Results 1 to 6 of 6
    my dog's Frisbee launcher
    Reputation: befoot's Avatar
    Mar 2006
    18volt to 14volt step down?
    Hi guys, I have an old 12volt Night Sun and I'm build a 14volt LED light.(Achesalot's - fantastic light)
    the thing is I work construction and I have lots of 18 Volt batteries and chargers on hand. So I was wondering if I can step down a 18volt battery to 14volts or should I just cough up the cash for new 14volt batteries and a charger? If this can be done...tips or links anyone?
    BTW...I was planing on Overvolting the 12 volt Night Sun at 14 volts
    thanks, Billy
    Darwin was an Optimist
    ...a wiggle theres a way
    Reputation: wiggy's Avatar
    There are a few ways you can do this
    you could get a step down transformer that would take 18in and put ~14volts out
    you could also do it with a pot
    or you could simply use resistors and make it drop that way just make sure that you get the proper wattage depending on how many amps your application is going to be drawing that way you don't burn them(resistors) out
    They do have voltage regulators but to my knowledge they do not have any 14vdc ones (if i am incorrect someone let me know) they have 5vd, 12vdc, and a handful of others
    if it was me i would go the transformer route if your settled on using an 18volt pack other wise just get a 14volt one because it maybe easier than having to fabricate a board
    good luck
    joe
    Oct 2007
    A buck converter like the bflex from Taskled.com will do the job perfectly and give you a whole rack of functions to the light. Most importantly it will regulate the current to the led's ensuring a consistant brightness (you set the level), it will also allow multiple brightness levels, temperature regulation, strobe + much more
    Hope this helps
    Ian
    Nov 2006
    Sorry, my old response did not make sense!
    Use a buck converter!
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Driver?
    Quote Originally Posted by befoot
    thanks, Billy
    If you use the Buck Puck DC-DC voltage converter, it will take up to 32V and give you the correct output amps and voltage:
    http://www.ledsupply.com/buckpuck.ph...FQNisgodPx1pNA
    The bFlex takes up to 20 V input:
    http://www.taskled.com/bflex.html
    Deal Extreme offers a cheap driver, but I think the input is limited to about 6 volts:
    http://www.dealextreme.com/details.dx/sku.7612
    Sandwich Shoppe's offerings won't take input above 12 V:
    http://theledguy.chainreactionweb.co...roducts_id=394
    A driver is the way to go for LEDs because they are difficult to run well using a resistor. The current draw of an LED changes sharply with very small voltage changes. Plus putting a resistor in line with the LED wastes some of the battery energy.
    Note that Sandwich Shoppe, LEDSupply, and TaskLED offer boost converters too. That would make a 12V battery run a 14 volt string of LEDs. But boost converters are more delicate and may require heat sinking. Or they may not offer enough power output. Maybe not impossible, but more difficult.
    Walt
    Mar 2006
    Quote Originally Posted by iggs
    Hope this helps
    Ian
    In the LED system, I'm using a BuckPuck "3023-D-N-1000 Wired, 1000mA Output, DC Powered" from ledsupply.com
    so looks like I'm good go to go.
    Walt...thanks for all the info and links big help.
    I think I will just retire the 12volt Night Sun
    and make a 2nd LED light for the bars
    more light and longer run times.
    thanks...you guys just save me a bunch of cash on batteries
