill does let you do alot more interesting stuff, and the rolled front edge really looks the biz.
    Had about two uninterupted hours this morning and did some table saw work.
    The inside is only 19mm square so only the Regina or Tina will fit in it.
    The outside edge was cut by setting the tablesaw blade at 45 degrees.
    Something to think about. I sort of like it for now.
    Hijack over.......
    ... and if we just ... Tell Laura I Love Her
    Bloody hell Tex you have been making chips
    can we have a video of you in action next time . Yes I think my stock is the same internal sizes as need to machine it out a little for the Ledil squares.
    OK just to confirm my cock up . pics at the new mtbr setting 4 seconds F4 WB Daylight
    2 CXPs @ 3 amps
    2 laura`s @ 3 amps
    1 of each @ 3 amps
    the Cxp is quite a bit floodier still not a bad light but I prefer the punch of the laura .
    though thank fully the combination is very nice
    That's a great looking light, Troutie. I've got some Lauras in hand I'm going to put into a 2-up build. What mount is that your using? Is it readily available?
    Quote Originally Posted by natac
    The mount is one of my own from the Mini Troutie light .did think about making one like Yetibetty`s flat pack mount .
    First ride on it this morning and very happy with the result long quite narrow beam
    with just enough spill for me I am pretty impressed .
    I was spotting rabbits at 200 metres easily .
    and that was only on level 3
    I have it set on TRIO mode so 1 / 3 / 5 even 1 is very usable
    on hi it ran for 1 hour at various speeds and did not dim down until 10 minutes into a forced walk due to a puncture 1 mile from home .
    levels 1 and 3 no sign of it even getting warm
    Laura Part number at cutters
    Trout,
    Amazing beam from Laura,
    Whats the part no of Laura from cutters??
    Cheers in advance
    Stu
    Quote Originally Posted by stu44
    Trout,
    Cheers in advance
    Stu
    I have not seen it on Cutters site yet I got mine from Farnells UK
    Some comparison shots with known lights
    Disclaimer I reverted back to the 6 Seconds as over the water it sucked up loads of light
    and the Bastid just did not show up @ 4 secs
    Which matters not as long as they were all at the same setting
    so first up the Bastid on high
    then the 7UP @ 1 amp
    the dual XML / Laura @ 3 amps
    and finally the Dual XML 1 Laura + 1 CXP
    Looks like Laura is the way to go in right angle design. Better spill and better throw.
    what's the spill and spread like on the Laura+CXP combo? I'm about to start on a twin XM-L bar light (to go with my twin XP-G + regina helmet light) and I'm aiming for a decent flood, particularly right in front of the bike. I can sacrifice some throw to get it as the twin XP-G helmet light throws fantastically.
    I currently have a regina, Boom SS and CXP-RS on order and I'm thinking about getting a Laura RS too. Any suggestions?
