Results 1 to 65 of 65
    VITALMTB Reviewed the Chilcotin
    Here...
    They gave it a 60%...er, 3/5 stars.
    One negative made me laugh: "Low anti-squat numbers and some relatively slow rolling tires certainly didn't help in this area" - referring to the bike riding heavy...low-antisquat numbers is a feature, not a lack of one. I prefer to be able to tune my platform as I ride techy stuff.
    Grab your popcorn guys...
    Dr. Pepper drinker
    Reputation: catch22's Avatar
    Just saw that via Facebook and man, if that doesn't sum up why short term bike tests are completely worthless I don't know what will. I have no idea why you would want the slack setting for JEM or any of the riding around Hurricane (exception being the Virgin FR stuff). Moab, GJ/Fruita, Hurricane are absolute perfect in the steep setting, the low BB and slow steering would be bad news for riding down there. Also goes to show why I hate Fox shocks, they've been terrible since the old RP3. Put a Monarch or CCDBAir and the the Chilcotin climbs amazingly well for a true AM machine. Lots of 3000+ vert days on XC trails in Park City have proved that to me. When it comes to technical climbing the Chilcotin is flat out the best technical climber I've ever ridden.
    I blown away by their comments about the flexy rear end and high maintenance. The rear end of the Chilcotin is one of the stiffest laterally that I've ridden. I ride in the same dry desert conditions and never had bearing issues with the old Endo or Chilcotin, pretty much zero maintenance other than maybe an occasional dab of lube on the 4x4 bushings if they squeak a bit (haven't had to do that on the Chilcotin yet).
    Sipping the Knolly Whisquillappa
    Noel, time to up your advertising $ with Vital to get a better review.
    Pivoteer
    Reputation: tiSS'er's Avatar
    I just read it as well, and was a bit surprised when I saw the 3/5 stars, until I read it. It sounds to me like bike was way over gunned for the trail, and they made a point of it. I am also very surprised by the flexy comments. I don't think this is the case at all, and we ride some pretty chunky stuff here, and I am by no means a light weight. The creaky bearings might be an indication that something was loose, hence the flexy feel. My bike is dead silent, and I have never serviced the bearings.
    When I demo'd an Ibis HD, it creaked so bad I wanted to walk back to the shop. Not only did it bother me, but the guys I rode with were annoyed as well. Ended up being a loose pivot and rear axle. It was so bad, that the shop offered me a free day on the bike.
    Anyway, I wouldn't get all worked up over their comments. To each his own, the Chili is not for everyone.
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: Calhoun's Avatar
    Nov 2008
    Say what?
    Quote Originally Posted by VitalMTB
    Some slight pedal feedback was also apparent in bumpy terrain on flat pedals.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Pivoteer
    Quote Originally Posted by Calhoun View Post
    Say what?
    Uh Duh....it's the wicked amount of chain growth....
    That's just kidwoo trolling. Everyone knows _dw is the power-top over there.
    Nice KOM, sorry about your penis.
    it's the ride....
    Quote Originally Posted by B Gillespie View Post
    I don't think so. People who needed a bike with a class of Chilcotin will go here more than believing what a jurno -who didn't know what flex and pedal feedback means- wrote. Noel doesn't need to advertise his bike to get a good rep from a the media.
    Ulating blencong sejatine tataraning lelaku...
    Quote Originally Posted by softailteamrider View Post
    Guess I should have put a sarcasm warning on my post...
    All the good stuff:
    1) Nicely CNC'd pivot hardware, bottle mounts, the direct mount front derailleur, and a removable front derailleur cable stop if you should choose to run a chainguide.
    2) Cable routing is entirely external, and in general it's a clean setup.
    3) For those that run a dropper post, there are guides ready and waiting.
    4) One look at the Chilcotin and you know it means business.
    5) The Chilcotin was designed for the gravity-minded rider.
    6) A bike that's ready to be ridden hard down some hairy stuff.
    7) The leverage curve is pretty progressive, and the first bit of travel is tuned with traction in mind.
    8) The cockpit is comfortable, centered, and balanced.
    9) The reach is short enough to get the front end up with ease but long enough to feel relatively comfortable while climbing. Not too long, not too short... just right.
