Page 71 of 82 FirstFirst ... 216167686970717273747581 ... LastLast
Results 3,501 to 3,550 of 4069
  1. #3501
    Feb 2013
    Quote Originally Posted by noot View Post
    From experience, a 2.35 Hans Dampf on a 23mm internal rim will NOT fit in the rear of a <2015 Honzo.
    That's odd. My 2012 fits a 2.35 HD or Nic with 29mm internal rim, with a little mud scrub room to spare.
  2. #3502
    the air is thin up here..
    Reputation: noot's Avatar
    Quote Originally Posted by Collins View Post
    Very strange indeed. My 2012 had paint missing inside the yoke from the my HD rubbing in my Stans Flow. Not all the time, but enough around corners that I took it off after one ride.
    2016 Honzo Ti
    2015 Kona Paddy Wagon
    www.mngnt.com
  3. #3503
    Bnerd
    Reputation: RideEverything's Avatar
    I've run a Hans Dampf on the rear of my 2012 Honzo regularly over the years. It has been on a 22mm and 26mm IW rim.
    The HD fits with the dropouts in the shortest position with enough room for mud as was stated earlier. If you need a little more room slide the dropouts back a bit and you get some more clearance.
    I do have most of the paint rubbed off in the chainstay yolk. But that's because of not having properly tensioned spokes on a previous wheel. I haven't had any rub since I had my wheels tensioned properly.
  4. #3504
    2012 Honzo.
    Currently has an XT (M780) triple crank with a 32t narrow-wide ring. Not a ton of clearance with the chainstay, but enough. Went to switch to a 34t and there is zero clearance.
    Am I stuck and unable to go 34t with this current setup? Or am I having a brain fart and overlooking something simple?
  5. #3505
    Quote Originally Posted by goalieman24 View Post
    2012 Honzo.
    Can you move your 34 to the outside of the spider where the big ring used to be when it was a triple? Also when you installed your BB did you include the drive side 2.5mm spacer behind the cup?
  6. #3506
    Quote Originally Posted by RideEverything View Post
    Huh well, that was probably my issue. Time to fire my wheelbuilder... (me)
    2016 Honzo Ti
    www.mngnt.com
  7. #3507
    Quote Originally Posted by maximo View Post
    Yeah it definitely fits on the outside of the spider but I figured that would be a less than ideal chainline. I'm also deciding on some sort of bash/guide setup instead of the naked chainring as it currently sits, so I may want to keep the outside of the spider open.
    I'm honestly not sure right off hand if the BB spacer is there or not. 2.5mm doesn't seem like it would make that much more room though.
  8. #3508
    Feb 2013
    Ha -- there's plenty of paint/steel schlopped off from the yoke, but the tire fit...
    You should be able to run a 34-tooth on the inside of the spider -- I've done this with XT and SLX cranks; probably with a 2.5mm spacer on the drive side.
  9. #3509
    Norđwegr
    Reputation: Vegard's Avatar
    I never could get anything bigger than a 32t to with my 2013, but I guess I could have if I spaced out the BB quite a bit and 'ruined' the qfactor. My Ti will fit a 34 just fine without any spacing trickery, perhaps it's time to warrant a new frame? :P
  10. #3510
    Can confirm: BB was spacer-less and adding one on the drive side cleared a 34t ring.
  11. #3511
    Quote Originally Posted by Vegard View Post
    Well the 2.5mm spacer is supposed to be installed on all bb 73mm shells so its not really trickery. I think its overlooked a lot when people install a new bb.
  12. #3512
    May 2013
    Basic bike building skills.
  13. #3513
    Got my new xc race whip put together today, 23 lbs and totally awesome!
    Sent from my SM-N910V using Tapatalk
  14. #3514
    fnInt(1/x^2,x,0,1)
    Reputation: fleanutz's Avatar
    Super nice build!
    Looks like a size large, is that correct?
    Quote Originally Posted by grnbkr View Post
  15. #3515
    Tire clearance is good, with a pretty worn and stretched out 2.35 Nobby Nic mud packs up a bit, but the wheel will spin freely, for racing this weekend I put on the 2.25 Racing Ralph and it was perfect.
    The fork pictured is a 34 with a kabolt axle. The 34, trimmed steerer and the axle was lighter than my 2016 32, and is exactly 1 lb heavier than the new step cast fork.
  16. #3516
    Reputation: johnnygolucky's Avatar
    [QUOTE=grnbkr;12733283]
    Holy crap!!! Thats my dream bike!
    So I'm curious, Ive got a Process 111Dl that I built up, but always need a hardtail in the stable. Being I love the GEO of the Process, it's natural to build a Honzo.
    Konas new website shows they don't sell the Al/DL as a frame, only the 27.5+ as a frame only and the Carbon frame only option is the all black version.
    So my question is this: how did you get that frame with the red lettering? And where did you get it at as it appears our local shop will not be getting them in for months and I have a couple races I'm hoping to race on the Honzo August and Sept.
