Results 1 to 7 of 7
Thread: Kona Ti Rove
    LFJ
    LFJ is offline
    Dec 2004
    Kona Ti Rove
    I am seriously thinking about getting a Ti Rove but have to order one without seeing it. Just curious as to what real world tire clearance this frame has for a rear tire?
    Also what fork would owners of this frame recommend?
    Reputation: micah356's Avatar
    Dec 2010
    I don't have any appropriately sized tires to check max clearance. I had 35c on it with tons of room, but I dpn't have anything bigger than that. I have heard of 40c fitting but I think that would be tight.
    LFJ
    LFJ is offline
    Dec 2004
    I wasn't sure if the rear tire clearance would fit a panaracer 700x45. Sounds like it might be very tight.
    Dec 2010
    Actually I was mistaken. Kona says that it will fit 40C with fenders or 42c without, but I have heard that it could fit 50c. I just have no way to check.
    Oct 2013
    I recently purchased a 49cm Rove Ti. Still trying to narrow down what parts I'm going to use. Anyway, I took the frameset and straddled a Panaracer Pasela 35c (actually measured 37mm @ 90psi) and there was 7-8mm of clearance on both sides of the tire.
    get down!
    Reputation: appleSSeed's Avatar
    I have a Specialized 29x1.8 in mine and that's a pretty huge tire. Highly recommended tire though! Only around 400 grams and tough as nails. I did the Dirty Kanza 200 and Cedar Cross on them and had zero flats. Actually I've never had a flat with them.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Oct 2013
    Sweet looking rig!! Would like to know more about your build if you don't mind. 50/34? What do you have for levers, barends and derailleurs? Had any trouble with the seatpost holding tight...I've heard a few concerns with the Enve type clamp. I'm leaning toward Ultegra 6800 but no barends available. My main bikes over the past decade or so have been a narrow tired road tandem (FSA & Record 10spd) and a Santana (Shimd 8spd w/barends) that we can do some gravel/ packed dirt roads. This is a completely new ,and selfish, type of build for me.
  1. Anyone preorder the Ti Rove?
    By appleSSeed in forum Kona
    Last Post: 04-06-2017, 02:36 AM
  2. Jake or Rove ?
    By lextek in forum Kona
    Last Post: 05-06-2013, 05:09 PM
  3. Answer Rove DJ/AM Stem for $40
    By GTscoob in forum Where are the Best Deals?
    Last Post: 09-06-2012, 02:55 PM
  4. Rove XC and Next XC
    By primestick in forum Bike and Frame discussion
    Last Post: 03-29-2012, 02:56 PM
  5. Answer Rove dj stem
    By gunt pimp in forum All Mountain
    Last Post: 02-21-2011, 06:38 AM
