Results 1 to 9 of 9
    Fat-tired Roadie
    Nov 2007
    Kona Hei Hei tire and water bottle clearances
    I have a '13 Hei Hei DL demo sitting in my garage that I need to decide whether or not to buy. I really like the way it rides, but the one I have - a 16" - can't fit a water bottle. Can someone with an 18" tell me if it shares the problem? It looks like the Hei Hei 29ers have always had a pretty similar scandium frame with tapered head tube, so I imagine previous years are representative too.
    My other question was what other tires people are riding with on the rear. It looks like a really tight clearance back there. My hardtail has a 2.25" Schalbe RoRo and RaRa that I'm pretty happy with; anyone try the 29" versions of those in the Hei Hei?
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    I've run a 2.3" Purgatory SWorks in my 2012 HeiHei DL. Apparently the 2013 rear triangle had tire clearance improved, I can't see 2.25" tire being an issue.
    Water bottles are tight, I have the 20" frame and I run a side loader cage with a shorter bottle. My camelback carries the water, my frame carries electrolyte drink.
    Fat-tired Roadie
    Nov 2007
    Good to hear about the tire.
    I figured I'd have to go to a side-entry cage, but I can't even fit a small bottle, no cages or anything. Which is irritating - if anyone out there has the 18", I'm still waiting to hear from you.
    upgrade until you suck
    I have a 19" and I can fit most water bottles in my frame. A friend has an 18" and he has trouble fitting anything larger than a small bottle in his frame.
    Reputation: FloriDave's Avatar
    Re: Kona Hei Hei tire and water bottle clearances
    I have a 19 inch hei hei, and use large bottles, but a side loader cage is the way to go.
    Sent from my Droid tablet using Tapatalk 2
    Fat-tired Roadie
    Nov 2007
    Quote Originally Posted by APSBiker View Post
    Sounds like your friend can fit a small bottle, though? That's what I was looking for. Given the miniscule changes in geometry, I think I'm leaning toward the 18" size.
    Thanks, guys.
    Yep, he hates that he has to use a camelbak for more remote rides, but that's the tradeoff, I guess.
    Fat-tired Roadie
    Nov 2007
    Thought I'd update the thread for anyone else who's asking the same thing.
    I did end up buying this year's 18" Hei Hei DL. A side loading bottle cage fits, and actually a large water bottle works pretty well.
    The cage is the T-One Anyway.
    ::T-ONE R&D CORP.:: Creation For Solution.
    So far, I really like it. Simple, and does the job. I don't have other side-loading or adjustable bottle cages to compare it to, however.
    And, last but not least, I'm really enjoying the bike.
    Reputation: lotusdriver's Avatar
    Sep 2013
    My 17" Tanuki DL will fit a water bottle, but only just.
  1. HD with water bottle?
    By agleck7 in forum Ibis
    Last Post: 06-19-2013, 02:16 PM
  2. Found a water bottle
    By pinerider in forum Colorado - Front Range
    Last Post: 05-12-2013, 08:23 PM
  3. For those who all want a new water bottle holder
    By deke505 in forum Off Camber (off topic)
    Last Post: 03-17-2013, 07:14 PM
  4. Replies: 1
    Last Post: 09-12-2012, 01:47 PM
  5. Smoke on the water.....bottle
    By Smokebikes in forum North & South Carolina
    Last Post: 01-13-2012, 05:45 PM
