Results 1 to 5 of 5
    Mounting front derailuer on chilcontin
    Trying to mount the shimano fd on the chilcontin and the outer chain guide is rubbing against the big ring. No way it will work the way i am attaching it. I am putting on a xo 2x10 crank and it is the correct derailuer per knolly's recommendation.
    Thanks,
    Patrick
    Knomer
    Reputation: Dusty Bottoms's Avatar
    By "chain guide" do you mean the cage of the derailleur? What size outer ring are you using, and what model front derailleur?
    Director of Sales: Knolly Bikes
    Yes I guess I mean the derailuer cage. It is the shimano fd-m785-e2. The one per knolly's recommendation. The outer ring is a 42t.
    bike tester
    Reputation: syl3's Avatar
    m785 is 2x10 with max 12t capacity and max 38/40 ring. you need another crank option for this fd.
    first result in google Product
    or you can run a sram fd with your sram crank: SRAM X0 2 x 10 Low Direct Mount-S1 Front Derailleur | Backcountry.com
    Thanks. I was afraid of that. But getting a new derailuer is easier than a new crank.
    Best,
    P
  1. Replies: 0
    Last Post: 04-12-2013, 05:11 PM
  2. Replies: 15
    Last Post: 07-16-2012, 05:14 PM
  3. Front derailuer help
    By dhelm72 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2012, 05:45 PM
  4. Mounting a rear rack in front?
    By cjohnson in forum Commuting
    Last Post: 03-05-2012, 09:00 AM
  5. Bolt on Front hub with ISO disk mounting
    By Pritchett in forum Wheels and Tires
    Last Post: 02-01-2011, 10:30 AM
