Results 1 to 68 of 68
    RideDirt
    Reputation: aedubber's Avatar
    Recommend me a crankset please ! :) on the chili
    So im REALLY trying to do a 1x10 setup once my frame comes in . I was thinking a 2x10 setup but i never really used the granny gear on my other AM bike and i was using a 36T chainring . I feel you guys would be more helpful here then another part of the forums
    So i was thinking a 32T chainring but what crankarms should i get that has the 73mmBB width ? My budget on the crankarms would be $500. Im really thinking about maybe some carbon crankarms or should i stay away from that?
    Again , this bike will be used for AM riding , i will try some lift assisted days on the NOT so rocky stuff but im sure by then ill prob be buying a downhill bike on the side .
    Im really trying to make this build my last AM bike that will be strong and not too heavy so i dont mind splurging a bit , i got plenty of time anyways till my right arm gets moving again.
    Running the Race Face SixC carbon cranks on both my Delium and Chilcotin. Work great. 73mm width is pretty much the standard and probably in excess of 99% of MTB cranks are that width. The only notable exception is 83mm cranks which are typically on DH and some FR bikes.
    RideDirt
    Thank you ! I was looking at those just wasnt sure .. Can i run it with any chainring or does it have to be strictly from raceface as well ?
    Reputation: 006_007's Avatar
    You can run it with other chainrings if desired.
    Pivoteer
    Reputation: tiSS'er's Avatar
    I much prefer the spindle interface on Shimano cranks. They are easier to get on and off. I thought I read somewhere that RaceFace was changing their interface though, but don't have any experience with it.
    XT cranks are the ticket for me. Super dependable at a good weight.
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: craigstr's Avatar
    Sep 2003
    XO's with a MRP bling ring and the race face end caps. Been running them all summer and love how stiff they are.
    http://www.mountainracingproducts.com/mrp/bling-ring/
    RideDirt
    Quote Originally Posted by craigstr View Post
    Mountain Racing Products home of MRP, White Brothers, Kreitler, Tamer, and Power Grips | MRP Bling Ring Chainrings
    Seems like the XOs have some nice low weight to them . I was planning on running an E-Thirteen chainring , i been using their stuff for a while so i love them . Hmm , this might be the winner for me here .
    Just FYI, my buddy just snapped one or two of his chainring tabs off his carbon RF cranks. And yes, he used the RF spacer/washer things under the bolts and they were torqued correctly.
    If you want light, XTR's are only a hair heavier than the RF. Sicklines say the RF are 492g, and the new XTR are 526g.
    I'm not ashamed to say carbon still freaks me out on a mountain bike. But then again, I run Saint cranks on my Chili....
    RideDirt
    Quote Originally Posted by rscecil007 View Post
    Good to know , i will keep that in mind . Is there some type of warranty that will cover him for just " snapping " his tabs? Im sure its going to be a PITA process ...
    Ha ! I wouldnt mind Saint cranks but they seem like they might be too heavy , i cant find out what their weight is
    Quote Originally Posted by aedubber View Post
    I'm not sure, but he's got them going through the RA process.
    Some weights, crank arms only, no rings, bolts, all 175mm:
    XT m780: 616g
    SLX m665 (version with steel pedal inserts): 640g
    Saint 810: 759
    At a minimum for me I'd run SLX for steel pedal inserts and the beefed up spindle over the SLX M660 version. But I like the Saints and honestly feel they are stiffer. Maybe it's psychological, I've no idea. But also I'm 215 geared up and tend to push taller gears, and don't spin a ton.
    Plus the Saints are black, so they have to be better right? LOL
    Edit: one more thing, the beefier the crank gets, the more spindle interface you get where the non-drive side crank arm slides on the spindle. Just estimating for instance, I'd say the XTR has about 1/2" of interface, the XT/SLX about 3/4" and the Saint almost 1.0".
    XT + Salsa chain ring --> more $ for lift tickets and beer.
    RideDirt
    Ok sounds good.. Yea im 200lbs myself and not the smoothest rider too lol ... Im going to keep my options open now i guess .. I think i just have a " carbon " kick going on lol , but ill have to really think about this..
    Yes lift tickets ! I had my season pass until i fractured some bones :/ now my season is done .
