Page 70 of 82 FirstFirst ... 206066676869707172737480 ... LastLast
Results 3,451 to 3,500 of 4065
  1. #3451
    Jun 2010
    Quote Originally Posted by noot View Post
    I'm gonna hold off for a while, see if I can get by without a dropper. If I do go back, the 9point8s look interesting. Some nice features that are of sudden interest considering my reverb failure - specifically, air spring failure just means "manual operation", the lock mechanism still works.
    I've got the Race Face,, which is essentially the 9 point 8 (Race Face licenses 9.8 to use their internals). Had a failure this weekend, but the saddle still locked in place so I could continue riding. Very happy with that option.
  2. #3452
    Jun 2010
    Quote Originally Posted by MostChillin View Post
    They may be the same internals but the Race Face and Easton versions keep failing. Plenty of posts here on MTBR to keep you busy.
    I've had my Fall Line for 7 months and it's worked flawlessly. A regular riding buddy has replaced three RF Turbine's in half that time. Just sold the latest warranty replacement and is going to give a Fox Transfer a try (since 9.8 still can't keep up with demand - baffling).
    Yep, my RF Turbine failed on it's first ride. I've got a 9.8 on order, but it's gonna be a while.
  3. #3453
    Aug 2014
    Yea, they license the drop lock tech... But they are definitely not "essentially the 9.8" - those Race Face droppers have had a ton of issues already, Fall Line is basically bomber, only issue I've seen is needing to replace the air seal sooner than you would think - leaking air after 6 months of use. That's a simple fix though and hopefully just an issue with a batch of the seals and not something we'll be seeing long term.
  4. #3454
    Nor­wegr
    Reputation: Vegard's Avatar
    I have the RF post, so far so good. I liked my KS Lev more, but none of the sizes they offered matched up with what I needed, either too long or too short.
    Quote Originally Posted by i.a.n. View Post
    Kona blew it by not building it with sliding drop outs. Tsk, tsk, tsk, Kona.
    Probably a material limitation as discussed previously.
  5. #3455
    Jun 2010
    Quote Originally Posted by Vegard View Post
    They still shoulda made it work! Hurumph!
  6. #3456
    Nor­wegr
    Doesn't matter, TI trumps it! :P
    It's going to rain tomorrow so I'm putting my DHF 2.5 on the rear, hopefully it'll fit.
  7. #3457
    Jun 2010
    Ti trumps all! Wait, I can't use that word...Ti drumpfs all!
  8. #3458
    the air is thin up here..
    Reputation: noot's Avatar
    Yup
    Pics please.
    2016 Honzo Ti
    2015 Kona Paddy Wagon
    www.mngnt.com
  9. #3459
    Nor­wegr
    Here you go, plenty of space even if my pic is shoddy. About 1cm on either side if you disregard the less than stellar drilling which leads to there being a tiny bit more room on one side. (an issue reported by many)
    Honzo Build Thread - post your builds here-08a41d48-a552-4d5c-9bc6-e374d389ee84.jpg
  10. #3460
    Aug 2014
    Yep, I was riding with my rear wheel uneven, just thought the stays were asymetric... Then I went to 27+ and it made the uneven clearance obvious. Asked around and sure enough it wasn't supposed to be that way. A difference of just a half a millimeter on the drilling will cause a huge mismatch! Not a big deal though, just had to slide one side back a hair.
  11. #3461
    Nor­wegr
    First ride with the 2.5 rear, it was AWESOME. Didn't do the slip and slide on anything, acceleration was good and the rolling resistance wasn't much worse than a nobby nic.
    Overall I was faster with this as a rear and front.
    Rode it on trails with mud, dry hardpack, roots and some wet areas.
  12. #3462
    Reputation: Rynee's Avatar
    Aug 2014
    @vegard sounds like you had good fun in the rain great to hear you're liking your setup more and more.
    Which tire are you running in the front now? Dhf 2.5as well? Have you also tried the dhr2 2.5 as a rear tire? Thanks!
  13. #3463
    Nor­wegr
    DHF 2.5 front and rear Haven't tried the DHR in any size, don't really see the need at this point because the DHF did great.
  14. #3464
    WNC Native
    Reputation: nitrousjunky's Avatar
    Quote Originally Posted by Rynee View Post
    They don't make the DHRII in a 2.5
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  15. #3465
    Nor­wegr
    Quote Originally Posted by nitrousjunky View Post
    Some have said the 2.4 DHR measures to be as big or bigger than a 2.5 DHF, wether or not that's a fact I don't know. Haven't tried it myself.
  16. #3466
    Jun 2015
    You are not the first one to choose this setup and I wonder why 2 dhf instead of one dhf + dhr ?
    I thought the dhr was better in rolling resistance.
  17. #3467
    WNC Native
    2.3 DHRII is about the same width as the 2.3 DHF.
    Tomati- I've ran DHF front and DHRII rear, then DHF on both ends. DHF rolls better and I preferred it over mix of the 2.
