Results 1 to 14 of 14
    Reputation: duggus's Avatar
    Detailed specs for Hei Hei 29?
    Does anyone know where to get detailed frame specs for a 2011 Kona Hei Hei 29?
    I need know the rear shock eye to eye measurement, bolt size, and the width where the rear shock mounts to the frame, getting a new Rock Shox Monarch RT3 and need to know what hardware to get.
    Bottom Bracket type... I know I need a 73mm but is there a certain type that is recomended... GXP?
    Front Derailleur: What type goes on this frame... looks like top pull, but what mount is it?
    Sorry if these questions are dense... it's my first frame build and I don't want to make any mistakes. Thanks.
    This is all I can find. Pics help in ID'ing certain components as well;
    konaworld
    Yeah... I've been resorting to that... but you'd think I should be able to find a spec sheet or something. I contacted Kona but waiting to hear back yet... just wanted to order the shock today. I'm also transferring some of the parts off my `11 X-Cal and trying to figure out what I can use. I have a top pull FD but not sure what the mount is on the Hei Hei.
    Here is what I know...........
    Shock Stroke 1.75" or 44mm
    Eye To Eye 7.25 or 184mm
    Front Derailleur is bolt on top swing top pull.
    BB is 73mm and just match up BB with Crankset. It does not have to match but might as well. BB's come with one or two spacers and using 2 spacers makes it a 68mm BB or one Spacer will make it a 73mm BB. Good luck with the build and the bike is fun to ride. Cheers
    Awesome! Thanks. I'll post some pics (in a few months) when I get this fully built.
    Dec 2011
    where can you buy a hei hei 29er frame?
    Quote Originally Posted by lubbockrider View Post
    Small chance you might be able to buy one off eBay. I tried to get the frame only from my LBS (that I race for) and there was no way. Maybe if you get a sponsorship from Kona? Good luck finding the frame-only.
    FWIW, I got an XT rear hub and cassette with my 2012 Hei Hei 29 base model. My 19" weighs about 32 lbs with all the stock equipment. I didn't strip it down and weigh anything separately. I will do that over time as I replace individual parts.
    Smile
    I ended up getting really lucky and finding one on eBay from "The Pros Closet", they sell a lot of team leftovers. I got a 2011 team frame with the chrome orange paint job and all the frame features of the 2012 Hei Hei 29. They had two that were never built up in a 19" which fits me like a glove. Just got done with the build last month:
    Rock Shox SID XX 100mm fork, 15mm thru axle & hydraulic lockout, tapered steerer
    Loaded ceramic bearing ano headset
    Truvativ world cup handlebars
    Velocity Blunt SL rim laced to Hope Pro 2 ano hub
    WTB Bronson 2.2 tubeless tire (front)
    Hayes Stroker Trail hydro brakes, 203/185 rotors
    Fox RP2 high volume rear shock - 4" travel
    SRAM 2x10 24-38t drivetrain
    X7 front & rear derailleurs
    Spank Spike platforms
    WTB Rocket V saddle
    ESI Racers Edge grips
    Came in at 29.1 Lbs with pedals. I have a lighter rear wheel on the way
    Reputation: eurospek's Avatar
    Kinda shocked with that weight. I was expecting around 26 lbs max. 29 lbs seems heavy for an aluminum frame, people are getting similar weights with the much burlier Kona Honzo.
    konahonzo
    The rear wheel is pretty heavy. I don't have super high end lightweight components on it yet, other than the SID fork. The frame itself was 4.9 lbs so that is pretty light. It's still light compared to a lot of my other previous FS bikes, and for a 29er FS. It was weighed with the pedals and everything on, I've also added a 180 Ashima rotor on the front since it was weighed... that 203 rotor was HEAVY. I could easily get it to under 28 with some lighter stuff... but I'd rather it be able to hold up to my 220 lbs also : )
    man, I think that's a great looking bike
    how much was the frame?
    I got it for just under $600 with shipping.
    Oct 2011
    envy
    Quote Originally Posted by duggus View Post
    So jealous...
    Can anyone tell me what kind of front derraileur this frame use?
    Sram low direct mount, bottom pull, but S1, S2 ou S3 model?
  1. New Hei Hei 29er Steps Up to Some Gnar
    By chollaball in forum 29er Bikes
    Last Post: 04-16-2009, 10:18 PM
  2. Hei Hei 2-9er owners -- 80 or 100mm fork?
    By dgangi in forum 29er Bikes
    Last Post: 03-25-2009, 04:21 AM
  3. Replies: 2
    Last Post: 01-28-2009, 08:58 AM
  4. rode a hei hei 29 yesterday
    By newmarketrog in forum 29er Bikes
    Last Post: 11-11-2008, 07:26 PM
  5. El Santo vs Kona Hei Hei
    By Mad Dingo in forum Salsa
    Last Post: 02-28-2008, 10:23 AM
