Results 1 to 3 of 3
    80mm fork on a Kula Deluxe?
    Do you think that running an 80mm fork on a Kula Deluxe would make the steering too twitchy? I'm thinking about buying a frame and swapping my current parts over, but I'm questionning whether my 80mm skarab would do the trick or not. Thanks!
    Andrew
    UK Biker
    Reputation: Fluffbomb's Avatar
    Should be fine!
    The Kona brochure states the Kula head angle as 69 degrees with 100mm Fox forks so putting a pair of 80mm forks should only steepen the angles by about a degree to give a 70 degree head angle which is about the norm for XC hardtails.
    Cheers,
    Fluff
    I ditto what Fluff says. Konas have slack head tubes, so it wont hurt at all. My Fire Mountain came with an 85mm fork and I kept the same travel when I bought a new fork because there was no way in hell a 100mm fork would allow me to still go around corner. Personally, I would spring for something like a Marzocchi MX-Pro ETA so you can run full travel downhill and in the rough and lock it down to 30mm travel on the climbs.
  1. 80mm fork or 100mm fork for a spider XVP
    By babar vip in forum Intense
    Last Post: 03-05-2005, 11:23 AM
  2. Everything you need to know about the PIKE's Motion Control Damping!
    By MicroHuck in forum Shocks and Suspension
    Last Post: 02-21-2005, 10:25 AM
  3. need new 80mm fork: Air or Coil?
    By Thumbie in forum Shocks and Suspension
    Last Post: 11-06-2004, 02:31 AM
  4. Spider with 80mm fork
    By 2wheeler in forum Intense
    Last Post: 04-19-2004, 02:43 PM
  5. Replies: 5
    Last Post: 04-14-2004, 08:19 AM
