Results 1 to 6 of 6
    Fixing a 150mm fork to a 2005 stinky
    Any advise against doing this? Looking at a Marzocchi Z1FR or a Firefly Plus. Thanks.
    North American For Life..
    Reputation: KNine's Avatar
    Nothing wrong with doing that. It will change your head angle thats all.
    Support Go Huck Yourself
    Center Cycle
    Old Town Bicycle
    KGRG 89.9 FM GRCC
    I refuse to accept your reality; therefore I will substitute my own.
    I was always told
    That if I ain't gon' be part of the greatest
    I gotta be the greatest myself
    Just roll it......
    Reputation: ebxtreme's Avatar
    Yep, as K-Nine said......
    .....it's just gonna steepen your head angle slightly if you have a longer fork on there now.
    For reference, the Axle to Crown measurements for the 'zocchi forks are as follows:
    '04 Z1 130mm - 518mm
    '05 Z1 150mm (also the '04 Z150) - 538mm
    ''03 - '04 Super and Jr. T - 558mm
    '05 66 150mm - 571mm
    '05 66 170mm - 596mm
    EB
    ok....
    Quote Originally Posted by KNine
    there's a slight imbalance with the amount of travel front and rear and the change in HA, how does this affect the handling?
    You have to look at it this way. The head angle on a Stinky is 66.5 degrees with a 170mm for when you drop to a 150mm fork that is going to take your head angle to about 67.5 degrees. Still slack, but not a stable going downhill. Anyways if you want to run a 6 inch fork and i assume you already bought the stinky. Why did'nt you consider a Coiler insted?
    Center Cycle
    Old Town Bicycle
    KGRG 89.9 FM GRCC
    I was always told
    yeah, you are right...
    the coiler would've been perfect but I bought the stinky with serious freeriding in mind. That was until I hurt my back dirt jumping. The doc advised me against subjecting my back to more serious shocks, so I decided to convert my stinky with trail riding in mind, a less stressful form of riding.
    I'm considering 150mm because I think anything less will make the bike quite ridiculous to ride, bearing in mind it has 7inches in the rear.
    already got my long stem and 2.1 cross country tires...
  1. fork question for 02 Kona Stinky Dee-Lux
    By aschir01 in forum Downhill - Freeride
    Last Post: 12-09-2004, 02:08 PM
  2. 150mm fork on a Hardrock 2005 - repost
    By freerider167 in forum Passion
    Last Post: 12-06-2004, 01:06 PM
  3. 150mm fork on a 2005 hardrock comp
    By freerider167 in forum Specialized
    Last Post: 12-05-2004, 04:25 PM
  4. Whistler and 2005 Marzocchi Line
    By Photo-John in forum Downhill - Freeride
    Last Post: 08-10-2004, 03:46 PM