    10) A bike that's great for descents and comfortable at speed.
    11) It rode like a mini downhill bike, and the stable and relatively playful platform inspired a good deal of confidence.
    12) It allowed for a forgiving ride without any sketchy moments.
    13) Pulling up into a manual was easy and the progressive rear end offered good support, helping to make the ride pretty nimble.
    14) Changing lines was easy to do at all but the slowest of speeds.
    15) Much like the geometry, the suspension seemed best suited to the descents.
    16) The supple system performed well over small bumps, chatter, square edges, and jumps.
    17) The geometry didn't adversely impact climbing, and we think this was mostly a result of the suspension.
    18) Knolly frames are covered by a two-year warranty against defects and a three year crash replacement policy
    19) We found the Knolly Chilcotin to be a fun bike to ride when the going gets rough.
    20) We see this as a bike for the all-mountain adventurer looking to stand out and be little different from the herd.
    BEFORE READING ON, NOTE: We never had the chance to put the Chilcotin to use through the really hairy terrain it was undoubtedly designed for!!!!!!
    Notably, the Chilcotin is one of the only all-mountain bikes to retain the FOX 36 Float and 20mm front axle for 2013.
    This is something we can really appreciate, even though it adds a decent amount to the bike's overall weight.
    -- thats because the other so-called 'all-mountain bikes' they have reviewed are simply not as heavy duty as the Chilcotin.
    -- the chilcotin is all mountain / freeride bike.
    8 points of contention:
    21) It wasn't the most precise or responsive of all-mountain bikes
    -- they just needed wider bars and a shorter stem, they obviously havent read the chili build thread.
    22) We were still able to notice that the rear end wasn't as laterally stiff as we'd like, and flex was detectable in certain situations.
    -- not when i rode mine and the terrain was much harsher.
    23) Some slight pedal feedback was also apparent in bumpy terrain on flat pedals.
    -- it must be very slight as ive not encountered this yet.
    24) The FOX Float CTD shock performed capably in firmest of the Trail compression settings, and also helped to prevent a bit of bob that the bike seemed prone to.
    -- the bob was a failing of the CTD shock! its shite!
    25) Set to 30% sag and in Descend mode there was excess dive both front and rear over smallish drops and g-outs, so we'd suggest using a firmer Trail mode for most riding.
    -- again, i bought a knolly as i didnt want to buy a full build with CTD on it. Its shite!
    26) It didnt feel snappy
    -- ffs! its best as a 170mm bike, its not the endo!
    -- then they called the ride 'nimble', wtf?
    27) The weight of the bike and an active rear end make climbing and pedally trails a bit of a chore
    -- then they say...the geometry didn't adversely impact climbing, and we think this was mostly a result of the suspension...contradictory!
    28) The Four by 4 suspension design requires the use of several bushings and bearings, all of which need to be properly greased and torqued on a regular basis.
    -- im fine with that.
    MY SCORING SYSTEM
    21, 24, 25 and 27 are unfair so im clawing back the points. Add these four points to the 20 good points they gave and you get 24 out of 28 = 86% which rounded to the nearest half star is:
    4.5 stars
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    Here's your problem right here:
    We rode the Knolly Chilcotin on our first day in Hurricane, Utah. Being new to the area, the group chose the famous JEM Trail as our adventure and let 'er rip.
    It's your first day and your hardcore riders, ready to have some killer fun! So you hit "the famous JEM trail*" with a group of fellow riders on 29ers/650bs, riding on a trail that is best ridden on a 29er hard-tail, like in this video. Description & Video: JEM Trail
    In this scenario, I wouldn't like the Chili either (especially in slack mode). If OTE had sent them to Flying Monkey trail, then the Chili riders would have been stoked; and everyone else would have been a lot less happy with their rides. Even if they had waited until they discovered Grafton Mesa trail (and some of the "alternative" exits) then they would have appreciated the Chili more.
    *I've never figured out why it's "the famous JEM trail". It's one of the easiest, non-eventful trails I have ridden. IMO, JEM trail is easier than Bear Claw Poppy (another St. George area trail) and I've seen kids with training wheels (not joking) on Bear Claw Poppy.
