Results 1 to 29 of 29
    Dec 2008
    What chainring are you guys running for 1x?
    Looking at converting my xt double crank to 1x. Probably going to order a race face n.w. 30-tooth. I run a 36 tooth cassette and do quite a bit of climbing. Any words of wisdom?
    I run 2x10 but before on my other bike I was running a 32. I wasn't the strongest rider back then. Now though I would recommend a 34. I think 36 would be too much for me. It's possible but sometimes on those long rides it might be a bit too much.
    32T not feeling strong, 34T fit, 36T really fit, 38T hard man, 40T iron man, 42T superman. If in doubt start at 34T. Im using XX1, Race Face narrow wide, Chromag, North Shore Billet.
    Reputation: Calhoun's Avatar
    Nov 2008
    I have MRP, North Shore Billet and Wolf Tooth Components. They are all direct mount (SRAM specific.)
    What chainring do you find yourself in most of the time?
    I think 32t is a great starting point, but you should plan on ordering both a 30t and a 32t. Because only you will know what works best for you and having both will make it easier to compare.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Dec 2008
    Thanks guys. This will be my first 1x setup to I am a little nervous about giving up my 24-tooth granny. I live and ride on the North Shore and do lots of climbing
    I have a 32t/11-36 on the Chili, and the same on the Endo. Although I've really considering going 34 on the Endo.
    I am 34t/11-34 on my Endo
    Sep 2013
    Currently running a 33T Renthal ring but am going to move to a 34T RaceFace Narrow Wide in the next month.
    Knomer
    Reputation: Dusty Bottoms's Avatar
    I rock 34t on my 32lb Chilcotin with XX1. On a lighter bike I'd probably pull 36t, but if that bike had bigger wheels I would probably stick with 34t.
    Director of Sales: Knolly Bikes
    32/11-36 on my chili. There are some steeeeeep ass climbs near me.
    Quote Originally Posted by mrniceguy42 View Post
    AND you're a puh-c.
    34t with 11-36 on the Chili, 36t with 11-32 on the V Tach.
    Reputation: rdhfreethought's Avatar
    36T 11-36 on the Chilly at last years Knollfest and PNW riding. For Knollfest 2013 I'll be going 32T or 33T (I bought an odd Chainring size, because I couldn't decide between 32 and 34)
    Regional Race Manager, Knolly Bikes
    Washington, Oregon, Montana, Idaho, Wyoming
    Quote Originally Posted by B Gillespie View Post
    AND you're a puh-c.
    Hey, I am what I eat. Maybe if y'all had some real mountains around you, you'd run a 32t!
    Mar 2013
    I have 32T with 11-36 on my Chili. Looking forward to put a 30T instead, currently it's not low enough for me with the climbing I do.
    Dr. Pepper drinker
    Reputation: catch22's Avatar
    31t North Shore Billet direct mount with 11-36 for riding my 34 lb Chili all over UT and CO. Picked the 31t because it was the closest match in granny to the 22/26 gear I used to climb in all the time for really technical climbing down south and I didn't want to loose my tech climbing gear. 31 has worked really well for some of the looooong drawn out climbs in N UT and it's been fine for everything technical that I've run across down south. Narrow/Wide would be nice but I like the gearing on the 31 so I'm sticking with it for now.
    Sipping the Knolly Whisquillappa
    its good to put a bigger ring than you can manage from time to time so when you go back to the smaller ring its easier to put the power down...Ive got a spare 38 here for days when im feeling energetic...might end up having to push up a bit at times but you get a better workout,,,
    Dec 2008
    Quote Originally Posted by cfrench View Post
    I really don't like having to get off and push so I am going to start off with a 30 tooth and see how it goes.
    Reputation: 006_007's Avatar
    Quote Originally Posted by Dusty Bottoms View Post
    If it had bigger wheels.
    That was pretty subtle.
    As for the topic on hand I am pretty happy with the Wolftooth direct mount ring.
    Reputation: bionicman's Avatar
    XX1 here on 30lb Chilcotin
    run 30 for climbing stuff
    good compromise for TigerMtn climb & lack of fitness
    Perpetual Hack
    Reputation: mykel's Avatar
    32 or 34 tooth on the Deliriums
    36 on the Podium
    All are Renthal.
    michael
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    Reputation: jgusta's Avatar
    Quote Originally Posted by Skooks View Post
    Good idea starting with the 30T since the 30T/36 rear is a nice climbing gear on the steeps. I ran 2x9 (24/36T, 11-34) for last 9 years, then 2x10 (24/36T, 11-36) over past year (late 10spd bloomer) and just went 1x on my 32lb rig a couple of months ago and I do TONS of climbing to get the goods in PacNW as well. For desending, 32T would be ideal since I never used 36T w/11 rear, but I need at least 30T/36 rear to make all the climbs I do (did 7000ft of climb/descent on Monday and am still sore). As it gets easier to make all your climbs with 30T, then I would go up as needed from there.
    Ride On!
    Reputation: vikb's Avatar
    32T x 36T is my low gear with a 27" diameter tire. We have lots of climbs where I live in BC, but more punchy tech climbing than long consistent crank for 2hrs climbs.
    Safe riding,
    Vik
    www.vikapproved.com
    Jan 2009
    is anyone running a sram xx1 with a 10 speed mech and cass. does this work, or not recomended
    Works great.
    Quote Originally Posted by delirian View Post
    youll get the benefits of narrow wide on the front and less costly rear, its a winner.
    You don't need XX1 cranks to do this. Race Face has narrow-wide chain rings.
    Safe riding,
    Vik
    www.vikapproved.com
    Quote Originally Posted by vikb View Post
    the xx1 cranks are relatively cheap though...its the xx1 cassette and rear mech that's the expensive bit..
    deleted: wrong thread, was trying to post in another
    You can buy just the Race Face rings depending on the cranks you currently have.
    Safe riding,
    Vik
    www.vikapproved.com
  1. What are you 1x9 guys running for gearing?
    By Crash Dummy in forum Ibis
    Last Post: 10-05-2012, 11:13 AM
  2. What are you guys running for tires? XC/AM
    By five5 in forum Niner Bikes
    Last Post: 08-05-2012, 10:24 PM
  3. 1x10 - What chainring are you guys using?
    By L4NE4 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2012, 03:43 PM
  4. What Chainrings are you 2x9 Guys Running?
    By ferrstein in forum Fat bikes
    Last Post: 01-09-2012, 05:25 PM
  5. For you guys who like running BMX cranks (or ride BMX)
    By ISuckAtRiding in forum Singlespeed
    Last Post: 11-19-2011, 08:39 AM
Members who have read this thread: 4
