Results 1 to 5 of 5
    Reputation: top_ring's Avatar
    New question here. Explosif or Kilauea?
    ( for the Kona aficionados ) ... Does anyone know for certain?
    In the mid to late 90`s Kona was producing the Explosif and Kilauea cromoly steel frames. Some years they were Tange prestige tubing, some Columbus and some Reynolds... are they the exact same frame with a different name?
    If not - what`s the difference?
    And what is the BEST tubing in your opinion? Thanks.
    UK Biker
    Reputation: Fluffbomb's Avatar
    Nope!
    The exact specifications of the frames varied from year to year but they were always different. The Explosif always had a higher specification tubeset.
    Fluff
    Yeah - I felt that might be the case but when you see the two together in photos they look identical. So basically , even thought the two frames geometry may be the same - the tubes on the Explosif are of higher quality... Yes??
    UK Biker
    Tubing
    You might find this link useful - http://kona.dk/bikeindex.php?yearId=8
    Explosif has always been the higher end of the two models.
    Its difficult to see any difference between Kona steel frames as bikes tend to use standard dia tubing for the main frame tubes and I suspect they all use Kona double butted tubing for the stays regardless of the model. The main difference is internally where the higher spec tubing allows thinner tube walls to be used (lighter & better ride).
    Saying that my '96 Explosif uses Columbus Max OR tubing which in pictures looks like normal tubing but in the flesh the tube ovalisation on the top & down tubes is quite noticable. Btw the '96 Explosif is my fave (biased) and avoid the '93 (if u could find one) as they're too light (I had one crack around the downtube). I also had one of the first '92 Kilauea and it was only a simple Double Butted frame so nothing special.
    Cheers,
    Alex
    Alex - thanks for the info. I actually had a 97 Max OR Explosif. A very nice riding frame but alas, it was too small for me at 18". I really should have a 19" so I`m in search of one now. But I would take the Kilauea all the same.
  1. Closest current bike to my '99 Kula? '05 Explosif?
    By 800-lb-gorilla in forum Kona
    Last Post: 04-15-2005, 03:06 PM
  2. Replies: 6
    Last Post: 02-08-2005, 07:31 AM
  3. Building a new 05 Explosif
    By simian23 in forum Kona
    Last Post: 01-06-2005, 02:38 AM
  4. Kona Explosif 2004 <-> 2005
    By Maixle in forum Kona
    Last Post: 11-29-2004, 03:19 PM
  5. Kona Explosif 93!
    By Markie in forum Vintage, Retro, Classic
    Last Post: 05-08-2004, 10:20 AM