    "sounds like you need to find a better mechanic..." -- Calhoun
    Quote Originally Posted by TSC View Post
    Yeah, thats it.
    For all their expertise, they didnt set the bike up right, tested it on inappropriate trails and bundled it into a classification that it isnt (Its AM/Freeride, not Trail/AM).
    When you look at Vitals better ratings recently they favour vpp bikes and i really didnt get on with vpp at all on the trails i ride.
    Also they recently rated the Commencal SX1 as a 3.5 when its an absolute diamond of a bike.
    Reputation: KRob's Avatar
    Yep. Nailed it. They chose the wrong trail to really get the gist of what the Chili is all about. On my Hurricane test ride last year I rode JEM too and it obviously wasn't its strong suit (HT 29er territory for sure) but even so, it did fine. Now on Gooseberry and Grafton Mesa it ruled!
    Must've been a wonky wheel, loose pivot bolt or something because the rear end is stiff. You can call the Chilcotin a lot of things... but flexy is not one of them. Not sure what they're talking about there. People who generally ride and prefer VPP or dw-link bikes will sometimes mistake that slight squat in a HL bike as flex or wallow. It's a preference thing and it certainly doesn't show its strengths best on a trail like JEM.
    Otherwise, fair enough review I suppose for the limited time they spent on it and for the trail they chose.
    Isaiah 58:14
    www.stuckinthespokes.com
    How are they even pushing the bike hard enough on the JEM trail to find out if the rear end is flexy? You should be able to ride a bike with the weakest of linkages and not have flex on that trail?!
    I have an endorphin and delirium t and they are the stiffest bikes I have ridden.
    Reputation: bionicman's Avatar
    Saw that review skimmed it over at first pissed then laughed then pissed again then like whatever
    These guys seriously don't have a clue! Lol must suck to be them.
    Rode gooseberry mesa with the Chilcotin. Then went over to check out Jem trail & guys at the trailhead unloading their full rigid 29ers giving me funny looks unloading my coiled Knolly day glo yellow Chilcotin about 5 minutes down the trail I knew why.
    Again must suck to be that ignorant about bikes in general.
    TSC
    TSC is offline
    Buehliever
    I don't think anything was intentional; and the riders appear to have the skills. I asked a few questions in the comments section that exposed a couple of the problems: 1) the JEM trail "system" is the only place the Chili was tested; and 2) they tested well-used, rental Chilicotins versus new bikes.
    frenchcr said it well, "Its AM/Freeride, not Trail/AM." IMO, most of the established trails in the St. George area are best ridden on either a new Endorphin (Goose, Zen, newly-revised Grafton, etc.) or a new Podium (King Kong, old Redbull Rampage area, new Redbull Rampage area). Nephi's Twist, AMA, and some new exits from Grafton are the only trails of which I can think of that might hit the Chili's sweet-spot--all require some decent suspension; but you need a bike you can pedal if you don't want to hike-a-bike.
    Side note: I've read that Flying Monkey is taming down to Chili-level difficulty if you walk a section or two.
    FTR: I've never ridden Nephi's Twist, Flying Monkey, King Kong, or the newer exits from Grafton and I probably won't until I get better control of my nerves and better at riding skinnies. All of these trails have severe penalty points--50+ foot falls--for missing your line.
    Ok fair enough - so tell me
    If I were to "review" a 1974 Buick station wagon at Laguna Seca raceway & bash it for handling like crap is that accurate?
    Sent Vitalmtb a link to this thread, let's see if they have the balls to reply.
    Hey guys, lets not get to bent about one review. Some people just like vpp and dw link bikes. I don't know why personally but that doesn't make them bad bikes. I know that if I were to do a review of a vpp or dw bike, I'd be saying things that I don't like about it but I represent myself and no one else. Maybe these guys just have said what they wanted to which is they prefer vpp bikes and that would be fine. Really the only thing to fault them on is when they say the rear end is not stiff which Krob made a great point as to why they might have felt that. They can ride mine anytime and see if mine is flexy too? Or if anyone of you live near vital HQ, take yours by and offer them another ride on proper terrain.
