Results 1 to 7 of 7
    Reputation: a a r o n's Avatar
    Need some help from a 2013-15 Unit owner
    Hey guys.... I've searched and can't come up with anything definitive. Can anybody with one of the latest version units do some measuring for me?
    I need to see the rear tire clearance, at the narrowest point... Preferably in mm and if possible, a visual of where on the triangle it is.
    Thanks in advance!
    Reputation: OFFcourse's Avatar
    Quote Originally Posted by a a r o n View Post
    Thanks in advance!
    I'll try to get you some photos today, trying to work out how wider rim I can run for mine ATM
    Awesome.... that's exactly what I need to know.... before I go buying a frame online.
    All measurements are taken with dropouts slammed for shortest CS.
    Maxxis Ardent 2.25 (tube @ 25psi) on WTB ST i23 TCS Rim (internal is 23mm, external is 27-28mm)
    Chainstay gap 69-70mm, not going to change as the sliders move back either this would be the first spot you will run into clearance issues on wider rims bigger rubber.
    Runs from 8mm-10+mm
    Not sweating the height at the BB or seat stay bridge
    About 6mm clearance on driveside
    About 8mm on non-driveside
    Wheel/frame is slightly out but 14mm total, 7mm each side.
    I have been looking at the light-bicycle 30mm carbon rims but the internal width is only 24mm +1 on these ones. Next jump is to the 35mm wide internal is 30mm on these so that would be better but I don't know how much this will increase the casing by for clearance.
    I would think I'd still have 3mm clearance on each side with the 35mm rims. But I dunno if its worth going that much as I wouldn't be able to run more than a 2.3 in the rear anyway. Hohumm what to do
    Yeah, I'm realizing pretty much everything you are. I think I'm going to end up with a 30mm internal width rear rim (velocity blunt 35), and a stans hugo rim up front. 2.4 ish rear tire and 3.25 up front. Thanks a bunch for the pictures. If I remember seeing correctly on the 27.5+ thread, the wtb trailblazer on a 35mm rim came in around 68mm....probably cutting it too close for the rear.
    Yeah I think to make use of a 35mm rim in the rear you would want to run something big to make use of it.
    Sounds like we are putting together similar bikes. I can't really decide between a Nextie 29" rear/Nextie fat front either a 50mm 27.5+ rim or a 26" fat 65mm rim. Tho I may just get a 29f/29r and grab a fat front wheel/fork in the new year. I have a fat fork/wheel I can put on to play around on to see if its suitable first. Was looking at the hugo+/arch but I really want to go carbon.
    Everybody around here mostly rides FSers or long travel HT's so need the extra cush if I'm gonna be rigid.
    I've spent two years on a fatty but it doesn't snow where I am and I've just moved so heaps less beach riding.
  1. 2013 Kona Unit
    By El Train in forum Singlespeed
    Last Post: 4 Days Ago, 08:47 PM
  2. 2013 Kona Unit or 2014 Kona Unit
    By evosil98 in forum Singlespeed
    Last Post: 2 Weeks Ago, 10:06 AM
  3. Replies: 4
    Last Post: 06-20-2014, 05:59 AM
  4. Happy new 2013 Trek Cobia owner
    By joewat64 in forum Trek
    Last Post: 06-02-2013, 05:12 PM
  5. New Kona Unit owner
    By Dictatorsaurus in forum Kona
    Last Post: 01-30-2012, 12:13 PM