  18. #3468
    Jun 2015
    Alright, thanks , good to know
  19. #3469
    Hoooo momma
    Is this the perfect Honzo tire??
    2016 Honzo Ti
    www.mngnt.com
  20. #3470
    Nor­wegr
    2.6 Nobbys? That's interesting if they're actual 2.6 and not just on paper.
  21. #3471
    Agreed. I think schwalbe is typically true to size.. My 2.35s are anyway.
    I can't find any info on these 2.6s yet
    2016 Honzo Ti
    www.mngnt.com
  22. #3472
    Reputation: carabao's Avatar
    I'd be happy if they were even close to 2.6. Very happy with the handling of the 2.3 but would love more volume. Also interested in the XR4 2.55s.
  23. #3473
    Jul 2016
    Hi everyone, I have a 2014 stock honzo except for tubeless tires and narrow wide chain rings and I was wondering what should I upgrade next? you guys got any suggestion?
  24. #3474
    Nor­wegr
    My suggestion would be to save up for a carbon wheelset with good hubs.
    Out of the things you can get, it'll be the the one that could transform your ride the most.
    If that's out of the question I'd look at a dropperpost, tires, stem/bar sizing and crankset.
    I never had much luck with my nobby nicks in 2.25 or 2.35, but with the wider footprint I'd be willing to give them a go. After my brand new DHFs wear out though, spent too much on rubber this year :P
  25. #3475
    Jul 2016
    What aboit aluminium wheelset? Any recommendation?
  26. #3476
    Quote Originally Posted by xoulliam View Post
    How heavy are you?
    You actually have an advantage - the latest "trend" is these new wide rims. The 2014 can't fit super wide tires, so there's a whole ton of "sorta wide" ~23mm internal rims out there that you should be able to get for a pretty reasonable price.
    The other thing you may want to upgrade that's works well in the "keep you satisfied longer" department is cockpit. Grab a nice wide carbon bar & save half a pound. Maybe a stem & seatpost too.
    2016 Honzo Ti
    www.mngnt.com
  27. #3477
    Jul 2016
    I'm about 185 pounds, what's the widest I can go?
  28. #3478
    I had Flows, which were around 23mm internal. In my old Honzo frame, I couldn't quite fit a Hans Dampf 2.35, which is a pretty wide 2.35. So, I wouldn't go wider than 23mm internal as it might limit your tire selection.
    Otherwise, at 185lbs (unless you have a habit of destroying wheels) I'd just keep your eyes peeled for a light set of wheels around that width at whatever price point you're comfortable with. I'm sure others will chime in with suggestions.
    2016 Honzo Ti
    www.mngnt.com
  29. #3479
    Jul 2016
    1. Carbon handlebars
    2. dropper seat post
    3. new wheelset
    4. Pike or Fox 34
    Any of those 4 were very noticeable upgrades for me
  30. #3480
    Jul 2016
    Well you guys did it again, back in 2014 I had read through this whole thread and decided to take a chance on a Honzo instead of the ROS 9 that I fell in love with during a demo. Over two years have passed and my 2014 Honzo was still my dream bike, until I looked at this thread again...
    My LBS just informed me that my new Ti Honzo frame will arrive on 7/6
    I will be taking everything from my current 2014 honzo and transferring it to the Ti frame. The following is on my current frame
    - Enve Carbon bars
    - KS LEV Dropper post
    - SLX Brakes with Ice Tech rotors
    - 1x11 XT Cassette, RD, and Shifter (11-42t)
    - RaceFace Turbine Cinch crankset with a Absolute Black oval chainring (32T)
    - 140mm RockShox Pike
    - Mango Chris King headset
    - Mango Chris King hubs with Stans flow rims
    - Orange Spank Spike Pedals
    - 2.35 Nobby Nic front tire, 2.25 Maxxis Ikon Rear tire
    I hope to have the Ti frame built up this weekend. I'm tempted to replace my current tires with a Maxxis DHF and SS combo but I'm afraid they might be too burly for my riding style, that being said wider tires are appealing to me.
  31. #3481
    Jul 2016
    Any tire recommendation for the northeast trail with roots and rocks and a bit of mud? And wich width?
  32. #3482
    Nor­wegr
    It all depends on your budget, what is it?
  33. #3483
    Jul 2016
    I have about 700 for a new set of wheels
  34. #3484
    Nor­wegr
    Easton Heist 30 or Flow MK3s with DT350s hubs are your best bets I guess. If I were you I'd still save up $400-500 more and go carbon.
  35. #3485
    Nov 2012
    I am building a new wheelset for my 2016 with Hadley hubs, wheel smith db spokes and Velocity blunt 35 (30 internal). Stoked cause it will be a 100% made in USA wheelset and the Hadley hubs really are insanely nice, excellent customer service too (I bought them used and needed to convert standards). Worth a look!
  36. #3486
    Highly recommend Hope Pros on LB carbon rims. Not much more than $700 either...