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by bionicman View Post
    My guess is that if any Chili riders with local trail knowledge were there, then the review would have been different (also, the bike setup); but that's not the fault of the reviewers. There is no conspiracy. They took what they were given and evaluated it to the best of their abilities. You can't fault them for that. If you're going to be upset, pick a different target for your hostilities (have you kicked your dog lately? J/K ).
    For perspective; the Chili review was part of the:
    2013 Vital MTB Trail Bike Test Sessions, That's a Wrap
    What do you get when you take 22 trail bikes, 5 test riders and 47 pounds of peanut M&M's into the desert near Saint George, Utah? You get the 2013 Vital MTB Test Sessions.
    2013 Vital MTB Trail Bike Test Sessions, That's a Wrap - Features - Vital MTB
    You've got to consider:
    • 5 test riders had to test 22 bikes in a limited amount of time so no in-depth testing was possible (i.e. no multiple days, multiple trails, and days for fine-tuning);
    • they didn't know the area and someone probably suggested the JEM trail system (UtahMountainBiking.com calls it a "classic");
    • you are not going to test every bike on the same trail (riders are going to want variation); and
    • everyone has their own likes and dislikes.
    After looking at the other bikes tested, I think the new Endorphin would better fit their definition of a "trail bike". My guess is that the Chilcotin wasn't part of the original lineup. (OTE, probably offered the Chilcotins to test; and that day happened on a JEM trail day.)
    Probably the most constructive thing to do is feel sorry that the reviewers wasted time on JEM trail (regardless of the bike), with so many good trails in the area; and feel sorry for Noel that his baby was the body builder at the Miss America pageant--so out of place!
    Mar 2013
    No its a little bit more than that man, there is a few inconsistencies and hypocritical statements, not to mention (what I found ridiculous) putting it in slack mode and "forgetting" about it!? If the trail is not presenting any ordeal wouldn't you change the bike settings since it has that option so that your review may better reflect the circumstance/situation?
    I think the best description of that review is sloppy, unbalanced and dare I say rushed?
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by ISharted View Post
    I was going to put an "edit" in my last comment but this is a better place. It does look like the Chili got the least saddle time by far. Most of the other bikes had significant saddle time on multiple trails, while the Chili was ridden on "the famous JEM trail" and that was all*. They probably shouldn't have included the Chilicotin in their review without comparable ride time on other trails.
    *My OTE loaner-for-a-day theory is getting stronger. I'm not trying to bash OTE. I bet they were trying to do Knolly a favor. I'm just seeing it as a reason that the Chilcotin wasn't given more of an equal chance.
    Dr. Pepper drinker
    I think that is my main contention with the review as well. With all the hype over slack bikes it seem like they just got lazy and said, slack is better mmmkay and stuck with that when in no way could it ever be better on that kind of trail. They even make mention of how easy it would be to change settings but didn't bother to do it? Why Not!
    I basically have one bike I ride for everything and mine stays in steep mode 95% of the time (nothing outside of a bike park day will get me to change it up). I'll actually argue that the Chilcotin covers the 'Trail' category much better than most give it credit for but definitely not in slack setting.
    Basing a review of a long travel bike in a slack setting on an XC trail just isn't time well spent and is really doing a disservice to the brand. The point they make about this being the first bike they rode there because all their test bikes were being shipped/arriving/getting built, etc. doesn't make posting a half assed review okay. For some reason I don't think they would have posted such a review up if the only thing they had to ride was a carbon V10 on JEM.
    Dr. Pepper drinker
    I'm sure Quentin just hooked them up with a demo to ride when they got in town while they waited for bikes to get built. JEM is super easy to access from OTE. I don't think much of the high country stuff on the Mesas was rideable when they were there either.
    It's lame that Vital kept posting stuff like this via facebook while the tests were rolling Photo by vitalmtb • Instagram showing off the hucking abilities of the Niner RIP9 RDO on one of the most drop and jump filled trails in StG. Why not take the Chilcotin there in terrain it's intended for and ride the Niner on JEM?
    fat & decripit old guy
    Mar 2011
    The one comment that I did agree on was the "it was not very snappy". I like the way my Chilli acts like a tractor up the steepest of climbs.
