Results 1 to 3 of 3
    5' 6.5" & 31.5" cycling inseam.What size Kona Unit?
    I think I'm probably in between the 15 and 17. Does the Unit work better as a smaller size with longer stem or a larger size with shorter stem? I'm a bit concerned the 15 might be too small. Suggestions?
    Aug 2005
    Quote Originally Posted by Geralt View Post
    The 15 would be too small. I'm just a tiny bit shorter than you. I like the size 16 or 17 Kona bikes in general. I found the size 15 Explosif I've demo'd to be rideable but too small.
    That's what I decided and what the bike shop recommended. The shop doesn't stock the Unit, so I had to order one. The measurements of the 17 are close to what I already ride, so I'm thinking it will be fine.
  1. Replies: 8
    Last Post: 06-05-2014, 11:08 AM
  2. Why size up? -->19" or 20" Kona UNIT?!?
    By el Camino in forum 29er Bikes
    Last Post: 03-08-2013, 06:05 AM
  3. Replies: 12
    Last Post: 08-26-2012, 09:19 PM
  4. Replies: 16
    Last Post: 08-06-2011, 02:52 PM
  5. Kona unit 2011 frame weight size 22"
    By JEA in forum 29er Bikes
    Last Post: 02-19-2011, 05:20 AM
