Results 1 to 5 of 5
    Dawg: Removing shock
    I'm going to have my Fox Float shock sent it to PUSH. Anything special I should know about removing it? Just take the air out and unbolt it?
    roots, rocks, rhythm
    Reputation: Dawgprimo's Avatar
    Quote Originally Posted by Warthog
    I think you covered it..........
    On a serious note you will have to give a little review on the New "Pushed" shock once you get a few rides in.
    Okay...fast forward a week or so into the future...what are the torque specs for putting it back on?
    Got this from Kona Tech for a Dawg:
    (Good to keep handy)
    Top shock - 240 inch lbs
    Bottom Shock - 200 inch lbs
    Rocker to frame - 200 inch lbs
    SS to rocker - 150 inch lbs
    SS to CS - 200 inch lbs
    Lower Pivot - 240 inch lbs
    (Don't forget to use loctite (blue))
    That is what I used on both my Kona and Turner.
    Good Luck
    Excellent, thanks!
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. Dawg: Play in upper shock bolt
    By Warthog in forum Kona
    Last Post: 05-11-2005, 09:35 AM
  3. Dawg rear shock size
    By squirrellyrabbit in forum Kona
    Last Post: 08-03-2004, 03:16 PM
  4. K2 Razorback Noleen Mega Air rear
    By MegaVolt in forum Shocks and Suspension
    Last Post: 03-30-2004, 09:28 PM
