    Reputation: duggus's Avatar
    2011 Kona Hei Hei 29 FORK question
    Hi, just thought I'd pick the Kona crowds brain. I have a 2011 Hei Hei SE 19" frame on its way... going to be my first frame build. My question is, has anyone used a G2 (51mm) offset fork on a Hei Hei... or any other Kona 29er? I noticed on their site the fork offset spec is for a 44mm. My last bike was a Trek/Fisher X-Cal 29er, so I liked the 51mm offset, and I noticed X-cals headtube angle is 69.3, the Hei Hei is 70... am I correct to assume a 51mm offset would put me at a similar "trail" spec as the X-cal?
    Come on... someone's gotta know this... winner gets REP POINTS!!! : )
    get down!
    Reputation: appleSSeed's Avatar
    Yes, it would get you to around the same trail spec.
    I would say to try a standard fork if you could, you might like it more or just as good. Unless you are keeping the original fork?
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Quote Originally Posted by appleSSeed View Post
    The new frame is tapered so I'm looking to get a tapered, with 15mm axle as well... just noticed quiet a few listings on ebay of fox forks with the G2 offset. I'm sure it would be very similar, was just hoping to hear from someone who actually had that set-up.... either way it always ends up being personal preference anyway right?
  1. Replies: 15
    Last Post: 03-02-2012, 08:52 PM
  2. 2011 Big Hit I with a double crown fork?
    By cesalec in forum Specialized
    Last Post: 01-20-2012, 07:48 PM
  3. 2012 Reba RLT fork will not fit 2011 Epic
    By dmboarder in forum Specialized
    Last Post: 01-15-2012, 09:16 PM
