Results 1 to 11 of 11
    Jun 2005
    Marzocchi Drop-Off Shocks (Kona Coiler)
    I just bought a Kona Coiler, and am wondering what the proper psi is for each shock leg on the front Marzocchi Drop-off fork. I read the online manual and came up with 30-40 psi right leg, and 0-15 psi left. However, I tried this and the shocks was waaayyy too hard, much harder than the factory setting. I've messed around with the it and i just can't get the shock to feel right. It may be that i'm using a manitou shock gauge/pump to inflate the shocks, istead of a marzocchi pump. Anyways, could anyone tell me what the proper psi for each leg shoudl be? I way about 130 lbs.
    Thanks Much,
    Mike
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Quote Originally Posted by boardinboy101
    Thanks Much,
    Mike
    There's the recommended setting... then there's you personal preference, try an in-between
    Jun 2005
    Quote Originally Posted by snaky69
    Thanks for the reply.
    Yes, well i've tried to figure that out, I just think it would be helpful to know some other peoples psi settings with the kona coiler's front shock.
    Reputation: shiggy's Avatar
    Dec 1998
    You do not need to know the pressure. Just use what gives you the proper sag. Kona recommends 38 mm / 1.5" of sag for your fork.
    mtbtires.com
    Reputation: rjohnston's Avatar
    My settings...
    I have the same bike as you and I weigh 200 lbs. My settings are 40 psi right leg, 0 psi left.
    Also, when the fork is new it'll be a little stiff. The more you ride it, the smoother it will get.
    RJ
    i heart singletrack
    Reputation: mgersib's Avatar
    At 130 lbs, you might not need any pressure.
    The fork has coil springs in it -- the air pressure simply suppliments the springs for heavier riders. I have a Marz. 66 VF, which has similar internals, and am running zero psi. in both legs to get the right amount of sag, and I'm 160lbs. At 130lbs, you may even want to go to slightly softer springs than stock, but try it with no pressure and see how your sag works out, and go from there.
    Good luck!
    MG
    Reputation: Coiler Mad's Avatar
    Jan 2005
    Don't bother with them mate, I've just replaced my Drop-Offs yesterday with RS Boxxer Ride U-Turns, completely changed the bike, and it even climbs better as well!!
    Still on Training Wheels!
    Reputation: drum714's Avatar
    Totally agree. You probobly won't need any pressure. Just double check your oil heights to help control your bottoming out resistance and you'll be set. But again set the fork where you are comfortable.
    It's not a good ride if you don't scare yourself at least once.
    Yeah...I'm Sponsored..................by my Bank Account
    Apr 2005
    I weigh around 163 lbs. and I've got an '04 Coiler with the Drop Off Comp that I'm running around 15 psi in both legs, and it works great. Recommended sag was around 10 psi, but it felt too mushy for the type of riding I do (trail riding with some small jumps and 2-3 ft. drops).
    Jun 2005
    Thanks much for the replies.
    I had 0 psi in each leg and it was very close to the recommended sag, however ther rebound was super slow and it just felt to soft, so i ended up with 0 psi in left leg and 5 in the right.
    I post too much.
    Mar 2005
    I think I have 5 psi in both legs, although I have nothing to check it out.
  1. Heckler or kona coiler
    By M.C. in forum Santa Cruz
    Last Post: 04-12-2005, 07:01 PM
  2. Kona Coiler?
    By jkish in forum Clydesdales/Tall Riders
    Last Post: 01-04-2005, 11:41 AM
  3. Kona Coiler?
    By jkish in forum Downhill - Freeride
    Last Post: 12-30-2004, 09:54 PM
  4. Whistler and 2005 Marzocchi Line
    By Photo-John in forum Downhill - Freeride
    Last Post: 08-10-2004, 03:46 PM
