Results 1 to 11 of 11
    Reputation: playdead's Avatar
    kona honzo seatpost diameter
    Hey,
    Just ordering a bunch of parts for a honzo build. Can't seem to find what size seatpost it takes. What size seatpost does it take?
    Thanks in advance.
    "Bound to cover just a little more ground"
    Never mind. Found it out.
    Reputation: eurospek's Avatar
    31.6mm for anyone who searches for the future.
    konahonzo
    Reputation: dfuse's Avatar
    Feb 2013
    Quote Originally Posted by eurospek View Post
    this is me thanking you from the future
    Anyone know the seatpost clamp/collar size?
    Quote Originally Posted by goldenaustin View Post
    35mm
    konahonzo
    Reputation: ynot89's Avatar
    dumb question most likely, but would a 34.9mm clamp work? I find my seatpost slides down (but not to either side) while riding. anyone else experience this?
    Sure would. It basically the same size as the 35mm clamp, depends on manufacturer and what they decide to label it.
    Is yours slipping with the stock clamp? What brand of seatpost?
    konahonzo
    Aug 2013
    yeah my seat post has been sliding down, wiped off some of the grease on the post so hopefully that will work otherwise, I will be looking at getting an allen key clamp so that I can tighten it some more rather than the quick release.
    Yeah, mine seems to slide down. I'm running everything stock right now, so both the clamp and seatpost are Kona's in-house model.
    I had the same problem with the stock Kona clamp. Instead of trying other remedies like toothpaste, carbogrip, etc. I just swapped it out with a Thomson. All has been well since then, with both a Thomson seatpost, and now a KS Lev.
Members who have read this thread: 10
