Results 1 to 21 of 21
    Pivoteer
    Reputation: tiSS'er's Avatar
    WTB I23/I25 rims
    Anyone have experience with these? I have now had 3 tires blow off the FlowEX. My initial concern with the FlowEX was the very low bead hook, and it seems to be genuine. The WTB I25 seems to be the same rim, but with a true UST bead hook. Never seemed to have tires blowing off my Mavic 819s.
    I did run some higher pressures today, I will see if that helps. I have also considered trying the Bontrager SE4 tires, but doubt they will compare to the Chunky Monkeys for which I love so much.
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: wilks's Avatar
    I have had Hadley's on flows and now have I9s on i23s. I prefer the i23s. Easier to mount up tires with a floor pump and no blow offs at all. I had a couple of disconcerting blow offs on the flows. I23s are lighter I think but can't say I noticed the difference.
    Pivoteer
    Quote Originally Posted by wilks View Post
    Thanks wilks, just the kind of feedback I am looking for. How is the quality of the I23? Do you notice the seam? Are you running Stans yellow tape?
    Reputation: shiggy's Avatar
    Dec 1998
    WTB I23/I25 rims
    Quote Originally Posted by tiSS'er View Post
    The WTB i23 is a high quality rim. I have not even looked for the seam, or noticed it.
    Stan's tape does not work, too narrow. I used the recommended WTB 28mm rim tape. Tubeless use with UST compatible bead tires has been flawless, as is standard tires with tubes.
    mtbtires.com
    Pivoteer
    Quote Originally Posted by shiggy View Post
    Thanks Shiggy. Seems strange to run 28mm tape on a 23mm rim. Does the tape run up to the bead? 30mm tape required for the i25?
    I'm just using Stan's tape. No issues whatsoever. Been running 2.35 Hans dampfs and various specialized tubeless ready tires with 100% success. I'm 200 lbs. rocky rooty east coast trails. Running 20-23 psi front 25 psi rear.
    Reputation: F.N.G's Avatar
    Opposite with me. Burped every tire off my 819s and switched to flow. No blows yet..
    Countless burps with my flow ex in the rear. After I finally destroyed the rim I switched to i23. Not a single burp since. I am a happy customer with them so far.
    I was considering the i25 for my next wheel build also. I have WTB Laserdisc FRs on my freeride bike, which were on my FR hardtail for 3 seasons before, and I never had to true them, no flatspots and the finish is very durable. 30mm outside, i-beam, unbendium bulge, etc... all nice features that make for a strong rim. They were really well build up by a good wheelbuilder, but still, I really trust these rims. Never burped a tire on those either, and I ride in east coast rocks all the time.
    The i25 looks like an updated and lighter (500g vs 565 for the LD FR) version of the Laserdisc FR. I bought Alex Supra Ds to change a Mavic 521 on another wheelset, and it feels cheap and didn't build up as nice as the WTB.
    I'd recommend the i25 without hesitation.
    i haven't owned i23's yet but im doing new wheel builds (both on the endo, front on the chili, both on the podium) and have been round the houses. took a very long time to decide as usual ..to cut a long story short im waiting for the i23 koms or e13 tr race rims (both out end of this month, both alloy+scandium, both 400g each) for the endo. putting spank spike 28 evo race rims (whistler tough, 500g each) on the podium.
    Reputation: Calhoun's Avatar
    Nov 2008
    I have been riding the i23s for a while. They have been great for me. I am not the smoothest rider and put my rims into the rocks pretty often. The i23s have held up well to my abuse and I'll keep buying them. After two years I am on my second rear, but still the original front. I have had some burps, but really I think they were related to my bad luck with rear tires (see a pattern here?)
    The key is having a wheel builder that understands how you are going to ride the rim. I went through 3 823s in one year with a builder that built wheels the way he liked them. My builder now is very aware of the hell I put my rims through and maintains my wheels superbly.
    It is too bad that they hold up so well, I would really like to try the KOMs or even the i25s.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    formerly shabadu
    Nov 2006
    For those burping tires on Flows, could you please list the psi you think you were at? If using a digi gauge, lemme know.
    Thanks.
    FTR, I have a FlowEX on the front of my Endorphin after my i23 developed a bunch of eyelet cracks. No burps or issues running around 30 psi. I still have an i23 on the rear that has lasted over a year with a number of Enduro races and a general crapload of riding. I think I got my first good dent last weekend at the moab ho down.
    Next wheel build will probably be with the scandium wtb rims.
    release of the koms has been put off until feb here, cant wait that long, just bought a pair of standard i23's for the endo...
    Reputation: mr.bubbles's Avatar
    I know the quality and setup are top notch, and so easy. Used WTB tape and presta. No riding experience yet on the i23. They are going on my chili as soon as the frame shows up.
    The Green Bastard
    Jun 2014
    WTB I23/I25 rims-img_8980.jpgWTB I23/I25 rims-img_8981.jpg
    rim:WTB st i23 tcs
    spoke:Wheelsmith #14
    hub:Chris King ISO DISC
    tyre:WTB Vigilante TCS LIGHT 26x2.3
    I am ordering it now. Only the front wheel is completed.
    Delirious Tuck
    Reputation: thefriar's Avatar
    I ran the i25 on the warden all season, its got a hop my wheel guru can't get out, I wasn't gentle with it. No issues with bead slipping or clyde beating on it.
    I'll probably go i25 again or something blingy.
    Perpetual Hack
    Reputation: mykel's Avatar
    Have a pair of I25's sitting waiting for may lazy ass to lace them up for the Podium.
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    Reputation: PeytonP's Avatar
    I don't know much about wheel building and maybe you guys can help me out.
    My bike came stocked with i23 Frequency sets, but I'd like to run wider (2.35-2.5) tires.
    Would the Frequency i25 rims be interchangeable with my current hubs and spokes? That would be an insanely cheaper alternative to buying all new wider wheelsets.
    Jun 2014
    It has not been yet completed.
    WTB I23/I25 rims-p1010245.jpg
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    Quote Originally Posted by PeytonP View Post
    A FREQUENCY i25 will be a straight swap (same ERD).
    A KOM i25 or a ST i25 will not be a straight swap (different ERD).
    The noticeable difference will be null and not worth the hassle. Bang up your current rims and replace them when needed.
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
    WTB I23/I25 rims
    2mm makes all the difference. Just ask my Mrs
  1. Enve AM rims.....then the Derby non-HD 29er rims
    By westin in forum 29er Components
    Last Post: 10-14-2013, 07:58 AM
  2. Actual weight Enve 29 AM rims / Reynolds 29er rims
    By madskatingcow in forum Wheels and Tires
    Last Post: 10-10-2013, 12:51 PM
  3. The New Carbon Rims vs Surly Rims For Offset Use?
    By Sand Rat in forum Fat bikes
    Last Post: 10-06-2013, 11:08 PM
  4. Replies: 5
    Last Post: 03-04-2013, 08:07 AM
  5. Replies: 5
    Last Post: 03-29-2011, 03:02 AM
Members who have read this thread: 4
