Results 1 to 3 of 3
    Pivoteer
    Reputation: tiSS'er's Avatar
    NON-LEV Dropper cable routing
    Can you guys post photos of the cable routing on your non-LEV posts? I am looking at either a Thomson or Reverb but not sure how to run the cables without making a mess. Any help is much appreciated.
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: 006_007's Avatar
    If nobody posts anything by the weekend I will uninstall my LEV and re-install my i950 for some pics.
    I had it setup so the cable wend down the front of the post / seattube and it never really interfered with the 4x4 linkage - but I could occasionally feel the excess loop tickle the inside of my leg.
    Pivoteer
    Quote Originally Posted by 006_007 View Post
    Thanks, no need to go out of your way to post those, that is a total PITA. I have some ideas, but the 4x4 makes routing a bit more difficult than some other frames. I may run it down the downtube with the brake cable and then straight up the seattube. That way the loop would be lower on the frame near the BB and would look clean. I am just having issues figuring out how to use the existing guides on the top tube without issue.
    Another thought I have is to locate a solid plastic tube, just slightly larger than the cable housing. Attach this housing to the guides on the top tube. I could then run the housing through the tube, and the excess loop would exit at the front of the bike. It would be a bit tricky and I couldn't have any binding.
    I'm a stickler for good cable routing, and cable rub drives me nuts.
  1. Jet 9 RDO Dropper Seat cable routing?
    By Ohfugit in forum Niner Bikes
    Last Post: 07-22-2016, 09:18 AM
  2. Dropper Post Cable Routing on Mojo-C
    By cchough in forum Ibis
    Last Post: 05-28-2013, 10:33 PM
  3. Dropper Post Cable Routing
    By steve86 in forum Ibis
    Last Post: 06-01-2012, 06:14 PM
  4. Cable routing for dropper seatpost on a Pitch
    By southdowner in forum Specialized
    Last Post: 07-11-2011, 04:52 AM
  5. Custom cable routing for dropper seatpost?
    By D45yth in forum Nicolai
    Last Post: 01-06-2011, 01:58 AM
