Results 1 to 28 of 28
    Greystoke
    Reputation: geo025's Avatar
    Dec 2010
    Stealth Reverb for my Chilli
    The external cable from my dropper had to go & the Stealth was the way for me. I know there are other 150 dropper posts that attach by the seat collar, but I've had no problems with the Reverb in the past.
    No drilling required.....honest
    No more cable rub like this...
    sapienti sat est
    Reputation: BikeBert's Avatar
    New question here. stealth drilling
    I was about to start new thread about stealth drop posts.
    However, I am considering Thomson one which runs regular cable.
    Any thoughts on where I could possibly drill the frame?
    ____________________
    | Picasa | YouTube | Pinkbike |
    Reputation: string's Avatar
    If I am looking at the picture right you came out through the water bottle mount? Clever!
    How hard was it to make the bends and get the routing done? Any fit issues?
    How about a close up?
    Reputation: Calhoun's Avatar
    Nov 2008
    At first all I could think was that I hated that cable routing.... but I keep looking at it and thinking "maybe..."
    How long have you had it set up like this? A 150mm Reverb would be awesome, I love how the bar clamp integrates into my brake levers (Avid.)
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Reputation: KRob's Avatar
    How in the heck did you get that hose routed down the seat tube, up the downtube and out the water bottle mount hole???
    Isaiah 58:14
    www.stuckinthespokes.com
    Reputation: honns's Avatar
    Quote Originally Posted by KRob View Post
    Obviously. He is a cable charmer.
    Quote Originally Posted by BikeBert View Post
    IF YOU PUT A DRILL ANYWHERE NEAR THAT FRAME ......
    And what the f*** is wrong with cable ties these days!!
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    Quote Originally Posted by Calhoun View Post
    geo025 definitely has a great idea for the stealthy post crowd.
    Aesthetic options: try to put the dropper cable through the upper water-bottle screw hole and:
    1) run the dropper cable over the bottom cables going to the rear; OR
    2) clip one less clip on the top and have the dropper cable "drop" sooner.
    Either way might move the cable from your sight-line.
    "sounds like you need to find a better mechanic..." -- Calhoun
    geo,
    That's some creative routing!
    A quick note on cable routing for your other cables. The small cutout at the front of the seattube linkage is designed to be a spot where you can tie your rear brake and shifter to. It keeps the cables from getting caught up on the tire or your shoe if something unusual happens...
    If you want to protect the ano on the linkage you can use a piece of tubing as a spacer and run the zip tie through it.
    Greystoke
    Dec 2010
    Ok it was a fairly straight forward procedure but not my idea, I stole it off the Ibis forum.
    I never use bottles so the lower hole was what looked like the best option.
    I threaded a piece of 1mm copper electrical wire stripped back then hooked it onto the Reverb line (a little bit of patience along with a steady hand). Ive added some protection for the hydraulic line ( old hydro tube & high pressure plastic water line) in the seat tube & where it junctions the down tube.
    Where it exits the down tube I have another plastic sleeve with a very snug fit to help protect it from any leverage damage.
    No real world on trail rides yet so cant comment on durability... yet.
    Reputation: Krout's Avatar
    Anybody else try this? News on durability Geo?
    Reputation: bionicman's Avatar
    I'd be interested in durability too. I'm currently trying to clean up the cables/rub on the C & hate this unsightly cable to my seat RSLev
    Greystoke
    Dec 2010
    This is working out well , the only problem if you are considering this is would be any interference with the type of bike rack you have.
    On another note I've dropped the rear shifter & brake lines down as in pic , definitely helps with keeping the shifting smooth + my big feet no longer get tangled in them.
    Nov 2008
    Thanks for the update Geo!
    Next time you have the camera out could you snap some pics of how the cable enters the frame? Also did you use a stock Reverb hose-or an aftermarket hose? I have a replacement stock hose and the diameter is too large, wondering if there is another diameter that lends itself better to this application.
    BTW the down low routing on your derailleur/brakes looks stealth!
    -cabra cadabra
    I have to say that is the cleanest cable routing I've seen save internal
    Greystoke
    Dec 2010
    Here you go Calhoun, I used the standard Stealth line .
    You have to remove a water bottle insert. Some may not like doing this but I'm sure it wouldn't be an issue to get another one installed if or when you wanted to move the frame on.
    To get the bottle mounting screw out (it had seized in place on my frame). I had to wedge a screw driver under the water bottle screw to stop the insert spinning. This is made of a soft alloy that's crimped in place.
    After the wedging action on the insert I realized how soft it was so just knocked the top off the insert. You could also file the top of it carefully & put some duct tape over the area to stop any scrapes to the frame.
    If you have the patience you can get that loose remaining insert out via the seat tube.
    Then just thread apiece of thin wire (not too flexible) through the hole, you can hook it out via another wire from the seat tube & you have your draw wire in place.
    It took me half an hour.
    Perpetual Hack
    Reputation: mykel's Avatar
    Clean...
    michael
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    So fresh and so clean.
    That cable routing looks so good...if I had more time to tinker I might go that direction!
    Pivoteer
    Reputation: tiSS'er's Avatar
    Quote Originally Posted by geo025 View Post
    Nice Job. But if you want it to be super clean, I would run the hose on the down tube with the other cables rather than have that line running down from the top tube. Simply zip tie to the rear derailleur cable.
    Employed by Pivot Cycles - www.pivotcycles.com
    solved
    Quote Originally Posted by tiSS'er View Post
    omg! ..so obvious in hindsight.. i dont know how i didnt think of doing that before,
    Nov 2008
    Awesome. When I was messing around with the hose I have it looked like those threads needed to go in order to make it fit.
    I am wondering how much bend would be required to make that loop to enter the frame. But I have the time and material so I'll check that out.
    -cabra cadabra
    Greystoke
    Dec 2010
    Yes good call but I was worried about the bend being a little tight & getting kinked restricting the oil flow.
    I may have to take another look at that down the track....
    ... But I have the time and material so I'll check that out.
    Heal up amigo. Hope you are staying sane!
    Nov 2008
    Quote Originally Posted by CharacterZero View Post
    Thanks mang! Got the ok to road bike, beats riding the couch!
    -cabra cadabra
    Perpetual Hack
    Initially, I had the same thoughts, route down the down-tube.
    However it looks like it would be a bit too much of a tight bend - you are looking at 90 degrees and a probable line collapse at that angle
    ....not sure how that would work out....
    michael
    Hatched in 1964
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    si vis pacem...
    Reputation: Parabellum's Avatar
    Oct 2011
    Maybe this was covered in another thread, but what happened?
    Nov 2008
    dislocated shoulder, joint is still unstable so no MTB for a while
    -cabra cadabra
    si vis pacem...
    Oct 2011
    I feel your pain. Broke my left collarbone in early May - just about to get back on the bike this weekend.
    At least I've had some time to work on the bikes. This is a pretty slick way to mount a Reverb but I think I'm still leaning towards the KS Lev 150.
  1. Alloy Jet 9 with Reverb Stealth?
    By jbirkle in forum Niner Bikes
    Last Post: 01-21-2013, 10:41 AM
  2. Reverb Stealth and The One
    By TheRage43 in forum Canfield
    Last Post: 10-26-2012, 11:04 AM
  3. Reverb Stealth?
    By iRider in forum Intense
    Last Post: 08-11-2012, 09:24 PM
  4. Looking for someone with a Reverb Stealth!!!
    By hardtailkid in forum Scott Sports
    Last Post: 02-06-2012, 04:58 PM
  5. 'Stealth' Reverb?
    By Eric. in forum SRAM
    Last Post: 02-11-2011, 09:57 PM
