Results 1 to 23 of 23
    Wanted: 7.875"x2.25" Fox Coil Shock
    Hey guys,
    You know the deal, looking for a 7.875x2.25 coil shock to send to Craig at AVY. If you guys have any spares laying around that you would be willing to let go I would would be interested in purchasing it!
    -Kyle
    Kyle,
    Put a wanted ad up here and on Pinkbike. They shocks will come out of the woodwork.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    I have a Van RC perfect for this. PM me.
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    VanRc or DHX will work fine either way
    Quote Originally Posted by KineticFear View Post
    Hey guys,
    -Kyle
    Quote Originally Posted by NoahColorado View Post
    Sweeeeet, PM sent!
    Pivoteer
    Reputation: tiSS'er's Avatar
    Sweeeeet, PM sent!
    You won't be disappointed.
    Employed by Pivot Cycles - www.pivotcycles.com
    Quote Originally Posted by tiSS'er View Post
    No sir, you definitely will not.
    Quote Originally Posted by rscecil007 View Post
    Third that
    Oct 2010
    Dear all,
    I may also go this way. Can someone explain what will be the real difference (I mean riding difference) between :
    1. Woodie
    2. DHX with Ava
    3. Van with Ava
    Thanks...
    Quote Originally Posted by gautama108 View Post
    Dear all,
    1. Woodie
    2. DHX with Ava
    3. Van with Ava
    Thanks...
    From experience, the only person on here who can explain that properly to you is the man himself, phone Craig Seekins at Avalanche Downhill Racing.
    Pivoteer
    Quote Originally Posted by cfrench View Post
    Agreed.
    I dont know if the OP got his hands on an AVY candidate rear shock but here's one on PB fully decked out. I have no affiliation with this person BTW, but its a good deal for a chili owner.
    2012 Fox DHX 5.0 With Avalanche Upgrade (7.875x2.25) - Pinkbike
    Quote Originally Posted by mrniceguy42 View Post
    Jesus, what a deal. If that guy's weight is close to yours where the valving would work, buy that thing STAT.
    Alright, so I got what I needed (aka that Avy tuned Fox on pinkbike). It was tuned for a 200lb rider and i'm about 190lb with my gear on so it should be sweet!
    What I need answered is the shock needs DU bushing, which ones to get? Also I think i'm going to need shock hardware because I don't think my DB Air hardware will work, is this true?
    DB Air hardware MIGHT work. I'd recommend the new Fox 5 piece polymer hardware though, really liking it so far on my 3 bikes. I'd go that way, and the each kit has the polymer bushing and hardware included.
    Those look nice, any idea on the sizes for Chili?
    Yes, you'll need to order them directly from Fox though I think. Does your Chili have flat rockers or the newer 3d ones?
    Just the regular flat rockers. I saw they have the 5 piece bushings on JensenUSA, I just need to know I have the right hardware lengths.
    Ok, you need the 21.8 M6 on the bottom, and 41.2 M6 on the top. Fox told me their part numbers were as follows:
    803-03-160 --> 41.15 M6
    803-03-143 --> 21.84 M6
    Hope that helps.
    Nice work KineticFear, you are gonna be more than stoked! Ti spring and extended reservoir is the icing on top.
    Yup, helluva deal.
    Nice to know Jenson carries that new bushing hardware too, nice find. For the longest time you could only get them directly from Fox.
    @rscecil007 Thanks for the measurements, ordered them already. Cost about ~$25 shipped for both
    @mrniceguy42 Thanks! I'm pretty stoked! Never had Ti spring before so it should be interesting. Has anyone tested an Avy shock with and without the reservoir, does it make a large difference in feel?
    Yup, helluva deal.
    I actually found ProBikeSupply carries them too. $4 cheaper than Jensen and Jensen said it usually ships in 1-2 weeks whereas I think they're in stock at PBS. Fox Rear Shock 5-Piece 6mm Mounting Hardware Kits - Pro Bike Supply
  1. Replies: 15
    Last Post: 09-11-2013, 09:00 PM
  2. Curnutt coil shock rebound "squeak"?
    By creyc in forum Foes
    Last Post: 02-05-2012, 11:06 AM
  3. Need a 7.875" x 2.25" rear shock, air or coil
    By morganfletcher in forum California - Norcal
    Last Post: 08-24-2011, 12:15 AM
  4. Replies: 4
    Last Post: 04-19-2011, 07:46 AM
  5. Replies: 7
    Last Post: 04-06-2011, 06:25 PM
