    Jun 2012
    Kona Process 153 '15 - Front Mech
    Wondering if anyone has swapped the front mech from the stock SRAM and had any success in more reliable shifts?
    Been a constant problem since I've bought my bike and has caused a number of chain drops.
    I know most resort to 1X. Eagle would be ideal but the stock Deore hub doesn't leave a easy way to do that.
    I've heard Shimano's front mech works much better, just not sure if its the SRAM mech or GEO.
    Thoughts? Thanks in advance.
    Edit: Since it wasn't clear based on the response. I have a 2X10 that i'm wondering if Shimano front shifter/derailleur would work more reliably than the stock X5?
    Jan 2011
    Quote Originally Posted by antigravity19 View Post
    Still get lots of chain dropping running 1x !, its something to do with the suspension, stronger shimano rear mech & mrp 1x guide helped for me
    you can go gx 11 speed with an 11-46 shimano mech, for loads of range or even 11-50 if you want more
    https://factoryjackson.com/2017/04/1...peed-cassette/
    Dec 2014
    Kimbers is correct. In my experience it's a clutch on the derailleur you're missing. As my chain started wearing it began to drop, so that plays a role too.
    Re-cap: rear mech with a clutch helps. New chain cleared up my problem. I also installed a $35 guide for insurance.
    oops I wasn't clipped in
    Jun 2012
    Its a SRAM X9 w/Clutch with a X5 front 2X10. I have not converted to 1X yet though the SunRace is interesting as an alternative.
    Drops mainly come trying to switch between chain rings in the front mech. It reluctantly tries to go to the Larger sprocket and will jump off. Basically have to have perfect conditions to switch.
    Looking at a front mech change if it would help going to SLX or similar to cheaply resolve the issue.
  1. Replies: 13
    Last Post: 10-03-2017, 12:41 PM
  2. 2014 process 153 vs 2015 process 134
    By f0nz0 in forum All Mountain
    Last Post: 06-09-2015, 01:50 PM
  3. Replies: 32
    Last Post: 12-12-2013, 08:02 AM
  4. '14 Kona Process 153 & '14 Trek Slash 7
    By Cludge in forum 27.5
    Last Post: 11-16-2013, 02:59 PM
  5. Replies: 5
    Last Post: 08-27-2013, 02:49 PM
Members who have read this thread: 13
