Results 1 to 58 of 58
    Knomer
    Reputation: Dusty Bottoms's Avatar
    What is that thick/foamy frame protection?
    Hey peeps,
    I'm wondering what we call that thick/foamy adhesive material that some of you use for frame protection on chainstays and underside of the downtube. I've done searches for wind/surf/SUP deck grip and it gets me in the ballpark, but those usually come cut into specific patterns, where I'm really looking for a roll of it, hopefully 3 inches wide and BLACK. Ya know?
    I ride thru a lot of loose shale in my 'hood and get more than the occasional kick-up to the DT. 3M clear bumper tape protects from scratches and paint flakes, but isn't thick enough for more aggressive hits. Help me out, thanks!
    Director of Sales: Knolly Bikes
    Hmm, I can't recall off my head, but I know what you are talking about.
    Doesn't 3M make some really thick clear stuff, similar to what they make for helicopter blades? I thought I saw some a few years ago when I bought some of the normal 3M for my Highline.
    Quote Originally Posted by Dusty Bottoms View Post
    Hey peeps,
    Frame defender? Thats what I've always used. Comes in a variety of colors.
    Knomer
    Quote Originally Posted by bigmountainskiercfg View Post
    Pretty freakin' cool to google search "frame defender" and see a KNOLLY PODIUM come up in top results....
    https://www.google.com/search?q=fram...hrome&ie=UTF-8
    Thanks.
    Reputation: Dude!'s Avatar
    On the downtube - I use two layers of clear 3M
    Reputation: VuDoo11's Avatar
    May 2012
    I don't know about foamy, but I use water resistant electrical tape stuff on my chain stay. It is made by scotch and is more like self sealing rubber. It is about 1mm thick and 1.5in wide. When you stretch it and overlap it it bonds to itself and won't stick to your frame of you decide to take it off. You can get it in home depot for $10 for a roll.
    Quote Originally Posted by VuDoo11 View Post
    That stuff works epically well on chain stays I agree, been using it for years. But if all Dusty wants to cover is the downtube, I don't think it will work.
    Knomer
    The 'shelter' tape looks interesting, anyone know if it sticks well to anodized frames?
    Quote Originally Posted by rugbyred View Post
    It sticks quite well to my raw frame. I think it should have no trouble with an ano frame. Just make sure it is nice and clean prior to application.
    Eric
    Dusty, I find this works well Frame Wrap - www.biketart.com
    Perpetual Hack
    Reputation: mykel's Avatar
    Couldn't find it on their site, but I got some from go-ride a couple years ago.
    it is a rubber strip with strong adhesive on one side.
    Give em a shout
    michael
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    Reputation: rdhfreethought's Avatar
    1. Prep frame
    2. Apply Sorbothane (Sorbothane Sheets - 12" square, 1/8" thick | Edmund Scientific)
    3. Apply Kevlar 49 4H or 2x2 weave, or similar aramid tape (ACP Composites - Large Stock of Ready to Use Composite Plate, Tube, Sheet, Fabrics and Core Materials.)
    4. Apply single layer of carbon fiber
    Use a quality epoxy and hardener, vacuum bag, and you are good to go.
    Setup cost is only expensive if you consider the vacuum pumps. You can avoid that by using a compression tape method.
    Give me a few weeks and I will show you the results.
    Regional Race Manager, Knolly Bikes
    Washington, Oregon, Montana, Idaho, Wyoming
    Reputation: Bullit_cn's Avatar
    I use 3M antiskid tape for the down tube. it has water resistant adhesive so it sticks a long long time...
    When trails gets tougher, Just stand up and deliver.
    fat & decripit old guy
    Mar 2011
    What is that thick/foamy frame protection?-cover-up.jpg
    If you need something now you can always go cheep and change it later.
    Reputation: Dominator13's Avatar
    I'm using Frame Defender right now and it seems to work well. It gets chewed up quicker than the 3M Mastic tape. The 3M Mastic becomes part of your frame. It is, actually, hard to get off your frame. It is pretty awesome stuff and I will be using it once I go through my frame defender.
    "You don't stop playing because you get old, you get old because you stop playing!" - Unigeezer
    Aqua installed jet ski decking on the downtube of both of my Knollys.
    +1 for shelter frame protection tape - best out there - imo.
    Dusty,
    The funny thing about the frame defender is that on the "Installation" page, it looks like they're using a Chili or an Endorphin outline for diagram. I don't have any bikes with the smaller 4x4 linkage (only a Delirium), but it sure looks like one of them to me !
    Installation | Frame Defender
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    Dusty,
    Some time ago there was a similar thread on which you suggested some NASCAR tape. Is that not thick enough? (I tried contacting them several times and left messages but never got a call back.)
    "sounds like you need to find a better mechanic..." -- Calhoun
    Knomer
    That is correct, not thick enough to prevent dings.