    No wheel spin, even in the winter mud we get here in the Vancouver area. My other bikes that I have owned had the "chain growth" issue and could not climb the way my Chilcotin does.
    Maybe IT IS the tremendous amount of frame flex that allows it to climb so well?
    Look, I'm not on board with Knolly World domination. In reality if every review was glowing, and Knolly's started popping up everywhere with folks on them that have no Idea of what they are capable of...then I'd be a lot more pissed. Facts are now is that I showed up to Knollyfest in December with a great bunch of dude with incredible riding abilities. the most incredible thing about it was the group speed. there were no wannabes in the group. Now if Vital, Mounatin bike action, and bike all start praising Knolly,.... then what...... Can you imagine a future Knollyfest were the importance is placed on lodging and restaurants over trail selection. (thanks again Tiss'er)
    I want Knolly to be as successful as can be but I surely don't want them to be over hyped and have a bunch of idiots that can't ride a bike on them because the mags say it's cooler than their ellsworth, ibis or whatever was cool in their neighborhood. (truth is, the chilly is more bike than 80% of mountain bikers can handle)
    the bottom line is Riders looking for the highest quality and most capable bikes will always find them regardless of reviews. Everyone of us is Knolly's strongest advertising. If you are at a trailhead and someone want to know what a Knolly feels like, let them ride yours and see what they think..... mine are always available to anyone!
    Nov 2008
    Quote Originally Posted by pfarrell View Post
    Exactly.
    -cabra cadabra
    Guys, relax. I love my bikes, but I love them because they work for me. Who really cares what some reviewer on VitalMTB says? Be happy with what you have and go ride.
    ...im forever blowing bubbles...i cant stand it when people just make statistics up like that...then to precede it with 'truth is'...
    Still haven't read the thing, and I'm 80% sure that's not gonna change.
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by frenchcr View Post
    Truth is that 97.84% of made-up statics are untrue, unless they are true. In that case, only 47.23% pass a sheer scrutiny test without some turpitude.
    Namaste Be-ACH!
    Seriously, there are certain times not to get your panties in a wrinkle; and this is one of them. pfarrell was trying to help or he was pissed. In either case, instruction (especially in the form of derision) is NOT helpful or appreciated. (Take this entire post as an example of what not to do. )
    And, if calling pfarrell out is your way of venting your anger/frustration then it's not productive. Go drown some kittens instead.
    Just roll it......
    Reputation: ebxtreme's Avatar
    These kinds of reviews don't get me upset at all. I think their review is completely appropriate considering the ride they did and how they were viewing the bike.
    The Chilcotin is at the burly end of All Mountain...we all know that. It's a stout frame that can take a beating. With a decent build, it's 30-33 lbs. depending on component choice and, IMO, it's not gonna keep up on uber smooth trails with guys on xc bikes. I'm fine with lugging it up big climbs knowing that it's gonna rip on descents - which it does!
    Also, I'll stick to my guns that, other than uber buff climbs and fireroads, I don't like to pedal this bike in slack mode....I just get way too many pedal strikes on our climbing and xc trails in Bellingham. While I do LOVE it in slack mode for jumpy/bermy stuff, I'm too lazy to swap it around and ride it 90% in steep mode - even on some of our more rugged FR trails. We just rode the Shore a couple weeks and I left it in steep mode and still didn't have any issues going down some gnar rock lines.
    I don't get pedal feedback on climbs - one of things I love about the bike - and haven't even felt a hint of flex in the back of this bike, so I'm guessing the demo bike might need some love.
    EB
    formerly shabadu
    Nov 2006
    Question the test trail, the mechanical condition of the bike ( maybe the r. wheel needed some tension...also I think someone here was spot-on when they suggested the activeness/wallow may have been felt as 'flex', especially on buff trails), but don't question the integrity or skill of the reviewers. Matt and Jess could ride circles around each and every one of you.
    Also, Vital gave 5 stars to the Stumpy Evo. Not a dw or vpp bike. Jus sayin.
    Were there issues with the way the review was conducted? yes. Were there nuggets of truth in that it isn't the quickest pedaling or handling bike out there? I'd say so.
