Results 1 to 2 of 2
Thread: Spring rate?
    New question here. Spring rate?
    I have a 2004 Stinky Dee-Lux 18" that came with a 550lbs spring on the Vanilla RC. I notice that when I stand and pedal in lower gears, the rear seems to bob. When in higher gears this is no a problem. I'm wondering if I should go to a higher spring rate? I weigh around 180lbs.
    roots, rocks, rhythm
    Reputation: Dawgprimo's Avatar
    Should try the shock thread......for more info
    Couple of things.
    Could have the Vanilla RC Pushed. (Push Industries)
    (I was impressed when I had it done to mine.)
    Also a general rule is to achieve a 25% sag when you are just sitting on the bike.
  1. Mountain Bike Spring Rate Calculator V5.0
    By FireDog46 in forum Shocks and Suspension
    Last Post: 07-16-2013, 08:46 PM
  2. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  3. Progressive setting & spring rate
    By Stinky Wiz in forum Kona
    Last Post: 12-17-2004, 11:00 PM
  4. Z150 vs. Z150
    By SamL3227 in forum Downhill - Freeride
    Last Post: 09-02-2004, 06:52 AM
  5. Heckler- What spring rate is right for me?
    By fasteddy001 in forum Santa Cruz
    Last Post: 03-31-2004, 08:46 AM