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    Slx m667
    These look killer
    Universal Cycles -- Shimano FC-M675 SLX Double Crankset - 10 Speed
    Delirious Tuck
    Reputation: thefriar's Avatar
    RF SixC - Been fine running on 2 years now including some lift serve, many pedal smacks in New England rock/granite garden riding. I'm heavier than most.
    XTR - Stiff, probably as light in a 1x as the SixC with booties on. Have Two sets of new XTR (1 3x and 1 2x) Happy as a clam as well. Have these on my Chili, no issues with 5 days of shore and whistler riding.
    Can't comment on X0.
    Shinobi-Wan Kenobi Moderator
    Reputation: kristian's Avatar
    Quote Originally Posted by 006_007 View Post
    Maybe... I was not able to run a Shimano chainring on my new RF Atlas cranks. The Shimano had more material surrounding the bolt holes than the a standard chainring and it wouldn't fit on the RF middle ring slot.
    For what it's worth, the 2012 RF interface was super easy--you just keep torquing until you bottom the bolt out (I used an old handlebar over my socket wrench for more leverage). The one time I needed to take the crank off on the trail was difficult, but I got it off with my multi-allen key tool so it is possible (although I had to re-tighten it when I got back home).
    I like the RF interface much more than the Shimano which tended to loosen up on me once in a while.
    Delirious Tuck
    I didn't know Shimano made backward compatible chainrings... I think the OP was asking about non-RF in the sense non-Shimano can be difficult with XTR level so can you run an e13/MRT/Homebrew/etc chainring...
    RideDirt
    Ya I would like to use my own chainring for a 1x10 setup etc since I don't really want to use a 2x10 setup .
    Reputation: Rock dude's Avatar
    This setup has worked out great!
    <a href="http://s204.photobucket.com/albums/bb68/chuckspartz/?action=view&amp;current=549044_10151316608609968_ 1914775644_n.jpg" target="_blank"><img src="http://i204.photobucket.com/albums/bb68/chuckspartz/549044_10151316608609968_1914775644_n.jpg" border="0" alt="Photobucket"></a>
    RideDirt
    Thanks rockdude!!! That looks exactly like something I want .. How many teeth is that ring on there ?
    That's a 32 tooth and 11-36 cassette.
    It's a little work on the long climbs but I'm getting there.
    RideDirt
    That's the exact same setup I wish to run , and hey it gives you a good workout on the climbs .... Sorry to be a bother to you but can I run my own chainguide ? Or does it have to be MRP to accommodate the MRP chainring ?
    Reputation: honns's Avatar
    I've recently been looking into the Middleburn RS7 - Lifetime guarantee. Light and strong.
    I think there would be no problem running any type of chainguide. I just went with the MRP so when I get stronger I can run up to a 36 tooth chainring with that chainguide.
    I ride a lot of rocks here so the bash guard has been working good.
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    - I have really liked my X0 cranks but I HATE how they hook together. It makes field servicing impossible.
    - I really like the XT and XTR method of joining the two sides. It's super easy to pull apart and make replacing chain rings (or chain ring bolts) a breeze.
    Interesting comparison from the RF site: http://www.raceface.com/comp/pdf/XC%20Double_RF.pdf
    "sounds like you need to find a better mechanic..." -- Calhoun
    Reputation: Bullit_cn's Avatar
    I think the new 2x10 XT looks good in black,
    The spider looks clean for a 32T single ring setup
    Attached Thumbnails Attached Thumbnails Recommend me a crankset please ! :) on the chili-xtblk.jpg
    When trails gets tougher, Just stand up and deliver.
    RideDirt
    Yea that does looks pretty nice , but do you think that will accept a 32T only ?
    I'm not ashamed to say carbon still freaks me out on a mountain bike ...
    I´ve broken three sets of SixC- cranks during past two years. Two of those are warrantied, one waits still shipping ... Always broken tabs, no other problems with those.
    Used / using several different cranksets in Chili (1x9) and in my full-rigid singlespeeder and after using SixC`s and X0 DH`s with HBC chainrings (there`s a small crack in those too - circular one in area where driveside crank joins to axle...), ended back to old XTR M-970`s. Nearly as light as carbon ones, practically as stiff as carbon ones. Those requires special tool for removing, but that`s the only negative side.