    Quote Originally Posted by TSC View Post
    Dusty,
    Jan 2009
    dusty.....
    what about these.
    Rockguardz - Real Carbon Fibre MTB Rock Protectors
    maybe you could contact them with specific knolly measurements and get some into production for various knolly frames.
    Reputation: alfredo's Avatar
    this one looks good. saw it on a bike and felt quite thick and good looking. i've ordered that an can post pics when i have it with me.
    Lizardstore
    Reputation: nightofthefleming's Avatar
    Self amalgamating tape. Many brands make it, it's a rubber like tape that kind of melts together when wrapped over itself. Can make it as thick as you want and doesn't leave any adhesive behind, because there is none. Don't know if you can get it in 3 inch wide, but you can make it as wide as you want. Worth looking into
    2013 Medium Santa Cruz Blur Trc in Matte/Silver, full XT kit, 1x10 with 32T wolftooth ring, 25 pounds 7 ounces
    now i put that downtube protection from lizardskins on the frame and have to say that it doesn´t not only look good but als feels quite stable.
    have a look
    Attached Thumbnails Attached Thumbnails What is that thick/foamy frame protection?-p1120763.jpg
    What is that thick/foamy frame protection?-p1120764.jpg
    What is that thick/foamy frame protection?-p1120765.jpg
    Reputation: KRob's Avatar
    Looks good. I tried to order some but the transparent version wasn't available.
    Gonna go 3M tape for now and an old tube for the chainstay....as those things are readily available.
    Isaiah 58:14
    www.stuckinthespokes.com
    ^ is that leather or real carbon fiber?
    Regardless it looks pretty good. I presume it has a self backed adhesive? Or, did you have to use your own adhesive?
    it's leather in carbon look. it has a self backed adhesive. sticks good, but i think it still has to go through the "real world" before i can give it a "passed".
    Quote Originally Posted by alfredo View Post
    I assume it's preformed to fit the down tube. Looks like it fits really well. Is it frame-specific?
    Isaiah 58:14
    Reputation: Calhoun's Avatar
    Nov 2008
    I think its just very pliable.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    TSC
    TSC is offline
    Buehliever
    I have had Lizardskins clear on my Chili since the beginning. You really don't notice it. It keeps away paint chips BUT it won't do what Dusty is asking. A solid rock hit will dent the frame with the stuff I have on. To prevent a dent, like Dusty was talking about, you will need something that cushions the impact (like Frame Defender or an old bike tire) or something spreads the impact across a larger surface area (like carbon fiber or plastic).
    Quote Originally Posted by KRob View Post
    no, it's not preformed. i was also surprised how well it fits. it is neither frame specific.
    Quote Originally Posted by chris*tx View Post
    Agreed - I rocked the Shelter on my Derlirum and it was great. I could see several "scars" where it had taken big rock hits. I need to get around to protecting the chilcotin, haven't made time to put it on yet.
    Bonus: I even used it as a chainstay protector on the D.
    mlo
    mlo is offline
    Jan 2013
    A frame I bought had the mastic tape that some have suggested. It was about in need of replacement and was a bit time consuming to remove, but not terrible. It left a bit of adhesive that came off fairly easily with some finish line degreaser.
    I may have to try the shelter tape to replace it when I get it built back up.
    Quote Originally Posted by mlo View Post
    The shop roll is a smokin' deal and isn't that expensive, fwiw/.
    Reputation: bubba13's Avatar
    3M Mastic
    Thanks for the tip on the 3M Mastic tape guys. I found a 2"x10' roll at Platt Electric for $25. It was very easy to install and the 2" width is perfect for the Knolly downtube.
    Attached Thumbnails Attached Thumbnails What is that thick/foamy frame protection?-001.jpg
    What is that thick/foamy frame protection?-002.jpg
    What is that thick/foamy frame protection?-004.jpg
    Portland Off Road Navagators
    Mar 2011
    Quote Originally Posted by bubba13 View Post
    That looks much better than a used tire like I put on my Chilli
    Reputation: 9iron's Avatar
    Jan 2013
    If you're looking for the neoprene SUP type mat you asked about, go here Hydro-Turf-Performance Traction Products
    I buy blank sheets from them all the time. Textured, grooved and smooth. Conforms well and uses 3M adhesive for a strong bond.
    Reputation: mayha's Avatar
    Mar 2012
    Looks good bubba...I just got some 2x10 on ebay for $12 shipped to go on the black Podium.
    New in Its Box 3M Scotch Rubber Mastic Tape 2228 2in x 10ft | eBay
    TSC
    TSC is offline
    Buehliever
    Wrong thread. Sorry!
    Looks good Bubba. I might have to do this and order some for my Podium. Is the exposed side sticky?
    I use something similar to wrap my chain stays in, works great.
