25K+ Lumens helmet mounted light (100W led bike light)
My first post here - I joined up to share my latest project.
Essentially, It is a 100W / 7000Lm street light chip sitting behind a projector lens.
The head unit only weighs 300grams - this compares favourably with the 250grams the 2x Magicshine P7 lamps I used to run on my my helmet.
The heatsink is a pure copper northbridge unit with a 50mm 16CFM fan mounted behind.
Batteries are 12x 2.9AH Panasonic 18650s in series - ie 44V nominal.
I normally run this light @ 120W, using a continuously variable pulsewidth control. I have an instant 'boost' button that pulls the MOSFETS high and provides upto 400W for 20second bursts.
Battery lasts approx 45mins+ @ 120W continuous and 20second 'boost' every 5 mins, before the low volts data loggers trigger a 3V cell alarm (all 12 cells are independently logged and alarmed).
Last night:
I just took the monster bike light out in the park.
Attached are the 2x data logs (1 log per 6 cells – 12x 3AH li-ion cells in total).
The blue trace on top is the total 6cell pack voltage.
There are a couple of weak cells to keep an eye on – I have a few spare cells to swap out if needed.
Other stats for that short bike ride:
Peak power = 403W
Peak current = 9.56A
Total WHr = 39.8
Total AH = 0.91
V min = 39.8
V fin (no load) = 45.6V
Recharge back to 4.2V per cell = 1.05AH
Note, I used 150W – 200W in the main, except for a few sections where I turned it down to 30W due to high reflected light of close objects -ie where the track weaves between bushes.
Ave pwr approx 160W continuous – averaged over the 15mins. Batts approx 1/3rd discharged.
The short bursts of low volts = the high load from burst of direct drive – ie MOSFETS fully on instead of the normal pulse width control. The direct drive is typically 350W (can be 400W on fresh charge) but generates a LOT of heat (LEDS are only approx 10% efficient) and can only run it for 20 secs at a time.
I also reduced drive to 100W during the slow uphill 1st gear slog back home . Yes, I can really feel the heat through the bike helmet when going slow , at the higher power levels.
BTW, I am using 2x JUNSI CELL LOG 8S units – tiny – smaller than a match box and back lit – amazing units.
And I am also using a GT POWER RC 130A power meter – measures power directly, records peaks, min V etc – also back lit for night – saves carrying 2x multimeters !
Bottom line:
• For 1/3rd of the ride, 5-30W is more than enough
• for most of the rest of the ride - 100-200W is the go
• for the fast down hill - use full power - 250W-400W - too much light is never enough for these sections.
Ihave a plan for feedback based automatic light control (eg use a cheap B&W security pinhole camera or simple focussed LDR).
BTW2 - My commercial 10W Magicshine led bike lights look distinctly feeble now.
The lesser beam shot is a Magicshine P7. The distant hedge is 65m away from the light.
Yes, this light is not a thrower - but is I do not ride fast enough for this to be an issue.
Reason: my mates could not find this !
BTW, this light is heaps of fun to ride with - big grins all round. I have the battery box zip-tied to the top of the bars sitting on top of a thick foam pad. The control pod (will be much smaller soon) sits on the bars with the red boost button next to my left thumb.
The fan runs quiet (approx 10V ave) @ 120W, but roars it's tits of (Ozzie expression) @ 350W+. This chip will run @ 300W all night with the slightly bigger (but 200grams heavier) heat sink I have.
Another design I considered was to use a CPU water cooler block (eg the complete Corsair kit) that would be light on the helmet and allow 300W+ continuous power (would also need 2x 5AH 6cell RC lipo packs).
Data log traces for pack A and pack B (6x li-ion cells each). The blue trace is the total pack voltage. Note the V dips when 'boost' is applied. You can see the effect of the varied load on the batteries when I adjusted the power up and down to suit track conditions.
BTW - the creek crossing (some times treacherous - I have gone over the bars here...) is a total breeze now - I can now clearly see to the bottom of the creek - I couldn't do this with the 2x Magicshine P7s.
I have ridden in light rain and the fan survived. The led just burns any moisture off as it typically runs at 65deg C, and 95degC after 20secs of direct drive.
I plan to place the battery and loggers in a lunch box with clear top.
The light reflects of the falling rain something fierce though.
trailguy1: WT# is that?
trailguy2: Looks like a plane, but it is flying pretty low?
trailguy1: Or a guy with a streetlamp on his head... or a UFO
trailguy2: Are you nuts, nobody is that crazy. Did you bring the camera?
I think I'd pack a fire extinguisher if I was using that light - good job! Thanks for posting pics too.
I was going to use the 300W chip but it is 4x more expensive. The 100W chip seems happy enough @ 200W continuous and 400W for short bursts - and is the same physical size (same chip?) as the 300W version.
The chip is a 10x10 array - ie 100x 1W leds. Due the the large chip size, I do not think it is possible to focus this light any tighter with a small diameter lens.
But, I LOVE the beam spread. Previously, I could hear the creek running parallel to the trail but not see it unless I turned my head (and then I could not see the trail...), now, the whole park is lit up. I have another, larger 65mm lens that has an even wider beam that I prefer, but I have to resolve some packaging issues.
The LED is 10x10 - ie 10 LEDS in series = 10 x 3V = 30V approx needed to drive 100W.
I chose to use a high volt source (12x li-ion cells = 44V nom.) pulse width controlled. This drive arrangement is approx 99% efficient @ 300W due to the tiny on resistance of the series MOSFETS. The fan uses approx 1%.