    Don´t say no to carbon in mountain bikes - I´m using carbon handlebar - but no more carbon cranks for me.
    RideDirt
    Yea I think I'll step back from carbon ... The weights on the shimano cranks are perfect .
    Will give you answer later today.
    I have the same crankset with the intention of converting it into 32T single ring setup for my upcoming Chilco too,
    RideDirt
    Quote Originally Posted by Bullit_cn View Post
    Excellent !!! I love test mules hopefully all goes well and get some photos if it does
    Delirious Tuck
    Quote Originally Posted by pergamonx View Post
    Broken tabs? How the heck is that happening? I'm not very light and I've had no issues slamming away on the SixCs for over a year now. Has RF given any feedback? Just curious so I can look out for it, no flame/trolling here.
    TSC
    TSC is offline
    Buehliever
    pergamonx is the extreme tester on everything. He pedals more miles in sub-freezing temps than I do all year. I'm always glad to have him chime in, because if it works for him it is guaranteed to work for me.
    Just say no to single ring set ups with ramped and pinned chain rings. They will work fine, but a non-ramped and non-pinned ring will have more positive contact and feel, especially when things start bouncing around or you ratchet the pedals back to clear something.
    RideDirt
    Quote Originally Posted by B Gillespie View Post
    Sorry for my noobness but can you show me a picture of the 2 different kinds as you mentioned ? Just so i can be on the same page here lol
    Reputation: wilks's Avatar
    I have old xt cranks and an e13 32 tooth chainring (non ramped and pinned) and run 1x10 with the mrp mini g2 sl cgain guide. Works well. FYI any chain ring designed for 1x will not be ramped or pinned. The shimano / SRAM rings designed for 2x or 3x cranksets will.
    Quote Originally Posted by thefriar View Post
    Yep - broken tabs. Here´s one example - others have been ~similar ones - one or two tabs just break.
    All broken cranksets have been 2010 or 2011 models, those new ones yet in package are 2012 model; I´ll suppose RF has strengthened those tabs- have not checked that.
    I´m rather light, riding weight is ~75kg and honestly I´m not sure when or how they have been actually snapped - have noticed those breaks afterwards when looking after some squeek or knocking from drive-train...
    Have used taco-style bash, always, so no direct hits to chainrings. Cranks has got hits, of course. And it`s not question of chainrings, have used many different ones (except RF originals) and that has happened anyways. No over-torque, RF spacers have been in use. Only feedback I´ve got have been new cranks, but I´ve not handled those warranty cases directly with RF, but via resellers.
    Quote Originally Posted by TSC View Post
    TSC, it`s your fault that my keyboard is covered with bursted beer : )
    It´s true that our conditions here are rather tough for parts 5 monts per year. Someway it`s extreme, but I´m not. My riding is about in the middle between N Vuilloz and Winnie the Pooh. And I´ve more bike parts and components than frames, and it`s only fair to give a chance to every single part to break ... Btw, just realized that all those breaks in SixC`s has happened during summertime, so it`s not either question of low temps.
    RideDirt
    Quote Originally Posted by wilks View Post
    Oh ok ! Haha thanks man Now i get it
    Alright it toke me sometime since this new XT cranks requires a T30 torx wrench,
    From the picture below, a 32T is tight as the chain may hit the tip of the spider arm,
    Probably a 34T would fit better,
    Attached Thumbnails Attached Thumbnails Recommend me a crankset please ! :) on the chili-xt32.jpg
    Recommend me a crankset please ! :) on the chili-xt32a.jpg
    RideDirt
    Thank you so much ^^^^^^ !!
    I think the triple is a better choice for single ring conversion
    RideDirt
    Any particular reason why ?
    My bad, I didn't made it clear :-(
    What I am saying is that the 3x10XT is a better choice over the 2x10XT since the spider are similar to the older version which works well with a 32T rings
    RideDirt
    Oh ok got ya
    Missouri sucks...
    +1 for Rockdude's setup. I've been running the same setup and wouldn't have it any other way
    RideDirt
    I actually ended up with the triple shimano XT setup .. Gonna try a single guide setup from there and see what happens .
    Reputation: Big B's Avatar
    Quote Originally Posted by Rock dude View Post
    What type of derailleur are you running with this setup? Medium or Long cage?
