Page 3 of 3 FirstFirst 1 2 3
Results 51 to 68 of 68
  1. #51
    Quote Originally Posted by mbikerguy View Post
    Just got the XTR M985 - $299 for my chili that's on the way.
    $299.00
    56% off $679.99 msrp
    Shimano XTR M985 10SPD Double Crankset > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop
    Keep in mind that particular crankset doesn't use the normal 110/64 bolt pattern, it's something funky. So if you need to ever replace the rings you'll probably have to pay a fortune for Shimano ones, or if you ever want to single ring it up front, finding a non-ramped ring might be hard.
    Just FYI. I looked into these in the past if you can't tell.
  2. #52
    Reputation: Calhoun's Avatar
    Nov 2008
    my vote is for these
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
  3. #53
    RideDirt
    Reputation: aedubber's Avatar
    Quote Originally Posted by Calhoun View Post
    Would look pretty sick on a black chili
  4. #54
    Nov 2008
    Quote Originally Posted by aedubber View Post
    with these too
    -cabra cadabra
  5. #55
    RideDirt
    These look really sick !! too bad i just saw them lol 2013 E*Thirteen TRSr Single Cranks - New Mountain Bike Components at Eurobike 2012 - Mountain Biking Pictures - Vital MTB
    But anyways , my XT cranks came in , waiting on more stuff to be delivered before i get the 1x10 setup for now .
  6. #56
    Quote Originally Posted by rscecil007 View Post
    Keep in mind that particular crankset doesn't not use the normal 110/64 bolt pattern, it's something funky. So if you need to ever replace the rings you'll probably have to pay a fortune for Shimano ones, or if you ever want to single ring it up front, finding a non-ramped ring might be hard.
    I didn't realize it was so different from the XT.
    Thanks for the heads up.
  7. #57
    Reputation: Big B's Avatar
    I picked up a set of Race Face Chester with a 32 tooth ring, and 12-36 cassette.
    Anyone know the spacer configuration for installing the bb in a single ring setup?
  8. #58
    Reputation: honns's Avatar
    Dependes on your frames designed BB width (68mm, 73mm, or 83mm) and the width of the cranks you picked out.
  9. #59
    I figured since this was a Chili thread, folks would know its a 73mm BB width. I actually spoke with Knolly recently, and they said a 2.5mm spacer on the drive side is all I need for the BB. So I'm good, thanks.
  10. #60
    You know what they say about assuming...
  11. #61
    Quote Originally Posted by Bullit_cn View Post
    I think the new 2x10 XT looks good in black,
    The spider looks clean for a 32T single ring setup
    Yea that does looks pretty nice , but do you think that will accept a 32T only ?
    Ive got those same cranks but with a Chromag 32t single ring and Blackspire Der Guide on my Surface
  12. #62
    Recommend me a crankset please ! :) on the chili-imageuploadedbytapatalk1347914214.910692.jpg
  13. #63
    RideDirt
    2012 Shimano XT 3x10 converted to a 1x10 using E-13 32T ring .
  14. #64
    Reputation: drakche's Avatar
    Nov 2012
    What bolt's did you use? Dis you use the original 8.5 mm bolts or did you had to go and get shorter 7 mm bolts?
    I'm looking into converting an FC-M670 to single ring.
    And can you please post a picture of the backside?
    Thanks.
  15. #65
    RideDirt
    You can use the original bolts since they are too long , when I bought my chain ring I also purchased the single speed bolts . I forget exactly what size they are but just make sure they are the single speed ones and I made my purchase thru Universal Cycles.
    My bike is all built up so I don't have any back side shots of it , but they sit very flush , nothing is in the way , and everything lines up just fine .
  16. #66
    Nov 2012
    Since I read that some people had to file the granny ring threads to fit it with a chain-ring.
    Looking at alternatives, I think I'm gonna go with single ring + Bash ring, So I think I won't need shorter bolts, But will purchase them, just in case.
  17. #67
    RideDirt
    Quote Originally Posted by drakche View Post
    You just need the proper crankset and you wont have any issues.. This is why i went with the 3x10 crankset so i can properly set it up as a 1x10 or you can go spiderless and not have an issue as well . These are the bolts i used ( Single Black )
    Universal Cycles -- Vuelta Anodized Aluminum Chainring Bolt Set
  18. #68
    Nov 2012
    I think that those are the 7 mm ones. Thanks. I'd go with the spiderless but those cranks are to expensive. SLX is for me (Plus I really like the 2013 look, they are just awesome, much prettier than XT IMO, they go great with Saint pedals).