    For the record: I sold my Chili and am waiting for an Endo, basically for similar sluggishness issues they mentioned.
    Namaste Be-ACH!
    you're a twat
    Truth is my bearings are creaking after one ride, my rp23 is off for warranty repair (at my expense) and my frame wasnt straight on reciept.
    I havent had an apology yet...just...OH IT COULDNT BE OUR FAULT.
    The 'sun does not shine out of Knollys backside' like some would have you believe.
    But the Chilcotin is a good design and so ill take care of the problems that i shouldnt have had to take care of myself.
    Just roll it......
    Flowtron, I completely agree with this and one really has to look at a bike's intent. It isn't the fastest pedaling bike ever and if you're looking for something "snappier", then the endo or another bike is more appropriate. I'm 100% ok with that for a bike I can take on a burly 6 hour ride and still hit 30 foot jumps and shred gnarly descents. This bike is easily more capable than what any of my old freeride bikes with 10 pounds less weight....the model of versatility! I'm planning to do a couple of enduro's this year and I know I'm gonna suffer a bit on the (un-timed) transition stages, but I'm stoked to rip the descents on this thing. The Endo is probably a better bike for those races, but the Chili is the perfect bike for my typical trails.
    Quote Originally Posted by flowtron View Post
    Actually, I don't think riding it in slack mode on JEM would be a problem at all. Mine does great on fast, smooth, flowy, bermy trails like that in slack mode.... in fact, I almost prefer it. The lower BB really makes it rail that stuff and you're not steering with the bars in that situation much so the slackness doesn't affect turning.
    Agree with EB that I'd rather have it in steep mode for steep, chunky, more techy climbs and it loses only a little confidence on the same trails going down. Also prefer 67 degrees for slower, twisty, tight trails.
    Isaiah 58:14
    I'm sure announcing on a message board you have "problems" instead of contacting the company, and then expecting a courteous and timely response go hand in hand. Let me know how that works out for you.
    I'm sure they seem fast to you, slowtron.
    Quote Originally Posted by KRob View Post
    Hahahaa! Any bike that isn't broken down can work fine on that stuff!
    you're a twat
    Lemme try:
    Truth is 'at 97.84% ay made-up statics ur untrue, unless they ur true. in 'at case, only 47.23% pass a sheer scrutiny test withit some turpitude. namaste be-ach! serioosly, thaur ur certain times nae tae gie yer panties in a wrinkle; an' thes is a body ay them. pfarreel was tryin' tae help ur he was pished. in either case, instruction (especially in th' f'rm ay derision) isnae helpful ur appreciated. (take thes entire post as an example ay whit nae tae dae. ) ain, if callin' pfarreel it is yer way ay ventin' yer anger/frustration 'en it's nae productife. gang droon some kittens insteid.
    Quote Originally Posted by Mrwhlr View Post
    Lemme try:
    Ive updated my avatar in reflection of this post
    TSC
    TSC is offline
    Buehliever
    you're a twat
    Twat did you say; as in, "I twat I dwownd da baby puddy tat"?
    I think you've said elsewhere that you're a non-native American speaker, so pardon my upcoming clarification if I'm mistaken. The word "twat" is an interesting word. You used it absolutely correctly. It does have a rarely used meaning of: "a man who is an incompetent fool". That describes me quite well. However, it has a strongly derisive meaning; so you should probably use it sparingly and only over the internet where the person you are addressing doesn't reach out and "touch you".
    Of course if you meant to call me a twat, as in "an obscene term for a female's genitals", then I'm fine with that too as long as I'm not the twat of that fat, hairy, ***** you call "mommy". (BTW, she's never looked so good as in your avatar. Be sure to compliment her on her plaid skirt.)
    Seriously*, you provided me with my biggest laugh of the day. Thanks for that! (*Seriously, why do I type "seriously" when the truth is that 23.4% of the time I type it when I'm not so serious?)
    BTW, give Knolly some slack for a bit. Cavan is finishing finals and then they will be more responsive. I don't know if they will grovel like you want; but they will set things straight.
