Results 1 to 3 of 3
    Aug 2010
    Big Unit questions
    I just bought a used Kona Big Unit frame and I have a few questions.
    1st I need to know what bottom bracket to use on this frame, I know GXP, but is there any differences in the various GXP's offered? And suggestions with links are appreciated.
    2nd I have and F29 straight 1&1/8" fork and want to know which adapter to use. the ones I found say that the outer dimension is 50mm ,but my head tube is larger by a few mm? Suggestions and links again are very welcome
    Steve
    When people ask me what I do, I don't tell them what I do for my job, I tell them I ride mountain bikes.
    What year? I used a cane creek zero stack on my 2011 big unit. The to was 44 I.d. and the bottom was 56 I.d. And used the reducer crown race that came with it. Haven't had any issues with it at all. I'm running the same fork. I use a Chris king out board bb 73mm and have an xt crank. What crank are you looking to run? I'm switching mine to a 1x10. Love the SS I'm just starting to get knee issues and noticed that the SS was a big contributor.
    um... yeah
    You can install any 73mm bottom bracket, depending on what cranks you use.
    The headset uses internal bearings top and bottom, even with a tapered fork. The lower bearing is the same, you just need a different crown race for the straight steerer. Cane Creek makes every possible version you could need. That's what I have in mind.
Hot Deals
Contests
Latest Mountain Bike Articles