I could have used lower volts and some kind of buck-boost cct, but have you seen just how big a 300W ferrite core is !! and there would be plenty of heat issues due to the 80-85% efficiency of the driver. So, I recommend using 12x top quality li-ions (I used panny 18650s - but they get up to 50deg C. I would recommend using 2x RC 6cell li-po packs for warmer climates - and would get much more power on direct drive 'boost'.
Li-Fe have too lower cell voltage - would need more cells, and their power density is much lower. The Panasonic 2.9AH 18650 Li-ions have the best power density currently available. When these wear out, I will replace them with the new 18650 cells Panny promises will have 40% greater power density - out next year.
If waterproofing is a priority, consider using a water cooling head instead of a heatsink and fan, and then seal the whole light head up.
BTW1 - I use a non-contact infrared temp gauge for testing
BTW2 - @ 100W, the led is 10% efficient, thus 90W of heat is generated, haf of this radiates out the front, and half (eg only 45W) is dissipated by the heatsink and fan. A modern CPU fan is waaay too big (and heavy) - I tried this.
BTW3 - the led in the beam shot is a 3500Kelvin (a bit yellow but ok on 'boost') and the led next to the ruler is 6500kelvin (OK @ 100W, a bit blue @ higher powers). I recommend the 5000kelvin led for all round use. The 3500 kelvin led has much more yellow phosphor than the 6500K one. When over driven, the blue elements (white leds are blue +phosphor) dominate the yellow phosphor and the colour shifts up a bit.
The beam shots are in my back yard. We love this area - only one block from the National park (where I ride @ night).
I watched a big Koala slowly walk down my drive yesterday. The Koalas have a very loud bellowing grunting sound - a mating call, I believe, that was quite disturbing when we first moved here. Lots of late night bangs and crashes as the Koalas and Possums (can see possums every second night) climb the gate, and drop down on the tool shed roof.
I will try and post a pic of a Koala using this new light.
I was going to guess you’re Australian. Why? Well, in the world of overkill, Australians seem to be more passionate about taking things one step further—I’ve seen this with high-horsepower car hobbyists many times before. Cheers to you for an overkill job done right!
Overkill - yes and no, once you have seen this light, you will never want to go back !
Truth is, 5-30W is enough for the tight sections in the park and on the street, but when the going is faster and open, 100-200W is good to have. And for the fast loose downhill between the trees - full power ! This is the only light I have that clearly shows the bottom of the creek.
Fairly cheap to build too - ie much less than $300 USD. I was going to buy a Lupine-Betty but the price is absurd for what you get.
I am finding myself adjusting the power up and down a lot - I may fit a hi-low range switch in the short term (eg low for traffic). I am thinking of building an adaptive (feedback) light control driven of the reflected light. Am thinking about this. Problem is, I have parts coming for a torch project, and have parts left over for a second monster torch - just have to order some RC lipos.
Dude, Pepster, you killed my ideas for building up another brighter-than-necessary light!!! I feel as though I shot my wad too soon! Now I need to research what Li-Po battery packs are available out there that can deliver 10A+ of current for prolonged periods of time, and from there figure out if I want to venture in your LUMEN HELL territory.
The only real roadblock for so many watts of heat of course is in the design of the heatsink; perhaps someone should just design a finned aluminum bike frame around the heat-spreading surface for a particular high-power LED module?
Funny you shoudl say that, my next idea is to use the handlebar as a heatsink to build a truely small unit I'll leave on permanently.
The copper northbridge heatsink I use is fine for about 170W continuous and the led stays under 75deg C stationary inside @ 21deg C ambient. When moving, the led runs much cooler and 200W continous seems ok with this lightweight heatsink.
@200W, assume 10% efficiency, 180W of heat is generated, half transmitted out the front, and and about half, eg 90W needs to be dissipated in the heatsink.
Modern CPU coolers do 400W easily...
So, heat is not so bad. (I was paranoid about this to start with). To do this properly I should have a thermo controlled fan and thermo controlled light power reduction... maybey one day. I am just stocked that this thing worked so well - waaaay above expectations.
Some earlier development photos. I started with a dolphin torch head. Then move the a 65mm lens and a copper cored CPU cooler. Note the wider beam spread of the 65mm - and only running 165W back then.
That is an impressive amount of light. The price is certainly right. It seems like to down side is a very wide beam. By varying the distance from the LED to the lens can the beam be tightened up any or is what you have shown in the photos about as good as it gets?
No, this is about as tight as it gets using that 45mm lens due to the large size (20x20mm) chip. You could play around with different lenses.
I personally prefer the wider beam of the wider beam of my other 65mm lens. I tryed moding the lense around, but I only succeeded in sharply focussing all 100 led elements in a 10x10 grid of bright points of light - ie out of focus is good.
Trust me - a wide light like this is an entirely different (vastly better) riding experience - your periphial vision is filled with light - it is kind of riding during the day. After 1/2hr of riding like this, a regular light (eg MS P7) looks like riding down a tunnel, and you will find that you cannot switch the wide light back on fast enough.
These leds are $30 now ! BTW, I built my own PWM cct for about $40 AUD and it only uses 15mA.
To each his own. IMO part of the fun of night riding is the darkness in my peripheral vision. A sense of mystery? I can't really say for sure.
I run a dual XP-G helmet light (27 grams on the helmet) and and most recently a dual MC-E on the bars. More than enough light for me with that combo. I can ride as fast with that setup as I can in daylight (OK, I am old and slow ).
IMO this is the beauty of the DIY light world. All of us here have our own idea of what is best for our use and we make what fufills those wishes.
