Results 1 to 3 of 3
Thread: Seat Tube?
    Reputation: jideay's Avatar
    Jul 2016
    Seat Tube?
    About half way down my seat tube there's an obstruction that prevents me from dropping my post all the way down. It looks like a pipe joint? Is this by design? 2011 Hei Hei 29 SE
    Reputation: watts888's Avatar
    Oct 2012
    How far down is it compared to the shock pivot?
    Could be a protective sleeve to keep a user from putting a seat tube too close to the shock pivot. Alternative possibility is someone used a seatpost shim in the frame, accidentally lost it down the seat tube, and it's stuck by the pivot area.
    "a hundred travel books isn't worth one real trip"
    Jul 2016
    It is just below the shock mount, where the bottom weld is (see image below, finger point). I'm guessing it's an added tube to give more strength to the bottom bracket? I'm trying to figure out what size Fox Transfer Dropper to buy, 150mm or 125mm (external). By using Fox's calculations, I am shy by 4mm for the 150... Thanks for your help.
  1. Seat post min insertion into a frame with seat tube brace question
    By Strife21 in forum Bike and Frame discussion
    Last Post: 07-24-2015, 10:36 AM
  2. Replies: 11
    Last Post: 04-29-2014, 09:14 AM
  3. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 11:12 AM
  4. Replies: 10
    Last Post: 02-22-2012, 11:02 PM
  5. Giant Reign 2010 Seat Tube Seat Post
    By cjsett in forum All Mountain
    Last Post: 01-16-2011, 07:07 AM