    Any info on getting one of these Carbon frames in a large would be SOOOOO helpful!!!
    Cheers!!!
    Ride, ski, ride, ski, repeat
  17. #3517
    Norđwegr
    Quote Originally Posted by johnnygolucky View Post
    They do, or atleast it says so on their page right under the photo of the bike. Click bikes, frames, then the AL/DL and look under the picture.
    Seems that all the people who got a CR so far have gotten the orange lettered version of the frame.
  18. #3518
    Jul 2016
    Has anybody rode the new 2017 Big Honzo? Really want to pull the trigger on that beast.
  19. #3519
    Quote Originally Posted by Sasadrzak47 View Post
    No. The Wozo caught my attention as a fun way for my wife and I to get a second fat bike if that means give up our Honzo.
    Both should be great bikes.
  20. #3520
    Reputation: Morgs010's Avatar
    I can't remember the top tube length of the 2016 Honzo St, however, it looks as though they have increased the top tube length by about 1cm for 2017 ( or maybe I am getting confused).
  21. #3521
    May 2012
    Really wish the Honzo ST Frameset would have been a different color this year. Bummed
  22. #3522
    Quote Originally Posted by Morgs010 View Post
    Here you are: KONA BIKES | 2016 BIKES | HONZO | Honzo ST
    2016 Honzo Ti
    www.mngnt.com
  23. #3523
    So looks as though for 2017 the Honzo ST will be approximately 1.5cm longer.
  24. #3524
    Reputation: Rynee's Avatar
    Aug 2014
    yes. and today they corrected the info on the website for the 17 steel honzo - it is NOT boost, but will be 142x12 as in the previous years.
  25. #3525
    Nov 2012
    Anyone running an ST with a 150mm fork? I am sending my 2014 140 talas back and just ordered a pike, I need to decide which air spring to get as the fork I got a deal on is currently at 130.
  26. #3526
    Norđwegr
    I'd try the 130 before spending money on changing it, you might like the spritely feel.
    Hopefully I have the time to take out my ti this weekend, I've been overloaded by work lately so I can save up for schoolbooks.
  27. #3527
    Jan 2013
    So, I tried out the 16 Honzo AL (M) and the 16 Honzo AL DL (L) for fit, and I am a little concerned about the sizing for the Honzo ST I intend to purchase to replace my broken Diamonback Sortie frame.
    I had an interesting experience on the two bikes in that neither of them really fit me properly and I am a little nervous about pulling the trigger now. I usually ride a M 29er, so my first instinct was to try medium, but the reach was way too short, I kept getting pushed off the back of the saddle... I tried the AL DL in Large, and the reach was perfect, but the standover was too high! It looks like the SO for the 17 honzo is the same for every model but the small (?) which is bigger than the rest of them (??). If this is true, the answer is to buy a large Honzo, but I would love some insight into this...
    "What Made Milwaukee Famous Has Made a Loser Out of Me"
  28. #3528
    Jul 2016
    Honzo Build Thread - post your builds here-fullsizerennder.jpgThought you might want to see my 2016 Honzo custom build, Spank custom build rims with Hope hubs next
    Attached Thumbnails Attached Thumbnails Honzo Build Thread - post your builds here-img_0733.jpg
  29. #3529
    Norđwegr
    You should get a dvo diamond to top off all that green.
  30. #3530
    Feb 2013
    What's up with the hookworms? This a urban mountain version?
    --Looks dope, btw.
  31. #3531
    Reputation: ATXZJ's Avatar
    Built a new 2016 honzo DL frame with some spare parts I had lying around. Built this one up as a lightweight-ish alternative to my other bikes.
    Full SLX drivetrain & brakes
    32 absolute oval ring
    11-40 sunrace cassette
    specialized carbon/ti saddle
    34.9 lev-I dropper
    leftover kona 40mm stem, bar & grips
    bontrager duster rims with sun ringle boost hub
    120mm Reba fork
    etc
    etc
    Super f*cking fun bike!
    14 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
  32. #3532
    Bnerd
    I decided to use my Honzo while coaching in the WBP yesterday. I figured since my group was on hardtails I'd join them.
    I have this group of 5 and 6 year olds through the summer two days a week. We pedal one day and ride park on the other.
    It was fun riding the Honzo in the park. I had to adjust how I was jumping as I was over shooting everything on the first few jumps! I know it's obvious but every bit of pressure gets translated directly into the rear wheel. When all you ride in the park is an 200mm DH sled it takes a bit to readjust your jumping technique.
  33. #3533
    Thread bump with my latest build. Still waiting on new bar & stem. And a front brake hose trim
    2016 Honzo Ti
    www.mngnt.com
  34. #3534
    Norđwegr
    Looks so much better with a dropper where the cable comes out at the clamp rather than a stealth routed one. I don't know what they were thinking when they screwed up the routing on the lower tube. If my RF Turbine fails I'm getting a KS lev or a Fox with seatclamp routing, easier to work with too.
