Results 1 to 22 of 22
    Mar 2005
    New question here. Questions about the Stinky
    ok.... i have a few questions about the stinky.... will a 5th element shock fit on it? what other shocks can u put on it?? i am 5'6 and looking into a stinky what size would u think would fit??? i will be buying a frame sooo i dont know about the sizes...would you think a 17??
    thanks alot
    Reputation: shiggy's Avatar
    Dec 1998
    You need to look at the geometry charts:
    The '05 Stinky has been revised so the 17" is the XXL.
    The 17" '04 Stinky is a M.
    If you go by the S, M, L, XL, XXL sizing the top tube lengths are basically the same from '04 to '05.
    Are you buying a used frame? Kona is not offering a Stinky frameset.
    mtbtires.com
    Mar 2005
    Quote Originally Posted by shiggy
    used prob a 03 or and 04
    Dec 1998
    http://kona.dk can fill you in on older Konas.
    mtbtires.com
    Reputation: ilikebeer's Avatar
    You can buy new 04 stinky frames from wheelworld.com for like 700. they've got the deluxe and primo too. Ive never gone through them for any parts, so I don't know their reputation though.
    Mar 2005
    im 5'10", 200lbs and i just ordered the 05 small stinky (15" frame)
    Reputation: odinnn's Avatar
    Sep 2004
    Quote Originally Posted by cobra
    I am 5'7", 160lbs and I am thinking of ordering a medium frame but the diffrence of a small frame vs. a medium is so small that I think that they would both fit me, but since I am used to riding rather big frames I think it will be ok.
    ps. I cant wait to get my bike, I have been riding on the same bike since I was 13 (now almost 20) and it is a non suspension bike and it is all fked up.
    Dec 1998
    Quote Originally Posted by odinnn
    The medium's TT is nearly an inch long than the small. That can make a big difference in fit.
    mtbtires.com
    Sep 2004
    I was battling my self about wheter I should get the medium or the large and picked the medium and now you are telling me this demn it is hard to decide on a frame size when you cant testride, I realy need to think this through again...
    edit: 1 inch is 2.54cm witch is realy short, my pinky nail is not even that long, Shiggy do you realy think it could make diffrence?
    Mar 2005
    I havnt seen the small size frame yet but i did sit on the medium. When i stood over it, she was in my crotch and it just didnt feel to good. I decided to take a gamble and order mine in a size small. I think the only difference is the spring rates. The medium is a 500lbs per inch and the small is 450lbs per inch. Im 200lbs so if i need a higher spring rate i will order one later.
    I cant wait for my bike either. Im going from a crappy $200 CCM Canadian tire bike to a 05 stinky.
    Dec 1998
    You must have REALLY big hands or REALLY long nails. My pinky nail is 10mm long.
    Yes, 1 inch can make a huge difference in the fit and ride of a bike. If it did not Kona would not bother to make the Stinky in five sizes. There is a 0.9" (22 mm) difference between the small and medium. The TT gets a half-inch longer (13 mm) with each size after that.
    Would you just randomly pick between a 90 mm and 110 mm stem?
    Icelander! I was in Iceland in '98 for a horse trek. I loved it there. Want to go back.
    mtbtires.com
    Dec 1998
    The frames are most definitely different sizes. The small is 1" shorter in the TT and has just 0.2" (two tenths of one inch / 5 mm) lower standover. Long travel bikes just do not have much standover clearance. IMO the small is WAY too small for you. The large may be a better choice.
    mtbtires.com
    Sep 2004
    You must have REALLY big hands or REALLY long nails. My pinky nail is 10mm long..
    I was making it up about the nails, was just trying to make a point
    Why did you have to bring this up? now I cant stop thinking if I should get the medium or not but from the middle of my hip to the front of my knee is 19,6 inches (50cm) so if I get the small my knees would be close to the bar.
    Isn't shorter stem a better stem in freeriding?
    It is good to know that you like Iceland but it sucks to be a biker here, biking is rather new here and we are few that want to want to race. They race few hardtrail races in the sommer but until now there has only been like 1 or maybe 2 dh races with 10 racersor something. But this sommer there are planed 3 dh races and me and my friend are both going to get Stinky's (hes gonna get the Supreme) and hopefully we will get permision to build some trails in the ski area here in Akureyri.
    Also Iceland is very expencive, the Stinky ($1900) will cost for me imported $2988 I mean thats just stupid.
    You will probably need a 550 or 600 lb spring. Im 200lbs and ride a 600 on my stinky, though my big is set up pretty stiff for freeriding. My bike is an 04, but it has seven inches front and back, with a 2:7 stroke to travel ratio.
    Mar 2005
    Well i hope i made the right decision on getting the small cause its too late to change now.So you guys think a 550# or 600# spring would benefit me over the 450#? I weigh right around 200lbs.
    That depends on your riding style. If you do mostly downhill, you might want something softer that allows you to go through the entire travel more often. Mine (600lb) is set up to have optimum performance on drops, with higher spead damping suffering a little. Also, I don't have the dhx, I ran mine on a Vanilla r and a fifth element.
    Mar 2005
    well i got her
    well here it is, a brand new stock 05 small frame stinky. only test rode her on the street, i love it so far. cant wait to take it in the bush.
    Sep 2004
    demn this bike is so hot, the wait for my bike is unbearable, and I am only waiting for one shirt to complete my order
    so how does the rear susp. feel? soft?
    what about the fork are you thinking of upgrading?
    Mar 2005
    well i havnt played with it to much yet, i set my rear shock at 125psi, cranked the tension on the spring (its a 450#) for some reason i cant get air to stay in the front forks? i think im using my fork pump wrong. i probably wont upgrade anything until something brakes or until something bugs me.
    Sep 2004
    Ok, I have been sitting here and whatched your bike for about 20 min, cant stop looking at it, so nice.
    Its all stock right?
    Would you recommend buying a shock pump to adjust the fork and the rear shock?
    I am inlove with the disc brakes
    Dec 1998
    ...Would you recommend buying a shock pump to adjust the fork and the rear shock?...
    Yes, you should own a shock pump. I have two: a low pressure pump for my Marzocchi forks and a high pressure pump for the Fox shock.
    mtbtires.com
    Mar 2005
    yea 2 pumps
    yea im new to this whole thing but shiggys right, my pump is 0-400psi, try to use that guage to adjust a few psi, it aint happening.
    yea i love my bike. my buddy is picking up the same one but a medium frame. i dont think you can you wrong with the medium either. My knees are kind of close to the handle bars where my seat is adjusted to on the pic above. i raised the seat a bit and slid the seat back an inch or so towards the rear tire.
    heres my shock pump, $40 canadian
  1. two simple questions, help please
    By antonovc in forum General Discussion
    Last Post: 08-16-2004, 04:35 AM
  2. future 5 spot owners stupid questions
    By newton in forum Turner
    Last Post: 05-12-2004, 02:11 PM
  3. buffalo creek questions
    By billybobzia in forum Colorado - Front Range
    Last Post: 03-22-2004, 01:42 PM
