Results 1 to 19 of 19
    Aug 2013
    120mm fork on Kona Unit
    Anyone try longer travel forks on the Unit frame? I can get a used frame for cheap and happen to have 120mm suspension forks sitting around for a quick and easy build.
    Did some searching but only found a few discussions in the SS forum.
    Just wondering if the result is a mini-Honzo with slightly slacker geo than what their specs show with the stock rigid fork. Looks like chain stays will be a bit longer.
    I know Kona recommends an 80-100mm fork on this frame, but I don't really need another 100mm travel bike. Anyway, would appreciate any feedback from those who have experimented with this.
    the unit has perfect geo, which is why it has gone unchanged for years now. a 120 fork would throw off the perfect geo. a 100mm fork would keep it almost perfect. almost perfect because a unit is absolutely perfect with the rigid fork that it comes with.
    good luck!
    rog
    Aug 2013
    Thanks Rog. It's just in my nature to mess with perfect!
    Quote Originally Posted by kickhorse View Post
    i know, i been dealing with you fiddlers, tinkerers, and over thinkers as a shop manager for eons. IT'S JUST A FVCKING BIKE!!!!!KEEP IT SIMPLE!!!!LEAVE IT ALONE!!!!!
    it's all good, mang
    rog
    Armature speller
    Sep 2004
    Do it and see. I'm thinking of 120's for mine.
    Jan 2011
    Well I've picked up some manitou towers @120mm for my 2014 unit
    They are tapered too, so I've had to buy a cane creek external bottom headset cup with a 12 mm stack height !
    To try and offset this ive ordered some spacers to lower the fork down to 100 mm
    I'll post up some pics and a review once its all arrived, I'm also weighting for some semi bath lube for the forks
    My buddy has a 2014 unit and he runs a 120mm fork and absolutely loves it... I would say go for it.
    Jan 2011
    Well still set at 120mm, had a quick spin about and it feels really nice loving the forks
    will try em at 100 when the spacers arrive
    Just need a longer brake hose !
    Jan 2011
    Did 20k at llandegla today conditions varied from a bit slidey to crap loads of snow, so not easy to give a decent review of how it rode, maybe wandered a it on the climbs, but not too bad
    Forks themselves were great, loads of control, lockout useful
    Be nice to try it in conditions were I can really hammer it
    I'll try it lowered to 100mm But it felt pretty damn good wy 120mm
    Reputation: I.V.A.'s Avatar
    Feb 2007
    Could you please measure the bb height at 120mm?
    Jan 2011
    320mm, thats an unweighted fork and with a 12mm lower headset cup instead of the integrated as it was a tapered steerer,
    be interested to know what the height was with the p2s as i never measured it
    Feb 2007
    If my math is right, it should be around 308 mm with P2.
    Armature speller
    Sep 2004
    Just installed a set of Manitou Marvel Expert 100mm forks on my 2011 Unit.
    A to C increased from 465-510mm and the HTA angle went from 71-69.
    Not ridden in anger yet but could have potential...
    Jan 2011
    Quote Originally Posted by NordieBoy View Post
    I had my 2014 Unit with 120mm towers, as it was a tapered fork i had to fit an external lower headset cup which added about 10 and a bitmm to the stack height
    steering felt fine and it soaked up the terrain
    I did feel i was pitched a bit too far back though, my saddle just felt too low relative to the bars
    reduced them down to 100mm and my positioning feels much better
    Armature speller
    Sep 2004
    Removed the spacers and the bars are 45mm below the seat. A little higher than usual, but should be no problem.
    Not going to chop the stem more until I find out what the handling is like on different terrains as I might drop it to 80mm and then the spacers would go back on.
    I'm looking to put a 120 tapered fork on a 2013 Unit.
    I'm not quite clear on the headset situation. Can someone post a link to an example of what Cane Creek bottom cup I'd need to buy?
    Quote Originally Posted by addATX View Post
    Is this what I need?
    Cane Creek 40 Series EC44/40 Bottom Cup > Components > Headsets and Spacers > Headsets | Jenson USA
    Armature speller
    Sep 2004
    Does sound like the right bit as the Unit specs say 40mm.
    Jan 2011
    yeo i fitted a
    Cane Creek 40-Series EC44-40 Bottom Assembly
    Cane Creek 40-Series EC44-40 Bottom Assembly | Chain Reaction Cycles
    on my 2014 unit
  1. 2013 Kona Unit or 2014 Kona Unit
    By evosil98 in forum Singlespeed
    Last Post: 12-10-2014, 09:06 AM
  2. 100mm forks vs 120mm forks ?????
    By Slapaho in forum 29er Components
    Last Post: 12-04-2014, 09:12 AM
  3. Spam: Kona Unit, Kona Honzo, Salsa Selma Ti
    By appleSSeed in forum 29er Bikes
    Last Post: 05-10-2012, 01:09 PM
  4. New Kona Unit
    By Sac29 in forum Singlespeed
    Last Post: 10-18-2011, 07:06 PM
  5. Kona Unit ? ? ?
    By charliethetuna in forum 29er Bikes
    Last Post: 04-10-2011, 04:07 PM