  35. #3535
    What size are you guys riding to your height? I'm 5'10 and ride a large 2015 kona unit and 2016 giant trance 27.5. The top tube length of the large honzo is longer than either of my bikes however with my freaky inseam, my seatposts tend to skyrocket out of the frame. I'm roughly 29" from bottom bracket center to top of my saddle.
    Plan to pick up a steel honzo frame but not sure. I do feel like mediums are cramped but this one has a weird geo
    There's something about those long grueling climbs that gets my front end all stiff... And I'm not talking about lockout...
  36. #3536
    Also do you guys prefer the alu over st? It's been years since I've been on a alu ht
  37. #3537
    I'm 6'7, 36in inseam, and ride an XL with 35mm stem, and seat as far back as it goes. TT on the Honzo Ti isn't as long as the new STs though, can't believe how long it is. Gotta wonder if its too long - are people gonna start running their stems backwards?
    As for Aluminum vs Steel, there was quite a bit of discussion a few pages back in this thread.
    2016 Honzo Ti
    www.mngnt.com
  38. #3538
    Aug 2014
    I was running a 2015 steel size small and I am 5'7. My inseem is only 29" but small felt perfect for me and the 2017 is now even longer. My opinion is go with a medium. You are just like me though, floating between 2 sizes dependent on the brand, so there really isn't a right or wrong answe, you gotta just go off the numbers and what you prefer
  39. #3539
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    Quote Originally Posted by kikoraa View Post
    I would say medium for your height, a large might be a bit too stretched.
  40. #3540
    Norđwegr
    Any ideas on what to use for the stealth hole in the seattube? The rubber bit sheared in half when a branch yanked the droppercable at the handlebar.
  41. #3541
    Jenson sells some Giant specific ones...dont know if they work with the Kona Frames.
    OR
    Reach out to your local Kona dealer and have Kona HQ send a few to you...thats what I had them do.
  42. #3542
    Jan 2015
    Your local dealer should have some lying around. I asked for some and they gave me 3 for free.
    A buddy said the Giant Rubber grommet is too wide it wont fit to the honzos.
  43. #3543
    Reputation: manitou2200's Avatar
    Do nothing, leave it without a grommet. Those things look cheesy anyway. I took a medium coarse diamond rat tail file to mine on the Following and chamfered the opening just slightly. They look much better and don't rub through the cable housing.
  44. #3544
    Reputation: Davidfs's Avatar
    Feb 2016
    Quote Originally Posted by manitou2200 View Post
    I'd worry about water/mud buildup inside the frame, I know it's not a big opening, but still...
    Riding a Brooks saddle mounted to Reynolds 853
  45. #3545
    Quote Originally Posted by Davidfs View Post
    There's tubing internally in the frame so it's not going to get into the frame cavity just in the tube that the housing or cable travels through.
    I think some companies don't run continuous internal tubing from head tube into seat tube is because then the water would end up in the bottom of the seat tube and or bottom bracket. I think that's why Kona ran theirs the way they did on the Honzo CR, plus it may make servicing easier. Evil runs a continues tube but also has a drain hole in the BB.
  46. #3546
    I'm pretty sure that vegard has a ti (that does not have internal tubing to facilitate the dropper housing). I agree with Davidfs...gotta keep that hole covered...large enough opening for crap to fly into...
  47. #3547
    Feb 2016
    Oh I didn't realize it's continuous, never mind then
    *edit*
    Aha, I was right! Just kidding...
  48. #3548
    Quote Originally Posted by ledude View Post
    Are you sure the Ti doesn't have internal tubing? One of the jobs of the tubing is to keep the housing from rattling around. They're tied so not to rattle.
  49. #3549
    I own a ti honzo...there is definitely no internal tubing.
    just a oval shaped cutout in the seat tube, the rubber grommet guides the dropper housing upwards towards the hole in the seat tube.
  50. #3550
    Ok, thanks for confirming this. I was wrong about the Honzo's then, I stand corrected. Damn, I don't like this part of the design and those rubber grommets are lame. If a manufacturer is going to have details like this they should have a screw down port cover and make the port larger. They would have been better off running an internal tubing from head tube to seat tube for the dropper. I'm sure the CR is the same then. I've got one on order but I may just use the Lev Ti dropper ext. routing on it and seal those holes up.
    I do love that Ti Honzo regardless. Are you totally stoked on this bike?
  1. Post your ETSX builds
    By Shark in forum Rocky Mountain
    Last Post: 07-22-2016, 07:23 PM
  2. Post your Practical Builds
    By hans-solo in forum Singlespeed
    Last Post: 02-23-2009, 09:13 AM
  3. Custom Builds Thread
    By jncarpenter in forum Turner
    Last Post: 05-22-2008, 03:33 PM
  4. post your 7" travel under 40 lbs builds
    By dusthuffer in forum Downhill - Freeride
    Last Post: 05-14-2008, 09:45 AM
  5. XCL Build thread X Post
    By DirtDad in forum Custom Builders & Other Manufacturers
    Last Post: 08-19-2006, 10:24 AM
