Results 1 to 9 of 9
    fat & decripit old guy
    Mar 2011
    What do you do when bored?
    My wife watches entertainment tonight. This means my nightly trip into my man cave/garage.
    I almost have all the items needed to do the switch to 10 speed. Looking at the gray Blackspire defender chain guard for my 2x10, I had a notion. Make it look purrrdy.
    A flapp-flapp sander to remove the anodizing, drill bits for holes, and a polishing wheel.
    All done with a cordless drill.
    I think that it looks better and is now a one off.
    What do you tinker with when bored/ exiled to the cave?
    Attached Thumbnails Attached Thumbnails What do you do when bored?-bash-guard.jpg
    Reputation: craigstr's Avatar
    Sep 2003
    Does that fit on the spider with a standard 26-39 or is that the spider used for the 24/38 option?
    Mar 2011
    It is the 26-39 spider-ring combo.
    Reputation: Calhoun's Avatar
    Nov 2008
    sadly I go out to the garage to work on something and end up drinking beer
    nice work though.
    Bandoleros Crew, NM
    Reputation: Bullit_cn's Avatar
    Nice job
    Same here, go to my bike room,
    fix something dont need to be fix,
    swap parts around and end up the bikes unrideable
    When trails gets tougher, Just stand up and deliver.
    Reputation: Sleevem1's Avatar
    Nice work man. Since my man cave is starting to get too cold I'm currently between wives I decided to exercise poor judgement and move my shop into my living room.
    Mar 2011
    Quote Originally Posted by Sleevem1 View Post
    I hope that there are no drill bits & cordless drills in the Knollys future
    Donkey Puncher
    Reputation: VanGor44's Avatar
    Damn thats a nice Chili....it looks somewhat...familiar...hmmm
    Mar 2011
    In the cave again
    This is for the minority out there cause I know that I am not the only one who runs Grip Shift.
    The length of the grips that Avid sends with the 10 speed shifters is way long but a good idea nun the less.
    Reviewers say that they can not be cut down...guess what!
    I was running ODI rouge grips cut down to fit my 10 speed shifters.
    Had the OEM grips that came with the Grip Shifts, so why not try to make them work?
    If I mangle them then no big deal cause I'm not using them any way.
    I have been running this mod for the last month or two with no problems.
    Not a computer guy, could not figure out how to properly set this up.
    Pic order:
    1) Before & after
    2) Transfer where the groves are onto the grips
    3) Cut down grip (I did 20mm)
    4) measure to cut the grove depth
    5) Cut groves
    6) Cut the rubber around the grip to the plastic
    7) Cut off the excess rubber
    8) How it should look after excess rubber cut away
    9) The grip plastic is thinner where it is cut down to so the lock ring has to be trimmed so as not to bind
    10) Tighten onto bar to make sure that enough has been trimmed off of the lock ring
    11)Careful to not trim off too much out of the plastic, just enough so the lock ring is snug on to the grip
    12) Before & after with the 20mm piece that I trimmed out
    Attached Thumbnails Attached Thumbnails What do you do when bored?-1-before-after-grip-shift-grip-mod..jpg
    What do you do when bored?-10-make-sure-enough-has-been-trimmed-off-so-collar-will-lock-grip-onto-bar-.jpg
    What do you do when bored?-11-carefull-not-trim-off-too-much-space-so-collar-will-fit-snug-grip.jpg
Hot Deals
Contests
Latest Mountain Bike Articles
