Results 1 to 5 of 5
    Process 180 fork?
    So I'm getting a kona process frame and I have a fox talas 180 left from a prior bike. I wanna avoid spending the extra on a 160. Anyone know if a 180 is doable with a process...more importantly, is it still a fun ride?
    Reputation: formu1fan's Avatar
    It seems like it should work. Maybe sending Kona an email would get a good answer.
    Where did you get the frame? I think this is going to be my next bike, but I wanted to get a frame only so I could build it the way I want, but I can't find it as a frame only option.
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Kona will tell you its going to void the warranty, running anything outside the travel range they use voids the warrantly.
    With that in mind, I would look into ways to shorten the travel of your current fork. That may included, but not necessarily be limited too, converting it to a Float instead of the current Talas. Since the float 180 travel can be shortened to anything you want that is under 180mm.
    Good luck
    #THELEGEND
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    Gonna be getting it as a warranty replacement...had a 2011 xxl coilair which has broken twice. Kona has been awesome about the warranty thing...first time got me a replacement coilair, but this time said no xxl coilairs left.
    Does the axle to crown distance shorten when a float is reduced from 180 to 160?
  1. Kona Process, Anyone have it yet?
    By Buggyr333 in forum Kona
    Last Post: 07-29-2013, 02:29 PM
  2. Kona process
    By EmbraceTheHate in forum All Mountain
    Last Post: 03-15-2013, 06:38 PM
  3. Nicolai The ION 18 Process
    By Karve in forum Nicolai
    Last Post: 12-06-2012, 02:35 PM
  4. Cadabra/Process
    By tedmasta in forum Kona
    Last Post: 11-16-2012, 01:00 PM
  5. ALM Process
    By Yogii in forum Frame Building
    Last Post: 04-27-2011, 08:07 PM