  37. #3487
    Nor­wegr
    Slightly OT, but damn this is one affordable and neat ride:
    On One DeeDar SRAM GX1 Mountain Bike | On - One
  38. #3488
    Aug 2014
    I just got back from a three day trip through Slovenia. The honzo has proven it's worth many times over 😊 I'm ever more impressed by that bike. We had two 26er fullies and two 29er fullies (carbon stumpy and carbon enduro) in the group as well. First, the advantage of the 29ers was extremely noticable both uphill and downhill. Second, the steel honzo with a 32T oval ring (i'm entirely sold on that one now) and 11-42 cassette was amazing - going uphill like a clockwork with flat pedals. Downhills were a bit more challenging than with the 29er squishies, of course. Third, the hardtail frame offers valuable storage possibilities...I'll post pics later on.
    Did I convey the notion that I'm stoked? 😃
  39. #3489
    Nor­wegr
    Would love to see pictures, I've never been there!
  40. #3490
    Aug 2014
    Thanks for your patience, sir
    Break before the first downhill section:
    High plateau "Nanos":
    On our way down - blasted by sideways winds:
    The mule:
    Reaching our goal - the sea:
  41. #3491
    Reputation: manitou2200's Avatar
    Attachment 1080512
    Attachment 1080515
    Attachment 1080516
    The mule:
    Attachment 1080517
    Attachment 1080518
    Great photos and stoke! Thanks for sharing. My gal is from Slovenia and we hope to get over there next year. You've got me fired up, can't wait.
  42. #3492
    Quote Originally Posted by carabao View Post
    Those, the 2.4 XR or SE4s and SE3s all interest me. XR3 and 4 combo has been great but I've torn sidewalls XR3 in back thus my interest in the SE3 tires. The Bontrager "3" tread is a lot of traction for how fast or quick it feels.
    I forget how big a tire you can mount on a 2014 bike (green) - the frame or Revelation fork.
  43. #3493
    Aug 2014
    Quote Originally Posted by manitou2200 View Post
    That's great to hear, thanks for the reply! You can definitely look forward to it, it's well worth the trip. And if your girl speaks the language, it's definitely a good bonus.
    Be sure to bring enough energybars, tools and spareparts though, we didn't see more than one bike shop in three days. And on Mondays apparently most restaurants seem to be closed.
    You might also want to check out the Soca valley, which is overwhelmingly beautiful. I've been there last year.
  44. #3494
    Sweet man! Thanks for the beta. And yes she does speak the language. I'll brush up on mine as well as the Italiano. Cheers!
  45. #3495
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    Quote Originally Posted by bitflogger View Post
    While they're not the biggest tires available, I ran a 2.4 Ardent in a Brownzo (2013) and am currently running a 2.5 DHF in a 2012 Revelation.
  46. #3496
    Quote Originally Posted by beer_coffee_water View Post
    Revelation has plenty of room for anything that's not "29+" - and even some of those may fit.
    From experience, a 2.35 Hans Dampf on a 23mm internal rim will NOT fit in the rear of a <2015 Honzo.
    2016 Honzo Ti
    www.mngnt.com
  47. #3497
    Jul 2016
    Honzo plus
    I have a Honzo 2015 model and I was thinking about trying to make it into a plus bike. I see that someone has done this before. What rims did people ise and did you have any problems with the chainline on a 142 rear end. Also are you running normal forks or Boost forks?
    Aug 2014
    Quote Originally Posted by mccreaky View Post
    I went with i35 rims for 2.8 tires, seems like this is the sweet spot for many, I love it! Chainline won't be affected by going plus... You will still run a 142x12 rear hub. You could go boost or non-boost forks... I use my pike 29er fork, it can clear a 27.5x3.0 tire no problem - but I'm happy at 2.8 anyways.
  49. #3499
    Aug 2014
    My 29er fork is 100x15, not boost
  50. #3500
    Aug 2014
    Also, the rear triangle fits a 2.8 Nobby Nic fine, but it's a little bit tight. Don't expect to go any wider in the rear without modifying the frame (not recommended). The 2.8 Nobby nic was getting too many punctures for me, I ended up switching to the 2.5 breakout which measures more like 2.6-2.7 on the i35 rim, it's also actually taller than the Nobby Nic. I plan on trying the WTB Ranger 2.8 once they release the dual ply tough version.
  1. Post your ETSX builds
    By Shark in forum Rocky Mountain
    Last Post: 07-22-2016, 07:23 PM
  2. Post your Practical Builds
    By hans-solo in forum Singlespeed
    Last Post: 02-23-2009, 09:13 AM
  3. Custom Builds Thread
    By jncarpenter in forum Turner
    Last Post: 05-22-2008, 03:33 PM
  4. post your 7" travel under 40 lbs builds
    By dusthuffer in forum Downhill - Freeride
    Last Post: 05-14-2008, 09:45 AM
  5. XCL Build thread X Post
    By DirtDad in forum Custom Builders & Other Manufacturers
    Last Post: 08-19-2006, 10:24 AM