    I'm looking to mirror this setup on my Chili, except using RF Chester 175mm cranks.
    Just got the XTR M985 - $299 for my chili that's on the way.
    $299.00
    56% off $679.99 msrp
    Shimano XTR M985 10SPD Double Crankset > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop
    Reputation: bionicman's Avatar
    Quote Originally Posted by mbikerguy View Post
    $299.00
    hope your legs can push that gearing!
    Quote Originally Posted by Big B View Post
    I'm using a medium cage X9 with 34t ring and 11-32t cassette. Works great, but I'm looking to switch to a short cage soon.
    RideDirt
    $299.00
    Great deal on that ! But i can see why lol that gearing is crazy but as someone said , hope you can push that gear as well
    $299.00
    Keep in mind that particular crankset doesn't use the normal 110/64 bolt pattern, it's something funky. So if you need to ever replace the rings you'll probably have to pay a fortune for Shimano ones, or if you ever want to single ring it up front, finding a non-ramped ring might be hard.
    Just FYI. I looked into these in the past if you can't tell.
    Reputation: Calhoun's Avatar
    Nov 2008
    my vote is for these
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    RideDirt
    Quote Originally Posted by Calhoun View Post
    Would look pretty sick on a black chili
    Nov 2008
    with these too
    -cabra cadabra
    RideDirt
    These look really sick !! too bad i just saw them lol 2013 E*Thirteen TRSr Single Cranks - New Mountain Bike Components at Eurobike 2012 - Mountain Biking Pictures - Vital MTB
    But anyways , my XT cranks came in , waiting on more stuff to be delivered before i get the 1x10 setup for now .
    Keep in mind that particular crankset doesn't not use the normal 110/64 bolt pattern, it's something funky. So if you need to ever replace the rings you'll probably have to pay a fortune for Shimano ones, or if you ever want to single ring it up front, finding a non-ramped ring might be hard.
    I didn't realize it was so different from the XT.
    Thanks for the heads up.
    I picked up a set of Race Face Chester with a 32 tooth ring, and 12-36 cassette.
    Anyone know the spacer configuration for installing the bb in a single ring setup?
    Dependes on your frames designed BB width (68mm, 73mm, or 83mm) and the width of the cranks you picked out.
    I figured since this was a Chili thread, folks would know its a 73mm BB width. I actually spoke with Knolly recently, and they said a 2.5mm spacer on the drive side is all I need for the BB. So I'm good, thanks.
    You know what they say about assuming...
    Ive got those same cranks but with a Chromag 32t single ring and Blackspire Der Guide on my Surface
    Recommend me a crankset please ! :) on the chili-imageuploadedbytapatalk1347914214.910692.jpg
    RideDirt
    2012 Shimano XT 3x10 converted to a 1x10 using E-13 32T ring .
    Reputation: drakche's Avatar
    Nov 2012
    What bolt's did you use? Dis you use the original 8.5 mm bolts or did you had to go and get shorter 7 mm bolts?
    I'm looking into converting an FC-M670 to single ring.
    And can you please post a picture of the backside?
    Thanks.
    RideDirt
    You can use the original bolts since they are too long , when I bought my chain ring I also purchased the single speed bolts . I forget exactly what size they are but just make sure they are the single speed ones and I made my purchase thru Universal Cycles.
    My bike is all built up so I don't have any back side shots of it , but they sit very flush , nothing is in the way , and everything lines up just fine .
    Nov 2012
    Since I read that some people had to file the granny ring threads to fit it with a chain-ring.
    Looking at alternatives, I think I'm gonna go with single ring + Bash ring, So I think I won't need shorter bolts, But will purchase them, just in case.
  67. #67
    RideDirt
    Quote Originally Posted by drakche View Post
    You just need the proper crankset and you wont have any issues.. This is why i went with the 3x10 crankset so i can properly set it up as a 1x10 or you can go spiderless and not have an issue as well . These are the bolts i used ( Single Black )
    Universal Cycles -- Vuelta Anodized Aluminum Chainring Bolt Set
  68. #68
    Nov 2012
    I think that those are the 7 mm ones. Thanks. I'd go with the spiderless but those cranks are to expensive. SLX is for me (Plus I really like the 2013 look, they are just awesome, much prettier than XT IMO, they go great with Saint pedals).
