Results 1 to 3 of 3
    Reputation: ubado's Avatar
    Oct 2011
    KONA HONZO ... what is the fork's head tube length for a small 16" frame?
    ... just like the title suggests, I'm trying to find out the total length of the head tube on the stock fork for a small/16" Honzo. (crown to top of neck ... stock setting)
    Currently I'm getting parts ready for when Kona releases their 2014 Honzo frames ... with this, I'd like to find out the total length of head tube I'll need to find. Especially since you can find some pretty good deals on forks with shorter head tubes ... I just want to make sure I don't get on too short.
    Any info is appreciated!
    '12 Transition Bandit29
    '14 Kona Big Unit
    '94 Kona Explosif
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Yeah so terminology first;
    Head tube is on the frame, the frame only
    Steerer tube is on the fork. Your minimum steerer tube length needs to be greater than the total "stack height" of the frame head tube length+headset stack height + stem stack height.
    On my small Honzo, the frame head tube length is 3.5".
    My fork steerer tube length is 6.25", that's with a king headset, chromag stem & 1cm spacer. Stock Kona headset and stem may have different stack heights.
    Hope that helps!
    Oct 2011
    Right On!
    Thanks FM ... that helps a lot!
    That steer tube length is even shorter than I figured ... cool, now I can go hunting for a used fork without questioning myself about if I figured out the length correctly.
    '14 Kona Big Unit
    '94 Kona Explosif
  1. 1.5 head tube frame can I use a tapered fork?
    By bicyclejuju1 in forum Shocks and Suspension
    Last Post: 04-30-2013, 02:41 PM
  2. Replies: 5
    Last Post: 04-22-2013, 02:06 PM
  3. Head tube angle or fork length
    By jackspade in forum Bike and Frame discussion
    Last Post: 07-22-2012, 11:43 AM
  4. Honzo Frameset - Face/Ream Head tube?
    By eauxgod in forum Kona
    Last Post: 12-31-2011, 07:28 PM
  5. 1 1/8 fork BUT 1.5" head tube?
    By Freddy4130 in forum Shocks and Suspension
    Last Post: 05-15-2011, 05:05 PM
