• 03-03-2013
    geo025
    Stealth Reverb for my Chilli
    The external cable from my dropper had to go & the Stealth was the way for me. I know there are other 150 dropper posts that attach by the seat collar, but I've had no problems with the Reverb in the past.
    No drilling required.....honest
    No more cable rub like this...
  • 03-04-2013
    BikeBert
    stealth drilling
    I was about to start new thread about stealth drop posts.
    However, I am considering Thomson one which runs regular cable.
    Any thoughts on where I could possibly drill the frame?
  • 03-04-2013
    string
    If I am looking at the picture right you came out through the water bottle mount? Clever!
    How hard was it to make the bends and get the routing done? Any fit issues?
    How about a close up?
  • 03-04-2013
    Calhoun
    At first all I could think was that I hated that cable routing.... but I keep looking at it and thinking "maybe..."
    How long have you had it set up like this? A 150mm Reverb would be awesome, I love how the bar clamp integrates into my brake levers (Avid.)
  • 03-04-2013
    KRob
    How in the heck did you get that hose routed down the seat tube, up the downtube and out the water bottle mount hole???
  • 03-04-2013
    honns
    Obviously. He is a cable charmer.
  • 03-04-2013
    cfrench
    IF YOU PUT A DRILL ANYWHERE NEAR THAT FRAME ......
    And what the f*** is wrong with cable ties these days!!
  • 03-04-2013
    TSC
    geo025 definitely has a great idea for the stealthy post crowd.
    Aesthetic options: try to put the dropper cable through the upper water-bottle screw hole and:
    1) run the dropper cable over the bottom cables going to the rear; OR
    2) clip one less clip on the top and have the dropper cable "drop" sooner.
    Either way might move the cable from your sight-line.
  • 03-04-2013
    BryanS.
    geo,
    That's some creative routing!
    A quick note on cable routing for your other cables. The small cutout at the front of the seattube linkage is designed to be a spot where you can tie your rear brake and shifter to. It keeps the cables from getting caught up on the tire or your shoe if something unusual happens...
    If you want to protect the ano on the linkage you can use a piece of tubing as a spacer and run the zip tie through it.
  • 03-04-2013
    geo025
    Ok it was a fairly straight forward procedure but not my idea, I stole it off the Ibis forum.
    I never use bottles so the lower hole was what looked like the best option.
    I threaded a piece of 1mm copper electrical wire stripped back then hooked it onto the Reverb line (a little bit of patience along with a steady hand). Ive added some protection for the hydraulic line ( old hydro tube & high pressure plastic water line) in the seat tube & where it junctions the down tube.
    Where it exits the down tube I have another plastic sleeve with a very snug fit to help protect it from any leverage damage.
    No real world on trail rides yet so cant comment on durability... yet.
  • 07-04-2013
    Krout
    Anybody else try this? News on durability Geo?
  • 07-09-2013
    bionicman
    I'd be interested in durability too. I'm currently trying to clean up the cables/rub on the C & hate this unsightly cable to my seat RSLev
  • 07-09-2013
    geo025
    This is working out well , the only problem if you are considering this is would be any interference with the type of bike rack you have.
    On another note I've dropped the rear shifter & brake lines down as in pic , definitely helps with keeping the shifting smooth + my big feet no longer get tangled in them.
  • 07-10-2013
    Calhoun
    Thanks for the update Geo!
    Next time you have the camera out could you snap some pics of how the cable enters the frame? Also did you use a stock Reverb hose-or an aftermarket hose? I have a replacement stock hose and the diameter is too large, wondering if there is another diameter that lends itself better to this application.
    BTW the down low routing on your derailleur/brakes looks stealth!
  • 07-10-2013
    bionicman
    I have to say that is the cleanest cable routing I've seen save internal
  • 07-10-2013
    geo025
    Here you go Calhoun, I used the standard Stealth line .
    You have to remove a water bottle insert. Some may not like doing this but I'm sure it wouldn't be an issue to get another one installed if or when you wanted to move the frame on.
    To get the bottle mounting screw out (it had seized in place on my frame). I had to wedge a screw driver under the water bottle screw to stop the insert spinning. This is made of a soft alloy that's crimped in place.
    After the wedging action on the insert I realized how soft it was so just knocked the top off the insert. You could also file the top of it carefully & put some duct tape over the area to stop any scrapes to the frame.
    If you have the patience you can get that loose remaining insert out via the seat tube.
    Then just thread apiece of thin wire (not too flexible) through the hole, you can hook it out via another wire from the seat tube & you have your draw wire in place.
    It took me half an hour.
  • 07-10-2013
    mykel
    Clean...:thumbsup:
    michael
  • 07-10-2013
    CharacterZero
    So fresh and so clean.
    That cable routing looks so good...if I had more time to tinker I might go that direction!
  • 07-10-2013
    tiSS'er
    Nice Job. But if you want it to be super clean, I would run the hose on the down tube with the other cables rather than have that line running down from the top tube. Simply zip tie to the rear derailleur cable.
  • 07-10-2013
    cfrench
    solved
    omg! ..so obvious in hindsight.. i dont know how i didnt think of doing that before, :thumbsup:
  • 07-10-2013
    Calhoun
    Awesome. When I was messing around with the hose I have it looked like those threads needed to go in order to make it fit.
    I am wondering how much bend would be required to make that loop to enter the frame. But I have the time and material so I'll check that out.
  • 07-11-2013
    geo025
    Yes good call but I was worried about the bend being a little tight & getting kinked restricting the oil flow.
    I may have to take another look at that down the track....
  • 07-11-2013
    CharacterZero
    ... But I have the time and material so I'll check that out.
    Heal up amigo. Hope you are staying sane!
  • 07-11-2013
    Calhoun
    Thanks mang! Got the ok to road bike, beats riding the couch!
  • 07-11-2013
    mykel
    Initially, I had the same thoughts, route down the down-tube.
    However it looks like it would be a bit too much of a tight bend - you are looking at 90 degrees and a probable line collapse at that angle
    ....not sure how that would work out....
    michael
  • 07-11-2013
    Parabellum
    Maybe this was covered in another thread, but what happened?
  • 07-11-2013
    Calhoun
    dislocated shoulder, joint is still unstable so no MTB for a while
  • 07-11-2013
    Parabellum
    I feel your pain. Broke my left collarbone in early May - just about to get back on the bike this weekend.
    At least I've had some time to work on the bikes. This is a pretty slick way to mount a Reverb but I think I'm still leaning towards the KS Lev 150.