    Quote Originally Posted by rscecil007 View Post
    The exposed side is not sticky. I think 3m uses the wax paper between the layers in the roll to make it easy to use and keep the exposed side clean of adhesive.
    Ok great, thanks. I'll try to order some up off ebay like Mayha did.
    the lowest price i could find...I thought Amazon would offer the same, but nope!
    2" roll @ ebay
    sapienti sat est
    Reputation: BikeBert's Avatar
    Caution;  Merge;  Workers Ahead! 3M DI-NOC™ Carbon Fiber Vinyl
    It might not be thick or foamy but I went with 3M DI-NOC™. It actually features a carbon textured finish. It's not just a carbon pattern printed, this texture closely resembles the look of dry carbon fiber, the weave reflects light the same way that carbon fiber would.
    Properties:
    - Self-Adhesive using 3M Comply adhesive
    - Stretchable with heat
    - 12 year indoor lifespan and 4 years outdoors
    - Water resistant
    - Can be cleaned with soap and water
    So I ordered small piece of carbon fiber vinyl, grabbed scissors, hair dryer and few minutes later...
    ____________________
    | Picasa | YouTube | Pinkbike |
    Looks good!
    But does that actually have the same protective properties as carbon fiber, or is it just a vinyl wrap that looks like carbon fiber?
    sapienti sat est
    Looks good!
    With a raw frame I don't care if it's bulletproof or just a vinyl wrap. It looks good and that was my goal
    BikeBert
    Have you looked at Carbon Leather from Lizard Skins? Similar look but a bit thicker.
    Nov 2007
    thanks for some sweet recommendations!!!
    i personally use some carbon fibre-ish wraps from auto motive shops, they use it to wrap bonnets and boots, and what not here. it's about $10 for a meter by 40cm or so.
    but really like how the frame defender looks and will give it a try!
    What is that thick/foamy frame protection?-p4pb6899611.jpg
    check out great video coverage of anything mtb (well almost).
    http://www.mtbcut.tv
    Mar 2012
    Anyone know how these two compare?
    3m Rubber Mastic Tape 2228 (65mil thickness)
    vs
    3M Scotch-Seal Mastic Tape 2229 (125mil thickness)
    Similar price on Amazon.
    Reputation: Sleevem1's Avatar
    I'm using the using the Mastic 2228 tape and its holding out fine although I think I could have saved about twenty bucks and went with this method.
    What is that thick/foamy frame protection?-p5pb9597619_zps3b1b745f.jpg
    Mar 2012
    Quote Originally Posted by Sleevem1 View Post
    HAHA!! Someone's NOT proud of their Giant Glory!
    May 2005
    To those that use the 3M 2228 mastic tape: Is this tape also very sticky on the outside once applied to the frame? I used a mastic tape from a different brand which performs great so far, but due to it's sticky nature, it attracts dirt and debris very easily. I read somewhere, that one could use window cleaner to get rid of this stickyness, on my no name mastic tape it did'nt make any difference so far. How about the 3M 2228 mastic tape? Thanks in advance.
    The 3M Mastic tape is not sticky on the outside and remains reasonably clean.
    Reputation: vikb's Avatar
    The stuff we use on SUPs for traction is an adhesive EVA foam. It would definitely add some impact protection to the DT. It soft and has some thickness to it so you might not dig it from an aesthetic point of view.
    Cut Your Own
    I've used a thick [~2-3mm] thick clear 3M adhesive film to protect the headlight on my dualsport motorcycle and it worked great. I can't lay my hands on a link at the moment, but it shouldn't be too hard to find. Nice thing is from any distance you wouldn't see it.
    I like the carbon fibre product that's been posted above looks nice...
    Safe riding,
    Vik
    www.vikapproved.com
    Quote Originally Posted by vikb View Post
    Cut Your Own
    I put these on all my bikes after a heads up from Delirian (its his bikes in the pics): KNOLLY ...they clip on and clip off for cleaning, great product.
    Jan 2009
    yep the carbon rockguardz work great, and look good to. they give good protection, i have taped round the one on my endo to keep any grit from getting behind it.
    the carbon mudguardz work great to for those of you that are able to ride year round through the mud and slop. there was lots of interest in both products when we were in whistler.
    Reputation: Big B's Avatar
    Quote Originally Posted by Dominator13 View Post
    I use the 3M mastic tape ($12 for huge roll on eBay). One of the benefits of the mastic tape, is it helps hold your bike on the tailgate while shuttling around. It's sticky enough so that the bike doesn't slide side to side, but firm enough that crap doesn't stick to it.
    I was able to peel off a 6" section that was seeing too much wear from shuttling, and replace it without issue. The tape and adhesive came off my bike without too much trouble, just pulling on it by hand.
    '04 Knolly VTach | '15 Knolly Podium | '16 Knolly Delirium
Members who have read this thread: 32
