Results 1 to 2 of 2
    Reputation: hogwash's Avatar
    Kona Explosif - fork question
    I see on KonaWorld.com that the Explosif frame is designed for use with a fork with 80mm of travel. would there be any drawbacks to running a 100mm fork on that frame?
    Reputation: Hayduke1972's Avatar
    Depends on your preference
    Quote Originally Posted by hogwash
    I got a steel KHS frame that was designed for an 80mm fork. I originally had an 80mm fork on it and I ended up changing it out to a 100mm fork. With the 80mm fork, the bike climed very well, but seemed twitchy at speed. Since I've put the 100mm fork on it, it definently tends to "wander" a bit on steep climbs(due to the slacker headtube angle). However, the bike is much more stable at speed so I like the tradeoff.
  1. Unit/Explosif geometry changes.
    By allroads in forum Kona
    Last Post: 07-27-2008, 05:47 AM
  2. Kona Konfusion (Unit/Explosif) :confused:
    By NRSLove in forum Singlespeed
    Last Post: 04-25-2005, 02:48 PM
  3. fork question for 02 Kona Stinky Dee-Lux
    By aschir01 in forum Downhill - Freeride
    Last Post: 12-09-2004, 02:08 PM
  4. Replies: 1
    Last Post: 12-08-2004, 10:58 AM
  5. rigid fork question: Alu, steel, carbon...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 03-24-2004, 05:18 PM