    Mar 2013
    My gripe I guess was more towards the article itself. Now iv'e read some great reviews from VMTB but that one just lacked any real substance and which is why I felt it was rushed. There are plenty of us that don't get the test ride opportunities that others are able to get so being able to "armchair test" is a valuable resource.
    The contradictory nature of the article was confusing so if one was researching the Chilli it is reasonable to think the reaction would be "moving on!". Lets say this was the next review you came across, now you would really be in a quandary although from what I have read here it appears to be far more accurate and far less contradictory. Tested: Knolly Chilcotin | Flow Mountain Bike I expect we will see a few more Knolly's here in Aus soon. (I have no affiliation with this publication)
    Reputation: craigstr's Avatar
    Sep 2003
    Pass the popcorn!
    Quote Originally Posted by craigstr View Post
    Pass the popcorn!
    Hey Craigstr, Remember when the Knolly Forum was an oasis of sorts full of nice people sharing info and stoke of riding their bikes. TRUTH IS, it was way more fun 100% of the time back in the day when you, dominator, woodyak and the like dominated these post with useful info. so sad now
    Mar 2013
    WTF!? So typical.
    TSC
    TSC is offline
    Buehliever
    Ouch! I think I just got thrown under the bus by the person I was defending.
    Pass the popcorn!
    I wonder if frenchcr realized that he started a game of the "the dozens". The Dozens - Wikipedia, the free encyclopedia
    TSC
    TSC is offline
    Buehliever
    Thanks for the article!
    Sep 2003
    Yeah, those were the good old days.
    You just can't hack it, Terry Pratchett.
    ..is that how you play 'the dozens' TSC??
    RideDirt
    Reputation: aedubber's Avatar
    LOl Vital can suck it nice and easy ... Flexy ? This frame is stiff as **** . Anyways lets talk about something important .
    TSC - Stop being a tool man , seriously ... Thanks .
    Perpetual Hack
    Reputation: mykel's Avatar
    3D forged Link?
    Sorry, couldn't resist.
    michael
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    [QUOTE=TSC;10328039]Ouch! I think I just got thrown under the bus by the person I was defending.
    Not throwing anyone under the bus, I just long for the days when this bike forum was about bikes. It should always be about bikes and not personal insults. No reason to get mad when someone doesn't like your bike. People are allowed to not like your bike. People should be allowed to say what they don't like or whats wrong with their bikes without personal attack. I just want it to be about bikes instead of who's a *****, twat or whatever... I Hope we are all a little better then that in reality, so for the love of bikes, let's all keep are personal feeling for others to ourselves.
    Cheers,
    Pete
    Pivoteer
    Memories
    <a href="http://www.flickr.com/photos/tisser/8260126766/" title="IMG_8176 by tiSS'er, on Flickr"><img src="http://farm9.staticflickr.com/8222/8260126766_a26cf4bb6f_b.jpg" width="683" height="1024" alt="IMG_8176"></a>
    <a href="http://www.flickr.com/photos/tisser/8259069771/" title="IMG_8032 by tiSS'er, on Flickr"><img src="http://farm9.staticflickr.com/8497/8259069771_65c8f2670b_b.jpg" width="683" height="1024" alt="IMG_8032"></a>
    <a href="http://www.flickr.com/photos/tisser/8259071039/" title="IMG_8027 by tiSS'er, on Flickr"><img src="http://farm9.staticflickr.com/8489/8259071039_536d58ab44_b.jpg" width="1024" height="683" alt="IMG_8027"></a>
    <a href="http://www.flickr.com/photos/tisser/8260144134/" title="IMG_8010 by tiSS'er, on Flickr"><img src="http://farm9.staticflickr.com/8349/8260144134_f73f721806_b.jpg" width="1024" height="683" alt="IMG_8010"></a>
    <a href="http://www.flickr.com/photos/tisser/8259085321/" title="IMG_7937 by tiSS'er, on Flickr"><img src="http://farm9.staticflickr.com/8503/8259085321_e384772ced_b.jpg" width="1024" height="683" alt="IMG_7937"></a>
    Reputation: woodyak's Avatar
    [QUOTE=pfarrell;10329107]
    Cheers,
    Pete
    Everything you said about me is untrue. I hate you! You don't even like bikes or Knolly or whiskey. Go suck an egg!!!
