Results 1 to 9 of 9
Thread: 1.5 amp drivers
    1.5 amp drivers
    I know there was a thread on the XPG's rated to 1.5 amps, but are there any drivers that can output 1.5 amps?
    Some cheapo drivers on Kaidomain and Dealextreme around that current. 1.3 and 1.5 amp drivers.
    Hipflex can be set to 1400 mA
    2 buck pucks wired parallel could get you 1.5 A.
    Shark buck is adjustable on the driver and could be set for 1.5 A.
    Hoffmanamps.com has 3.7v drivers rated at 1.4...if you don't want to wait for DX or Kaidomain...and they're only 17mm diameter.
    A waste of time it is is
    Reputation: emu26's Avatar
    a couple of other choices here
    This one is of Chinese origin, I guess it can be found on Kaidomain for cheaper
    Just needs George to chip in and say the next Bflexs will be 1.5 amp output to cause a stir
    Quote Originally Posted by zemike
    Perhaps you can give us the link.
