Results 1 to 6 of 6
    Hisforever
    Reputation: SHAHEEB's Avatar
    Dec 2004
    warden with a 150mm fork?
    Would this length fork be lame on the warden?
    I have a pike 150mm fork I could put on a frame I am looking at. I would sell it for a bigger fork but nobody wants to buy it.
    in the low/slack geo setting it seems like it would work for general / moderate all around riding.
    Jesus Saves
    It is an easy change on the pike to make it 160mm. Just need a new air shaft ~ $40
    Hisforever
    Dec 2004
    thanks alex will have to make that happen then.
    has anyone ridden the carbon warden and the insurgent back to back? wondering which one is more forgiving for DH?
    Jesus Saves
    Reputation: Dude!'s Avatar
    I think the Warden feels best with a 160mm fork in the steep setting.
    Reputation: David R's Avatar
    I've often wondered about this, would a 150mm fork in slack mode kinda be like an in-between the usual slack/steep? ~66* HA, ever so slightly lower bb. Hell, try it and see, as someone said the airshaft to bump it up to 160mm doesn't cost much...
    Aug 2015
    I have an MRP Stage set at 160 mm on my Warden. The A2C is roughly 10 mm less than other forks with the same travel, so, from a geometry standpoint, it's like a 150 mm fork. I'm set in slack mode, which, as David pointed out, puts the HA around 66* and the BB height a bit lower than the "standard" slack geometry. I like this setup but I haven't tried it with the fork at 170 mm so I can't help with any comparisons. It seems like a good middle ground for my local trails, which aren't too steep and scary.
  1. Wrong thread
    By Zerort in forum Lynskey
    Last Post: 01-15-2016, 11:27 AM
  2. fork length for Warden
    By Skooks in forum Knolly
    Last Post: 09-16-2015, 12:40 PM
  3. Fork to complement Warden/CCDBA
    By jiker in forum Knolly
    Last Post: 06-09-2014, 12:15 PM
  4. Fork for the warden
    By rookie nick in forum Knolly
    Last Post: 02-10-2014, 06:32 AM
  5. Warden geometry question w/160 fork
    By jgusta in forum Knolly
    Last Post: 11-25-2013, 11:43 AM