    Now that thats out of the way I can continue my ride
    TSC
    TSC is offline
    Buehliever
    Cheers,
    Pete
    I agree. I was trying to be funny and got carried away. It happens when I'm sleep deprived--I think I'm funnier than I actually am. There are some days when I should just put my keyboard away; and yesterday was definitely one of them. Sorry.
    I'm with you on the slack mode. I actually rode it in steep mode for the 1st time about a month ago. While it was nicer to have a higher bottom bracket for chunky climbing stuff I preferred the handling of it in slack mode. I didn't really find that it peddled any more or less efficiently in either mode. That's what's great about this bike. You can set it up just the way you like it and it's still gonna rip. It's too bad the bike wallows so much, is flexy, is an inefficient peddler, and so forth...
    +1 for slack
    J:
    J: is offline
    i can smell yur litesaber
    Dec 2009
    tastey pics tisser..
    J:
    J: is offline
    Dec 2009
    Quote Originally Posted by Pinkbike
    Derka derp derka derka derp derp
    fukc
    [QUOTE=woodyak;10329765]
    HAHAHAHAHAHA and everything you say about me is true. I'm just a poser with cool bike drinking whiskey trying to get the cool kids to like me! Cheers and enjoy the ride!
    Reputation: thedeathstar's Avatar
    Mar 2012
    You are wrong. 160-170 mm of travel is perfect for these trails. That's why we ride Knolly, because it can still be hella fun on Hurricane Rim.
    There's a reason why a lot of the dudes at OTE ride Chilcotins and it's probably the same reason it's the bike they gave the reviewers.
    Mar 2012
    What the hell is wrong with you?
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by thedeathstar View Post
    You're the fellow that was positive that vitalMTB had tried the Chilcotin on trails other than JEM, when they hadn't. Now you're sure that I am WRONG when I said,
    "IMO, most of the established trails in the St. George area are best ridden on either a new Endorphin (Goose, Zen, newly-revised Grafton, etc.) or a new Podium (King Kong, old Redbull Rampage area, new Redbull Rampage area)".
    I did say it was "IMO" and since there is no arbitrator of truth in this case, I think that stating unequivocally that I am WRONG is bit strong.
    The one thing we know for sure: you are "confident" that your opinion is the truth. Myself, I'm not so confident. What I said was speculation, based on my feeling of being "over-biked" (i.e. I didn't need all my travel) on the trails I've ridden in St. George/Gooseberry Mesa area. The only trail that I saw mentioned in the reviews that I haven't ridden is Nephi's twist, so my opinion does have some basis to it. However, I don't have the new Endorphin and haven't ridden one so my speculation that the new Endorphin is a good match for the trails in St. George/Gooseberry Mesa area may be absolutely wrong.
    BTW, from your post on vitlMTB, I didn't get that you were a Knolly rider. Which Knolly bike(s) do you own?
    pfarrell, tiSS'er, or any of you that have both bikes; what do you think? Is the new Endorphin up to the trails in the St. George/Gooseberry Mesa area? I'm genuinely curious.
    List of trails I noticed that were ridden by the reviewers:
    St. George area
    --Barrel Roll
    --Grafton Mesa
    --Guacamole
    --JEM
    --Nephi's Twist
    --Zen
    Bootleg Canyon
    --Boy Scout
    --Girl Scout
  1. VitalMTB members, please like my bike
    By motochick in forum Downhill - Freeride
    Last Post: 11-15-2012, 06:30 PM
  2. Carbon goodies on Vitalmtb!
    By danglingmanhood in forum Downhill - Freeride
    Last Post: 02-18-2012, 10:45 AM
  3. Pivot 5.7 reviewed - Pinkbike
    By LeeL in forum Pivot Cycles
    Last Post: 12-08-2011, 10:24 AM
  4. Biggest trails ever. VitalMTB feature.
    By DHgnaR in forum Downhill - Freeride
    Last Post: 04-19-2011, 12:53 PM
  5. Ride in the snow vid (Austin) on vitalmtb
    By bitewerks in forum Texas
    Last Post: 02-21-2011, 08:11 PM
