Results 1 to 2 of 2
    May 2005
    Coiler Delux Spring Weight
    What is the standard spring weight on an 05 Coiler delux? I just bought an '05 delux 17 inch and it shipped with an 800 pound spring. My LBS switched it to a 500 lb x 2.8 spring when they put it together, but I think the stock spring is a 550 lb. I am 176lbs and ride all kinds of terrain including free ride and even on the road to work a bit. This is my first dual suspension bike so I wanted some input on what the proper weight spring would be. Is 500 ok or should I be looking at a 550 or 600? Thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by BC Hunter
    From Kona's tech info sheets:
    Spring Rates; Coilers: 15-450 lb, 17-550 lbs, 18-650 lbs, 19-700 lbs, 20 - 750 lbs
    I am a bit lighter than you and the stock 700# spring on my 19" Coiler DL is prefect. I only need a small amount of preload to get the correct sag.
    mtbtires.com
  1. Mountain Bike Spring Rate Calculator V5.0
    By FireDog46 in forum Shocks and Suspension
    Last Post: 07-16-2013, 08:46 PM
  2. WalMart bike kicked my Ibis's ass!!
    By Itripper in forum General Discussion
    Last Post: 03-08-2006, 02:38 PM
  3. Replies: 2
    Last Post: 04-19-2005, 09:10 PM
  4. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  5. Ques. on sizing for body weight to rear shock's spring weight
    By Bonkler in forum Shocks and Suspension
    Last Post: 05-12-2004, 03:09 PM
