Results 1 to 9 of 9
    Code Burr
    Reputation: thebronze's Avatar
    12v LED tail light project
    Hey guys, what are my options for a 12v solution for an old motorcycle? LED's look ideal since the vibrations wont kill the filament like a normal bulb. Is there a step down converter or driver to knock the 12 down to 7 or 3.4?
    May 2005
    ebay.
    Search led taillight bulb
    Figure out what socket you have and you'll likely find a match.
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    I run my trunk lights off of 12V's
    Code Burr
    Scar, what are you using to step down the 12v current?
    Vancbiker, I'll take a look at those but i'd rather fab something up.
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Quote Originally Posted by thebronze
    Taskled makes a really sweet driver that is perfect for just such an application:
    http://www.taskled.com/ccxw.html
    Light freak
    Jun 2005
    Yep, using the TaskLED CC5W set up for 700ma output
    Code Burr
    What would you guys think about using one of these for a rear light and another for a brake light? I'd ditch the spring and the reflector. They look like they can handle 12v pretty easily. I have no idea how bright they are.
    http://www.dealextreme.com/details.dx/sku.11836
    I'm guessing you'll want a 180 degree diffuser for it to possibly work. otherwise you'll probably have pink hotspots in your red plastic light cover.
    maybe look into this led + diffuser as well..
    http://www.dealextreme.com/details.dx/sku.1776
    Reputation: BrianMc's Avatar
    I built a pair of nominal 12 volt tailights that are about 100 lumens each and are slightly brighter than my cars LED tailights. They are a moderate spot and I aim them out at about 15 degrees to get a bit more rear angle coverage to each side, while still overlapping the beams straight back.
    A bit more info here.
    These bulbs modded:
    http://www.dealextreme.com/details.dx/sku.5325
    Newer style Marwi in paired set :$20 plus shipping.
    http://www.hoffmanamps.com/MyStore/catalog/partsled.htm
    Of course you could make an array of more of them if you wish.
