Results 1 to 5 of 5
    electric T
    Mar 2005
    My 05' Stinky chain slap is driving.....
    Me crazy. I just got the bike, so the chain probably needs to be tightened, or removed a link, but still, the chain slap is out of control. Any suggestions? Otherwise, "THE BIKE IS SICK!" Later, Justin Tee
    Ninja Please
    Lizard Skins or an old tube zip tied on.
    Reputation: shiggy's Avatar
    Dec 1998
    Or an old tire-
    mtbtires.com
    Quote Originally Posted by jamie
    No need to use ugly zipties !
    I opened up the rear triangle and put an old tube over the chainstay , folded so it doubled up.
    It a 5min job to remove pivot bolts and hanger (and rearwheel offcourse) put the tube on and put it back together , looks loads cleaner than zipties.
    Cheers
    A Chain guide will shut the noise up considerably,a DRS if you run a front derail,SRS if single chainring,this provides a pivot point for the chain right below the closest spot in the swingarm,without a guide the chain pivots up at the chainring and comes up and slaps the swingarm.Try simulating the roller of a chainguide with your finger and you'll see what I mean.
    Also switch to s r a m derailluer in the rear,they control the chainslap better because the body will only rotate up so far then it hits a internal stop.
  1. 04 stinky vs 05 stinky
    By Tallboy350 in forum Kona
    Last Post: 03-12-2005, 02:35 PM
  2. Replies: 8
    Last Post: 02-14-2005, 03:46 PM
  3. Replies: 0
    Last Post: 01-04-2005, 02:17 PM
  4. Singlespeed chain slap
    By SpinWheelz in forum Singlespeed
    Last Post: 01-03-2005, 04:38 PM
  5. XO chain slap
    By Johnny Hair Boy in forum SRAM
    Last Post: 07-14-2004, 11:55 AM
