    2012 Kona Unit - Want Taller Gearing - Recommendations?
    I'm pretty much just using my Unit as an all purpose urban commuter and it's pretty flat here, so I'd like the gearing to be taller for more relaxed commuting.
    Any recommendations for what to go with? I'll admit, I've never worked on a bike before, but I'd say I'm definitely mechanically inclined.
    Any write ups out there on how to change the gearing and if someone has a brief shopping list and recommendations on what I'll need, I'd be very appreciative.
    Jan 2005
    I was using a 34-18 in the early spring commuting on my unit but tended to top out at about 15-16mph on the flats. If I was going to be doing a considerable amount of commuting I would probably use a 34-17 set up. I was also riding in the stock igniter tires.
    Surly Single Speed Cog > Components > Drivetrain > Singlespeed, BMX, and Track Cogs | Jenson USA Online Bike Shop
    FSA DH/SS MTB Chainring > Components > Drivetrain > Chainrings | Jenson USA Online Bike Shop
    Park HCW-17 Fixed Gear Lock Ring Tool > Accessories > Tools > Freehub and Cog tools | Jenson USA Online Bike Shop
    I don't know if you have a chain whip. But you need that locking tool for the unit hub.
    Thanks for the recommendations, finally got around to ordering from the links provided above.
    Any idea where I could get torque specs for the rear sliding drop out hex bolts?
    Quote Originally Posted by Lord09 View Post
    RE: torque specs.
    Contact Kona customer support.
  1. 2012 kona unit - replacement options?
    By StopStaring@myUnit in forum 29er Bikes
    Last Post: 12-01-2012, 03:27 PM
  2. 2012 Kona Unit 29er BB Size?
    By airic81 in forum Kona
    Last Post: 10-09-2012, 11:37 AM
  3. 2012 Kona Unit with Loop fork
    By money in forum 29er Bikes
    Last Post: 04-09-2012, 09:31 PM
  4. 2011-2012 20" Kona Unit Question
    By nitrousjunky in forum Kona
    Last Post: 11-30-2011, 10:26 AM
  5. Kona Big Unit. Will there be one for 2012?
    By BobShort in forum Kona
    Last Post: 10-26-2011, 08:43 PM
